1 registered members (LightSpeed), 139 guests, and 22 spiders.
+8Rich 190
John V6 135
OZ 4/4 88
TBM 86
Image 79
Rosendahl, Vladimir T, 2949olivier, peter tierney, Tom ff
7771 Registered Users
S1 for sale
by Tvrtastic. 17/01/22 11:14 PM
The usual way to get lost…
by xc68anc. 17/01/22 08:58 PM
Exhaust température
by atalante83. 17/01/22 07:04 PM
Map light, another style
by xc68anc. 17/01/22 06:29 PM
Tool to release tenax hood fasteners
by Jonathan G. 17/01/22 05:06 PM
Brough Superior
by Gambalunga. 17/01/22 03:27 PM
So, you think YOUR roof leaks a little..
by Stringers Best Mate. 16/01/22 11:05 PM
King George VI badge
Ms Marple meets Grandmama!
Sunshine Returns to the North East
MOG414 gear knob
2022 is the year!!!!!
Topics42,691
Posts717,121
Members7,771
Most Online1,033
Dec 28th, 2019
No Birthdays
Battery Disconnection #726459
03/12/21 08:36 AM
03/12/21 08:36 AM
France, 66
Topline123 Offline OP
France, 66
Good morning
I need to add a USB charging port to my car (2005 Plus Four). Can someone please tell me how long I can disconnect the battery for in order to do the work without upsetting the factory immobiliser? Thanks in advance.
2005 Plus 4
2020 Hyundai eKona
2020 Mitsubishi Outlander PHEV
Re: Battery Disconnection [Re: Topline123] #726462
03/12/21 08:56 AM
03/12/21 08:56 AM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
When I first changed my battery, the engine ran rather roughly for a few seconds as I guess the ecu had lost its memory, but it quickly recovered. I cannot think of why the immobiliser would be upset by a disconnection.
Incidentally, for USB ports, I simply purchased a double USB unit fitted with an extension lead and cigar lighter plug, from ebay. I mounted it virtually out of direct sight, onto the scuttle bar on the passenger side with a couple of cable ties and simply plugged it into the existing cigar lighter socket.
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: Battery Disconnection [Re: Topline123] #726463
03/12/21 08:57 AM
03/12/21 08:57 AM
Wiltshire
RJW Offline
RJW  Offline
Wiltshire
I replaced the battery on my 2013 Plus 4 and decided to paint the support cradle at the same time. This meant there was no battery connected for a few days. No adverse affect as far as I can tell.
Re: Battery Disconnection [Re: Topline123] #726466
03/12/21 09:22 AM
03/12/21 09:22 AM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
+1 for the adaptor.
This one even gives voltage readout as well as two 3.1 amp outlets.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Battery Disconnection [Re: RichardV6] #726469
03/12/21 09:29 AM
03/12/21 09:29 AM
France, 66
France, 66
Thanks for the infos. I've decided to leave the cigarette lighter intact as it is useful to plug in a coolbox and use the permanent live feed for the maplight instead. I will connect a bracket to the tubular bar that is under the dashboard, above the transmission tunnel. When it's done and I haven't set light to the car ,I'll post a picture.
2005 Plus 4
2020 Hyundai eKona
Re: Battery Disconnection [Re: Topline123] #726478
03/12/21 10:48 AM
03/12/21 10:48 AM
Suffolk
John V6 Offline
Brooklands Register contact
John V6  Offline
Suffolk
I found some adapters don't give out enough umph to charge my phone. No idea why but I have one that works now.
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Battery Disconnection [Re: Topline123] #726487
03/12/21 12:19 PM
03/12/21 12:19 PM
Solihull
Spanner Juggler Offline
Solihull
On the shop floor we used to plug in a battery charger to the cigar lighter, it was called a Code Saver to save loosing the radio code. Similar would work and if you have a battery conditioner that plugs into the fag socket it would work. Just be aware that the battery + cable will still be live even after it’s disconnected so isolate with a rag or similar. I have done it several times on Morgan’s when adding sat Nav charging leads for myself and pals cars.
BR
Colin
BR Colin
Re: Battery Disconnection [Re: Topline123] #726489
03/12/21 12:30 PM
03/12/21 12:30 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
If you don’t have a radio, you can replace the blanking plate with a piece of plastic drilled for a twin USB socket. You can then buy a plug and flying leads that will plug into the radio wiring. That will give you an ignition enabled USB socket without modifying the car wiring. If that suits you, I will dig around and see if I can find the details of the plug and leads that I bought when I did mine. I also fitted a cigar lighter at the same time (also ignition switched) which I use for my Sat Nav.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: Battery Disconnection [Re: Topline123] #726493
03/12/21 01:12 PM
03/12/21 01:12 PM
Suffolk
John V6 Offline
John V6  Offline
Suffolk
I have a radio that has a USB aux socket. I use that to power my GPS Speedo. As Paul says it is only on with the ignition. I use an extension USB lead with several sockets so I also still have the use of a memory stick for music. I don't think I would trust this route for a high current device.
Re: Battery Disconnection [Re: John V6] #726521
03/12/21 05:31 PM
03/12/21 05:31 PM
RichardV6 Offline
RichardV6  Offline
Differing current ratings John. The ratings I'm aware of are 2.1 and 3.1 amps which apply to car adaptor and mains socket variants to name but two. Often adaptors are offered with two USB sockets covering both current ratings as some delicate devices may suffer from too higher charge current.
