0 registered members (),
55
guests, and 12
spiders. |
Sky !
by IcePack. 17/05/22 05:12 PM
Topics43,316
Posts728,760
Members7,932
Most Online1,033 Dec 28th, 2019
Re: Adjusting side view mirrors, Plus 4
[Re: LarryS]
#726885
07/12/21 09:42 PM
07/12/21 09:42 PM
Posts: 4,137 Costock, South Nottinghamshire...
Paul F
Which mirrors do you have? The lozenge shaped mirrors often supplied from new are very difficult to adjust to give an adequate view. I changed mine to round door mirrors from Librands. These are relatively easy to adjust to give a good field of view.
Paul Costock, UK 2014 4/4 Rolls Royce Garnet Red Disco 4 Teddy - 17h1 Irish Draught cross
[Re: LarryS]
#726894
08/12/21 06:45 AM
08/12/21 06:45 AM
Posts: 769 Germany, Rhein-Main Area
xc68anc
You can also try to turn not the mirror, but the whole arm (or leg?) in another position. More inside or more outside.
And yes, it‘s good to have a second person for the adjustment. I undo the the leg and the mirror and fit a chrome and round motorcycle mirror. Works.
Greets René
2018 plus4 (sports green) with a homemade really shiny red tinted dash…
[Re: Paul F]
#726897
08/12/21 08:53 AM
08/12/21 08:53 AM
Posts: 1,875 Kent
Alan Patterson
Kent
Which mirrors do you have? The lozenge shaped mirrors often supplied from new are very difficult to adjust to give an adequate view. I changed mine to round door mirrors from Librands. These are relatively easy to adjust to give a good field of view. +1.
Regards Alan AP08 MOG 2016 Plus 4 GDi - Mazda Soul Red Metallic
[Re: Alan Patterson]
#726904
08/12/21 10:20 AM
08/12/21 10:20 AM
Posts: 5,070 norfolk, UK
lowebird
norfolk, UK
Which mirrors do you have? The lozenge shaped mirrors often supplied from new are very difficult to adjust to give an adequate view. I changed mine to round door mirrors from Librands. These are relatively easy to adjust to give a good field of view. +1. 100% improvement, the OME mirrors are pretty poor.
[Re: lowebird]
#726929
08/12/21 03:46 PM
08/12/21 03:46 PM
Posts: 2,558 Derby
PhilRoyle
Derby
Which mirrors do you have? The lozenge shaped mirrors often supplied from new are very difficult to adjust to give an adequate view. I changed mine to round door mirrors from Librands. These are relatively easy to adjust to give a good field of view. +1. 100% improvement, the OME mirrors are pretty poor. Agree with this - with my OME mirrors I could see the sky, the hedgerows or the road under the car but not where I wanted to see. I got some stainless John Taylor mirrors which are slightly convex and are brilliant. They fit easily into the MMC original holder in the door.
[Re: LarryS]
#726930
08/12/21 03:52 PM
08/12/21 03:52 PM
Posts: 30,239 Devonshire
Devonshire
Hi: I can’t seem to get the right side mirror on my 20/20 Plus 4 to adjust properly. The correct position does not seem to be possible? It wasn’t correct when I took delivery of the car. Any suggestions? Thanks to those of you who helped me with the clock setting mystery. Thanks, LarryS On my past and present cars I have never found a problem with the original mirrors, but I always have the passenger side one around 1" higher up in adjustment compared to the drivers side also one click further out on the base adjustment patience is rewarded, as suggested earlier an assistant adjusting whilst you watch helps a lot. Good luck.
Regards Richard
1999 Indigo Blue +8 2009 4/4 Sport Green prev 1993 Connaught Green +8 prev
[Re: LarryS]
#726998
09/12/21 10:01 AM
09/12/21 10:01 AM
Posts: 20,250 South Yorkshire
South Yorkshire
The factory mirrors are poorly made, and difficult to adjust. There were factory round mirrors available for a while, which were no better.
The aftermarket replacement round mirrors are a massive improvement, in looks, adjustment and rear vision.
