10 registered members (TalkMorgan, Arwyn Williams, PaulV, RichardV6, BLUE+4, RedThree, gmcn, Black Adder, johncc, SCX358G), 175 guests, and 13 spiders.
+8Rich 128
John V6 118
OZ 4/4 114
8359 Registered Users
Thanks to All.
by kiwi100. 06/06/23 03:17 AM
by Neil49. 06/06/23 12:02 AM
Carpets and Headrests
by C2RM. 05/06/23 08:37 PM
Best Small Camera
by John V6. 05/06/23 10:38 AM
plus 4 GDI not starting Help please
by series1. 04/06/23 08:06 PM
Stay safe out there.
by Alistair. 04/06/23 12:57 PM
O2sensors and cylinder relationship
by thomaslea1. 04/06/23 12:31 PM
Spotted In Amboise Loire
Wiscombe Park
Sod the rain
Forums32
Topics45,158
Posts764,871
Members8,359
Most Online1,033
Dec 28th, 2019
Adrian Bott, itsfrank666, James Nolan
Adjusting side view mirrors, Plus 4 #726878
07/12/21 07:42 PM
07/12/21 07:42 PM
Pa. USA
LarryS Offline OP
LarryS  Offline OP
Pa. USA
Hi: I can’t seem to get the right side mirror on my 20/20 Plus 4 to adjust properly. The correct position does not seem to be possible? It wasn’t correct when I took delivery of the car. Any suggestions? Thanks to those of you who helped me with the clock setting mystery. Thanks, LarryS
Re: Adjusting side view mirrors, Plus 4 [Re: LarryS] #726880
07/12/21 08:12 PM
07/12/21 08:12 PM
France, Dunkerque
gaston Offline
gaston  Offline
France, Dunkerque
Unscrew the screw hidden on the black cover and have someone help you to adjust it while you are seated.
Re: Adjusting side view mirrors, Plus 4 [Re: LarryS] #726885
07/12/21 09:42 PM
07/12/21 09:42 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
Which mirrors do you have?
The lozenge shaped mirrors often supplied from new are very difficult to adjust to give an adequate view. I changed mine to round door mirrors from Librands. These are relatively easy to adjust to give a good field of view.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 5
Re: Adjusting side view mirrors, Plus 4 [Re: LarryS] #726894
08/12/21 06:45 AM
08/12/21 06:45 AM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
You can also try to turn not the mirror, but the whole arm (or leg?) in another position. More inside or more outside.
And yes, it‘s good to have a second person for the adjustment. I undo the the leg and the mirror and fit a chrome and round motorcycle mirror. Works.
Greets René
2018 plus4 (sports green)
Re: Adjusting side view mirrors, Plus 4 [Re: Paul F] #726897
08/12/21 08:53 AM
08/12/21 08:53 AM
Kent
Alan Patterson Offline
Kent
+1.
Regards
Alan
AP08 MOG
Re: Adjusting side view mirrors, Plus 4 [Re: Alan Patterson] #726904
08/12/21 10:20 AM
08/12/21 10:20 AM
norfolk, UK
lowebird Offline
lowebird  Offline
norfolk, UK
+1.
100% improvement, the OME mirrors are pretty poor.
Reg
Re: Adjusting side view mirrors, Plus 4 [Re: lowebird] #726929
08/12/21 03:46 PM
08/12/21 03:46 PM
Derby
PhilRoyle Offline
PhilRoyle  Offline
Derby
+1.
Agree with this - with my OME mirrors I could see the sky, the hedgerows or the road under the car but not where I wanted to see. I got some stainless John Taylor mirrors which are slightly convex and are brilliant. They fit easily into the MMC original holder in the door.
Re: Adjusting side view mirrors, Plus 4 [Re: LarryS] #726930
08/12/21 03:52 PM
08/12/21 03:52 PM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
On my past and present cars I have never found a problem with the original mirrors, but I always have the passenger side one around 1" higher up in adjustment compared to the drivers side also one click further out on the base adjustment patience is rewarded, as suggested earlier an assistant adjusting whilst you watch helps a lot.
Good luck.
Regards Richard
1993 Connaught Green +8 prev
Re: Adjusting side view mirrors, Plus 4 [Re: Alan Patterson] #726958
08/12/21 07:05 PM
08/12/21 07:05 PM
New Forest
Lordofthewings Offline
New Forest
A few months back I had to do some fettling on the round ones fitted on my car, see post #717347. (I sold the rectangular-ish / lozenge-shaped ones that came with the car as spares, as they just seemed so poorly made). There are about ten different planes in which the mirrors and the stalks can be manipulated, and in the case of mine there's a further sort of fine-tuning possible by slackening the little tensioning bolt on the back of the mirror and rotating it 180 degrees around its own axis, which can raise or lower it by a couple more centimetres.
Re: Adjusting side view mirrors, Plus 4 [Re: LarryS] #726998
09/12/21 10:01 AM
09/12/21 10:01 AM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
The factory mirrors are poorly made, and difficult to adjust. There were factory round mirrors available for a while, which were no better.
The aftermarket replacement round mirrors are a massive improvement, in looks, adjustment and rear vision.
(Release build 20190129)
PHP: 7.0.33 Page Time: 0.052s Queries: 15 (0.013s) Memory: 2.5996 MB (Peak: 2.7548 MB) Data Comp: Off Server Time: 2023-06-06 10:10:33 UTC
