16 registered members (sprinty, JMcL, TBM, Craig Jezz, +8Rich, MATTMOG, Bonesie, griffo, Alistair, Topline123, OZ 4/4, nippymog, Aeroman, TimG, Viper, vbalddave), 389 guests, and 19 spiders.
+8Rich 188
John V6 158
TBM 83
Peter J 82
Tont, Norfolk Mog, Moggie31, Upton O'Good, BlueMorgan
7754 Registered Users
Battery Disconnection
by Topline123. 03/12/21 08:36 AM
Combat stress calendar
by Gordon D. 02/12/21 06:24 PM
Ideas around the new threewheeler
by xc68anc. 02/12/21 01:53 PM
Leaking brake fluid
by M3W Glasgow. 01/12/21 06:26 PM
What is the 3W's actual turning radius?
by MichaelS. 01/12/21 05:52 PM
Brake Rotors
by PaulyG. 01/12/21 01:26 PM
Morgan Grand Prix 1917 Replica-Progress-12/02/21
Plus 8
November in the New Forest
Shuttleworth Collection
Getting Comfortable
Topics42,476
Posts713,177
Members7,754
Most Online1,033
Dec 28th, 2019
Toi
Page 1 of 4 1 2 3 4
Fuel Pump Not Working! #725746
24/11/21 03:41 PM
24/11/21 03:41 PM
Derby, UK
BGW Offline OP
BGW  Offline OP
Derby, UK
[2001 4/4 1.8 Black Top Zetec.
[Had a lovely drive out in the mild weather, came home and parked up in the garage. A few days later it wont start! The fuel pump is not working. New battery, new fuel pump relay, new fuse, all connections checked visually. Imobiliser light goes out when ignition is turned on, inertia switch pressed in. Have run out of ideas. Can anyone help please? Thanks in anticipation, cheers, Brendan.
Brendan
2001 4/4.
Re: Fuel Pump Not Working! [Re: BGW] #725752
24/11/21 04:23 PM
24/11/21 04:23 PM
Yorkshire
Jack & Jill 602 Offline
Yorkshire
Brendan,
Have you tried a supply direct to pump from battery?
Jack
1985 4/4 T/C 4 seater Royal Ivory
2018 Pembleton SuperSport (self built).
Siva Edwardian
Re: Fuel Pump Not Working! [Re: BGW] #725754
24/11/21 04:26 PM
24/11/21 04:26 PM
Derby, UK
BGW Offline OP
BGW  Offline OP
Derby, UK
Hi Jack - I haven't. Might be a good idea. Do you know which pin to connect to? I don't seem able to find a fuel system wiring diagram.
Brendan
2001 4/4.
Re: Fuel Pump Not Working! [Re: BGW] #725755
24/11/21 04:42 PM
24/11/21 04:42 PM
Devonshire
+8Rich Online content
+8Rich  Online Content
Devonshire
On my older car it is a White/Purple positive switched feed to the pump, it might be worth putting a voltmeter on there first to see if it's live. I'm not too keen on having a spare floating live feed around a petrol tank, maybe I'm just too careful.
The pump is twenty years old now.
Regards Richard
1994 Connaught Green +8 prev
Re: Fuel Pump Not Working! [Re: BGW] #725762
24/11/21 05:13 PM
24/11/21 05:13 PM
Luddite Offline
Luddite  Offline
Brendan I have no idea of your Morgans fuel system where the pump might be located whether in tank or close to it.... on my 86 +8 the pump is mounted above the tank thus easy to get to. White and Purple as Richard suggests fits with my poor memory, but you will find wiring colour codes here should you have any confusion..
Wiring and Fusing - BS-AU7 Colour Codes (mgb-stuff.org.uk)
Good luck.
Re: Fuel Pump Not Working! [Re: BGW] #725767
24/11/21 05:20 PM
24/11/21 05:20 PM
Derby, UK
BGW Offline OP
BGW  Offline OP
Derby, UK
Thanks everyone, my pump is of the in-tank variety and a pig to change I suspect!
Brendan
2001 4/4.
Re: Fuel Pump Not Working! [Re: BGW] #725773
24/11/21 05:39 PM
24/11/21 05:39 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
As Richard says, start with a check for a voltage at the pump connector. And don't discount the possibility that your new relay is faulty.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: Fuel Pump Not Working! [Re: BGW] #725774
24/11/21 05:40 PM
24/11/21 05:40 PM
SimonH Offline
SimonH  Offline
It’s a tank out job to change, assuming you can hold of one
You’ll probably have to swap the pump itself rather than the complete assembly
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Fuel Pump Not Working! [Re: BGW] #725775
24/11/21 06:08 PM
24/11/21 06:08 PM
Staffordshire
IvorMog Offline
IvorMog  Offline
Staffordshire
If the pump is faulty, have a word with Terry at Glencoe.at the link below.
I think the pump shown is what I used but with a different flat strainer instead of the canoe type shown.
Glencoe fuel pump
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Re: Fuel Pump Not Working! [Re: BGW] #725777
24/11/21 06:22 PM
24/11/21 06:22 PM
Luddite Offline
Luddite  Offline
My guess is that an in-tank pump may be fed through a connector that could also take in the fuel gauge, perhaps both using the same earth (black). That perhaps being the case then green/black may be the fuel gauge thus looking to find the white/purple as being live with the IGN switched on would seem a worthwhile check..? Assuming there are no other safety devices/switches between the ign switch and the inertia switch you mention.
In my car the oil pressure has to be present for the pump to continue running and on fuel injected cars there can be other measures used to ensure the engine is running to ensure that the fuel pump electrical supply is maintained.
Good luck.
Page 1 of 4 1 2 3 4
