0 registered members (), 181 guests, and 18 spiders.
+8Rich 215
John V6 149
CooperMan 109
OZ 4/4 107
TBM 90
DalesPlusFour, Mark Adams, Ian12345Aero8, kiwi100, Steve_1970
8015 Registered Users
Inauguration of the Morgan Brussel Belgium garage
by nestor59310. 26/06/22 10:07 PM
Sat nav glare
by M3W55. 26/06/22 08:37 PM
Are pressure washers worth it?
by Quicksilver. 26/06/22 06:58 PM
Plus4 Tonneau 1993
by Clive Fishing. 26/06/22 04:16 PM
I Had To Do It....
by Peter J. 26/06/22 12:38 PM
Vredestein t-trac 2 165/80r15
by Montegue. 26/06/22 08:06 AM
Wire Wheels - Chrome to Black Options?
by Montegue. 26/06/22 07:41 AM
Isle of Man Trip June 2022
People of the Isle of Man Trip June 2022
Orkney
New Plus Four config...
MOG414 on MaltaTV part 1 &  2
Topics43,535
Posts732,587
Members8,015
Most Online1,033
Dec 28th, 2019
DaytonaMog
Page 2 of 4 1 2 3 4
Re: Wolf performance remote grease system [Re: Leroy] #730071
13/01/22 07:41 AM
13/01/22 07:41 AM
UK
BuyBritish Offline
BuyBritish  Offline
UK
Remote greasing means you dont need to get down under the wheel arch.... but Craigs car shows he goes down under to keep it so clean?
When greasing the surplus grease exits the various points around the stub axle, roller bearings etc and if you don't go under there then you will have an almighty mess...so I grease while under there and clean up the surplus...so whats the point of the remote greasing?
Rob Davies
Morgan 3 Wheeler 1934 MX
Morgan Series 1 1947
Morgan +4 1956 TR4
Morgan +4 2000 T16 Rov
Re: Wolf performance remote grease system [Re: Leroy] #730075
13/01/22 08:55 AM
13/01/22 08:55 AM
Sanderstead
Tim Crump Offline
Tim Crump  Offline
Sanderstead
I have gone the remote greasing route, so every 2nd tank of fuel I will open the bonnet and pump a few strokes of the grease from my gun into each. Not scientific as I’m not watching for grease to appear, but more the little and often camp.
Tim
Plus 4 2018
Re: Wolf performance remote grease system [Re: Leroy] #730078
13/01/22 09:31 AM
13/01/22 09:31 AM
Lytham St Annes, Lancashire
JohnHarris Offline
JohnHarris  Offline
I'm increasingly less willing to try and get under the car and struggle to use a grease gun with the car on the ground. I'm considering a remote greasing system as a quick wipe off of any excess grease is pretty easy. There may be much merit in the 'little and often' approach of Tim.
2008 Roadster 4 seater FELIX
prev 2006 4/4 70th LOKI
prev 1977 4/4 SEAMUS
prev 1985 4/4 MOLLY
Re: Wolf performance remote grease system [Re: Leroy] #730079
13/01/22 09:46 AM
13/01/22 09:46 AM
Suffolk
John V6 Offline
Brooklands Register contact
John V6  Offline
Suffolk
I found getting the gun on the nipples was the hard part. The remote kit makes that so much easier but you still need to get under the car.
I first put kitchen towel rolled up between the disc & the axle.
Pump grease 6 times into each nipple. I find that gives a small excess of grease consistently.
Clean up stub axles of excess, remove kitchen towel carefully to avoid excess grease on the discs (if any) & spray brake cleaner on discs to be safe.
Spanner check the front of the car & check for damage lose wires etc.
I do that every 1,000 miles
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Wolf performance remote grease system [Re: Craig Jezz] #730081
13/01/22 10:36 AM
13/01/22 10:36 AM
Oxon
Craig Jezz Offline
Craig Jezz  Offline
Oxon
Originally Posted by Craig Jezz
I bought mine from Wolf and they screwed In ok on my 2016. 4/4 with no issues. I purchase the swivel type…
My first attempt I did over tighten the nipple in the thread and snapped it inside, I had to use the extract drill to get it out. I then ordered replacements from Cain which he advised using the swivel type.
Rule of thumb don't over tighten
Craig Jezz
Morgan 4/4 Sports Sand
Re: Wolf performance remote grease system [Re: BuyBritish] #730083
13/01/22 10:41 AM
13/01/22 10:41 AM
Oxon
Craig Jezz Offline
Craig Jezz  Offline
Oxon
Quite agree, I still jack the car up and wipe off any excess grease and clean up underneath. I fitted them during lockdown 2020 as I had nothing else to do grin2
Craig Jezz
Re: Wolf performance remote grease system [Re: Leroy] #730089
13/01/22 12:29 PM
13/01/22 12:29 PM
Wiltshire
RJW Offline
RJW  Offline
Wiltshire
For those of us who do not have remote greasing, is it preferable to have the wheels on the ground when greasing or is it okay to jack up the car so the wheels are off the ground when greasing? Obviously access is easier with wheels off the ground.
Bob.
Re: Wolf performance remote grease system [Re: BuyBritish] #730090
13/01/22 12:33 PM
13/01/22 12:33 PM
South Shields
Leroy Offline OP
Leroy  Offline OP
South Shields
As John V6 has said below, this is my reasoning. As I don't have a trigger type grease gun, it is often really awkward to be underneath the car trying to. Make sure a good seal in the nipple. Much easier from the engine bay, and then a good look under to wipe away any excess. We that's the way its going to be once fitted.
2004 Series 1 Roadster
Re: Wolf performance remote grease system [Re: Leroy] #730091
13/01/22 12:47 PM
13/01/22 12:47 PM
Co Wexford, Ireland
Robbie Offline
Robbie  Offline
Co Wexford, Ireland
When I "invented" the remote greasing kit it was only as a convenience particularly when on away touring, as it meant it could be done easily without getting clothes dirty etc. It does NOT eliminate the need to check fasteners and issues of surplus grease from time to time. I also have a pipe end fitting on the grease gun which when its lever is pressed, opens to grip the nipple , thus eliminating the 'Fight" to get the fitting on and off the nipple - Purchasable on E-Bay for about £15.
Cheers!
Robbie
2021 Plus Four -- Helga
211-WX-1433
Re: Wolf performance remote grease system [Re: RJW] #730092
13/01/22 01:13 PM
13/01/22 01:13 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Bob.
Off the ground for me.
Page 2 of 4 1 2 3 4
