14 registered members (Fpoutch, Davetherave, IcePack, HJF, meabh, RJW, BigLes, Topline123, M3W55, John V6, DickJ, TBM, Sir Percival, Jon G4LJW), 415 guests, and 17 spiders.
+8Rich 188
John V6 158
TBM 83
Peter J 82
Tont, Norfolk Mog, Moggie31, Upton O'Good, BlueMorgan
7754 Registered Users
Battery Disconnection
by Topline123. 03/12/21 08:36 AM
Combat stress calendar
by Gordon D. 02/12/21 06:24 PM
Ideas around the new threewheeler
by xc68anc. 02/12/21 01:53 PM
Leaking brake fluid
by M3W Glasgow. 01/12/21 06:26 PM
What is the 3W's actual turning radius?
by MichaelS. 01/12/21 05:52 PM
Brake Rotors
by PaulyG. 01/12/21 01:26 PM
Morgan Grand Prix 1917 Replica-Progress-12/02/21
Plus 8
November in the New Forest
Shuttleworth Collection
Getting Comfortable
Topics42,476
Posts713,181
Members7,754
Most Online1,033
Dec 28th, 2019
Toi
Throttle Return Springs - Weber 32/36 DGV #725798
24/11/21 09:20 PM
24/11/21 09:20 PM
UK
SCX358G Offline OP
SCX358G  Offline OP
UK
I have a Weber 32/36 DGV (manual choke) carb on the 1600 crossflow engine in my 4/4. Currently it only has one throttle return spring, and that is not secured (imho) in a particularly elegant manner.
Can anyone tell me if one or two springs are normal (I would have thought two were safer) and show me a diagram or pic of how the lower end of the throttle return springs are correctly secured?
many thanks
Dave
Blue 4/4 1969, Green +4 1953
Re: Throttle Return Springs - Weber 32/36 DGV [Re: SCX358G] #725801
24/11/21 09:30 PM
24/11/21 09:30 PM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
Got the standard return spring in the carb, and then the additional vertical one you can see in this photo. Spring is an MGB/C throttle spring which goes from the throttle assembly on the carb to a very rudimentary bottom bracket. Will probably fabricate something better at some point.
1972 4/4 4 seater - 3G Morganeer
Too many ratty motorbikes
Re: Throttle Return Springs - Weber 32/36 DGV [Re: SCX358G] #725802
24/11/21 09:31 PM
24/11/21 09:31 PM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
Close up
Re: Throttle Return Springs - Weber 32/36 DGV [Re: SCX358G] #725805
24/11/21 10:33 PM
24/11/21 10:33 PM
Evergreen, Colorado, USA
britmog Offline
britmog  Offline
Here are a couple of pictures of my double return spring, hope they help?
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Re: Throttle Return Springs - Weber 32/36 DGV [Re: SCX358G] #725807
24/11/21 11:15 PM
24/11/21 11:15 PM
Yorkshire
Jack & Jill 602 Offline
Yorkshire
Secondary throttle cables should ideally be a compression spring over the exposed inner throttle cable, additional extension springs on the carb linkage are likely to put extra load on throttle spindle increasing wear.
Jack
1985 4/4 T/C 4 seater Royal Ivory
2018 Pembleton SuperSport (self built).
Siva Edwardian
Re: Throttle Return Springs - Weber 32/36 DGV [Re: SCX358G] #725811
25/11/21 06:22 AM
25/11/21 06:22 AM
Manitoba, Canada
BertL Offline
BertL  Offline
Manitoba, Canada
RHD 1970 Not my car in photos but my '69 has exactly the same fitment,
only one return spring and it is attached to the rad. stay-rod by simply inserting the open end loop over it.
https://www.tm-img.com/image/3XZGK][img]https://www.tm-img.com/images/2021/11/25/60774554-770-02X.jpg
https://www.tm-img.com/image/3XC1Q][img]https://www.tm-img.com/images/2021/11/25/60774552-770-02X.jpg
https://www.tm-img.com/images/2021/11/25/60774560-770-02X.jpg
Bert & B1800
Re: Throttle Return Springs - Weber 32/36 DGV [Re: SCX358G] #725813
25/11/21 07:17 AM
25/11/21 07:17 AM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
The joy of Morgans - three cars, three completely different set ups smile smile
Re: Throttle Return Springs - Weber 32/36 DGV [Re: TBM] #725822
25/11/21 08:58 AM
25/11/21 08:58 AM
UK
SCX358G Offline OP
SCX358G  Offline OP
UK
Thanks very much for the quick replies - isn't Talkmorgan wonderful !!
Dave
Re: Throttle Return Springs - Weber 32/36 DGV [Re: BertL] #725823
25/11/21 09:21 AM
25/11/21 09:21 AM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'06 Saab 9-3 Convertible
Re: Throttle Return Springs - Weber 32/36 DGV [Re: SCX358G] #725825
25/11/21 09:30 AM
25/11/21 09:30 AM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
It's interesting that Bert's works in the opposite way to mine. I certainly don't have that bar that goes to the radiator either. However, the metal bracket that holds the cable adjuster is the same as mine, although mine is in the rear of the carb (by the rocker cover).
Bruce's works the same as mine, although looks like one of the weber linkage kits has been added Linkage Kit
