6 registered members (TBM, RedThree, DickJ, IcePack, RichardV6, John V6), 405 guests, and 16 spiders.
+8Rich 188
John V6 160
TBM 84
Peter J 82
Tont, Norfolk Mog, Moggie31, Upton O'Good, BlueMorgan
7754 Registered Users
Battery Disconnection
by Topline123. 03/12/21 08:36 AM
Combat stress calendar
by Gordon D. 02/12/21 06:24 PM
Ideas around the new threewheeler
by xc68anc. 02/12/21 01:53 PM
Leaking brake fluid
by M3W Glasgow. 01/12/21 06:26 PM
What is the 3W's actual turning radius?
by MichaelS. 01/12/21 05:52 PM
Brake Rotors
by PaulyG. 01/12/21 01:26 PM
Morgan Grand Prix 1917 Replica-Progress-12/02/21
Plus 8
November in the New Forest
Shuttleworth Collection
Getting Comfortable
Topics42,476
Posts713,185
Members7,754
Most Online1,033
Dec 28th, 2019
Toi
Drivers footwell cross bar #722412
23/10/21 05:44 PM
23/10/21 05:44 PM
England, Shropshire
Andrewmcc Offline OP
England, Shropshire
I could not think of another description for the " Drivers footwell cross bar". Its the bar, that is actually on the floor of both footwells, part of the frame, that I and probably many of you use to heave yourself out with. I put my feet on it and push myself up and then nip over the side. Hopefully you now no what I'm talking about. The aforementioned crossbar is now showing signs of wear and needs repainting. Does anyone have a recomended hard wearing paint that they may have used to do the same job?
Thanks
M3W, Bentley Continental 6.0 Flying Spur, MGB BGT. Beetle Conv, Merc Est, Renault Cleo.
Re: Drivers footwell cross bar [Re: Andrewmcc] #722416
23/10/21 06:12 PM
23/10/21 06:12 PM
Staffordshire,U.K.
Missing Wheel Offline
Staffordshire,U.K.
I know exactly where you mean, and what you mean.
I use black tank tape or gaffer tape to cover the tube, when in place it is difficult to see that it is not painted. The tape can be changed as often as needed ( it seems pretty tough and lasts quite well) with little effort or expense.
Hope this helps.
Re: Drivers footwell cross bar [Re: Andrewmcc] #722419
23/10/21 06:20 PM
23/10/21 06:20 PM
Georgia, USA
Lance Offline
Lance  Offline
Georgia, USA
I use black traction tape so that I don't slip getting in or out.
Lance
1981 Plus 8
2016 Three Wheeler
2014 Corvette Stingray Convertible z51
Re: Drivers footwell cross bar [Re: Lance] #722420
23/10/21 06:28 PM
23/10/21 06:28 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Good idea. Stair tread tape, skateboard tape, etc. I put a wide strip of it on the third rail on my 4 post lift to stop the rear wheel from spinning on the aluminum channel. The tape covers between the upright legs of the channel.
It also makes for good gripping surface on things you don't want to drop.
Re: Drivers footwell cross bar [Re: Andrewmcc] #722428
23/10/21 07:41 PM
23/10/21 07:41 PM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
I use tape for protection on the cross beam as well , but for general touching up on the chassis, you cant beat Tractol paint ( Phil B tip )
https://www.amazon.co.uk/APUK-Tract...tol+paint&qid=1635017999&sr=8-14
Re: Drivers footwell cross bar [Re: Andrewmcc] #722432
23/10/21 09:46 PM
23/10/21 09:46 PM
Surrey UK
Malcolm M3W Offline
Malcolm M3W  Offline
Surrey UK
I have thought about the non slip tape as seen on skateboards, I think alluded to above. Not done it yet though!
Re: Drivers footwell cross bar [Re: Malcolm M3W] #722434
23/10/21 10:26 PM
23/10/21 10:26 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Re: Drivers footwell cross bar [Re: Andrewmcc] #722436
23/10/21 10:48 PM
23/10/21 10:48 PM
East Hampshire
Number42 Offline
Number42  Offline
East Hampshire
Courtesy of Mr Bleazey The Special has a non-slip finish to the cross rail and it works a treat. I’ve no idea how he did it but it is certainly a good mod to do.
Re: Drivers footwell cross bar [Re: Number42] #722454
24/10/21 06:03 AM
24/10/21 06:03 AM
West Sussex, UK
Chris99 Offline
Chris99  Offline
West Sussex, UK
I painted mine with Hammerite which worked well.
Mix some sand in it to give an anti slip finish
Red Leader drive
Re: Drivers footwell cross bar [Re: Andrewmcc] #722479
24/10/21 10:27 AM
24/10/21 10:27 AM
United Kingdom, Lincolnshire
planenut Offline
planenut  Offline
Black plastic water pipe with a cut along the side so that it clips over the chassis tube works well.
