6 registered members (Nathan, Image, sprinty, Chris2002tii, Graeme Morrison, Ginmoggie), 162 guests, and 10 spiders.
RichardV6 111
Luddite 107
John V6 91
OZ 4/4 85
adamcobb, David68, Feierstarter, pinkhouse10, Rabid Ray
8264 Registered Users
Hello from Germany
by Feierstarter. 31/01/23 10:19 PM
Floods in New Zealand
by OZ 4/4. 31/01/23 08:32 PM
Wanted - Aero 8, Series 1/2/3
by verysideways. 31/01/23 05:37 PM
Rebound spring gap ??
by Peter H. 31/01/23 12:59 PM
Which satellite navigation
by Condor. 31/01/23 10:47 AM
Hello from Franconia (Germany)
by JBKPlusFour. 30/01/23 09:36 PM
Experimenting to see if I can finally upload a pic
by Jonathan G. 30/01/23 04:40 PM
JBKsPlusFour #2
JBKsPlusFour
LM62
Autumn leaves
Babeny Dartmoor
Topics44,620
Posts754,819
Members8,264
Most Online1,033
Dec 28th, 2019
Eddie, Gary Fairhurst, kwb
Page 2 of 4 1 2 3 4
Re: Petrol smell and drip from engine [Re: Bobajobbob] #726071
28/11/21 05:22 PM
28/11/21 05:22 PM
Hertfordshire
O
Obie Offline
Obie  Offline
O
Hertfordshire
Here is a thread on wet sumping. http://www.talkmorgan.com/ubbthreads.php/topics/290761/1
If you do a search in Google you will usually find something linked to Talk Morgan, quicker than doing the search in TM.
Re: Petrol smell and drip from engine [Re: Bunny] #726076
28/11/21 05:48 PM
28/11/21 05:48 PM
Kent
Bobajobbob Offline OP
Kent
Originally Posted by Bunny
Originally Posted by Bobajobbob
When you say "starting the engine after wet sumping" what do you mean?
When the M3W has been standing for an extended time (think weeks) without the engine being run then there is a tendency on many engines for oil to drain from the oil tank, past the oil pump into the crankcase. On my car, around 2 Litres ends up in the wrong place. When the engine is subsequently started, the oil is pumped back up to the oil tank where it belongs. A small amount may also be 'burped' out of the breather pipe which connects the crankcase to the air intake. This can dribble down through the air filter and end up on the floor if it's not all absorbed by the air filter element.
This is a feature of many dry-sump motorcycle engines so we cannot point the finger at MMC this time!
Many thanks. The car hadn't been driven for a couple of weeks so that is a possibility. The fluid did appear to be dripping down from the air filter area although the smell does appear to be more petrol than oil. Of course this being a Morgan there may well be petrol leaking somewhere else and I am being distracted by a more obvious but benign oil leak.
92 Connaught Green Plus 4
Triumph Bonneville 865
Re: Petrol smell and drip from engine [Re: Bobajobbob] #726079
28/11/21 06:06 PM
28/11/21 06:06 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
You could easily have both issues happening. Wet sumping pumping oil into the air cleaner and driping out as well as fuel leaking from the injector tower fuel hoses, or the tower spigots themselves.
Pull the fan to check for fuel leaks as has been said before.
The oil into the air cleaner just gunks up the air cleaner and dumps oil into the intakes causing crud to build up on the pistons, the rear piston in particular.
Re: Petrol smell and drip from engine [Re: Bobajobbob] #726099
28/11/21 08:11 PM
28/11/21 08:11 PM
Berkshire, England
Mark H Offline
Mark H  Offline
Berkshire, England
My money is on fuel hose issue - coupling or split plus front engine crank seal or blocked vent.
Got to love the M3W
Re: Petrol smell and drip from engine [Re: Bobajobbob] #726145
29/11/21 02:55 PM
29/11/21 02:55 PM
Aberdeenshire
TimG Offline
TimG  Offline
Aberdeenshire
Leaking fuel is not good round any engine but if fuel gets on your screens they will go opaque & need changing. I had a leak from the crimped hose connections.
Re: Petrol smell and drip from engine [Re: Bobajobbob] #726203
29/11/21 08:25 PM
29/11/21 08:25 PM
Lot et Garonne, France
Stevo666 Offline
Stevo666  Offline
Probably after effects of wet sumping or could be excessively breathing engine (piston rings) that's sending a fine mist into the throttle body/air filter area continuously - when you stop it slowly accumulates to bottom of filter/throttle body and seeps out onto cam chest cover over a couple of days then down onto floor.
Fit a remote catch tank/breather tank which should solve the issue if your that concerned.
Check the fuel hoses as a priority of course but looking at the picture that wouldn't be petrol staining the ground like that.
Re: Petrol smell and drip from engine [Re: Bobajobbob] #726207
29/11/21 09:04 PM
29/11/21 09:04 PM
Kent
Kent
Cheers all for all the info and suggestions. While I am at it should I also be checking the fuel tanks? I certainly haven't noticed fuel on the screens so I suppose if there is a petrol leak, above and beyond any oil issues, it could also be happening at the back of the car too?
Re: Petrol smell and drip from engine [Re: Bobajobbob] #726209
29/11/21 09:29 PM
29/11/21 09:29 PM
Berkshire, England
Mark H Offline
Mark H  Offline
Berkshire, England
Fuel tanks crack around the mount points - forget to add that one to the list - The fuel spray cracked my screens too
Re: Petrol smell and drip from engine [Re: Bobajobbob] #726346
01/12/21 10:43 PM
01/12/21 10:43 PM
Stevo666 Offline
Stevo666  Offline
For fuel tank leaks, quickest way to see is look at the wood 'protection' pieces underneath and see if they are stained.
Just have a car here now where the bottom seam weld has a crack running along it....wood heavily stained....
Re: Petrol smell and drip from engine [Re: Bobajobbob] #726351
02/12/21 01:02 AM
02/12/21 01:02 AM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
the tank fill tube weld to the tank can leak too.
Page 2 of 4 1 2 3 4
