Morgan Aero 8
1 registered members (LightSpeed), 139 guests, and 22 spiders.
+8Rich 190
John V6 135
OZ 4/4 88
TBM 86
Image 79
Rosendahl, Vladimir T, 2949olivier, peter tierney, Tom ff
7771 Registered Users
S1 for sale
by Tvrtastic. 17/01/22 11:14 PM
The usual way to get lost…
by xc68anc. 17/01/22 08:58 PM
Exhaust température
by atalante83. 17/01/22 07:04 PM
Map light, another style
by xc68anc. 17/01/22 06:29 PM
Tool to release tenax hood fasteners
by Jonathan G. 17/01/22 05:06 PM
Brough Superior
by Gambalunga. 17/01/22 03:27 PM
So, you think YOUR roof leaks a little..
by Stringers Best Mate. 16/01/22 11:05 PM
King George VI badge
Ms Marple meets Grandmama!
Sunshine Returns to the North East
MOG414 gear knob
2022 is the year!!!!!
Topics42,691
Posts717,121
Members7,771
Most Online1,033
Dec 28th, 2019
No Birthdays
Draining Fuel #730150
14/01/22 10:15 AM
14/01/22 10:15 AM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Is there any easy way to drain fuel from an Aero tank?
With all the work I have been doing (and on the car) it hasn't been used much since Covid started, so the fuel is 2 years old. No issues with moisture as the car is stored in a dry heated space but I figure if it sits much longer it might be worth draining the old stuff out.
If there isn't.. I know you can get some pump/suction workshop tools for draining fluids, and recommendations for a compact cheapish home solution?
Aero 8 S1
Re: Draining Fuel [Re: NickCW] #730159
14/01/22 10:48 AM
14/01/22 10:48 AM
Oxted
PJC Offline
PJC  Offline
Oxted
Hi Nick, you could try a Jiggle Syphon https://www.amazon.co.uk/Hyfive-Priming-Jiggle-Syphon-Transfer/dp/B00KE0GTPQ/ref=sr_1_4_sspa?crid=2K15TUKB0OSGG&keywords=jiggle+syphon&qid=1642157102&sprefix=jiggle+%2Caps%2C91&sr=8-4-spons&psc=1&smid=A3UZTDMDZ5GUQW&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUEySUFKQlVWRk1CT1ZMJmVuY3J5cHRlZElkPUEwMDA0NTg1REVRR1ozS1VESzdVJmVuY3J5cHRlZEFkSWQ9QTAwMTY5ODVaUDJRUU9HMENVN0gmd2lkZ2V0TmFtZT1zcF9hdGYmYWN0aW9uPWNsaWNrUmVkaXJlY3QmZG9Ob3RMb2dDbGljaz10cnVl
The only thing to consider is having got the fuel out what do you do with it due to all the laws now about safely disposing of hazardous chemicals etc.
If your tank has got space in it then I would suggest that it may be better just to fill it up with Esso or Shell premium fuel with a gerry can so that the old fuel is diluted and mixed with the new fuel and ensure that you then keep topping the car up regularly so that the older fuel is diluted further and further with new quality fuel.
Cheers, Paul
Re: Draining Fuel [Re: NickCW] #730160
14/01/22 10:51 AM
14/01/22 10:51 AM
SimonH Offline
SimonH  Offline
The tanks are foam filled, so sucking out the fuel will be difficult
I'd jump the fuel pump relay, split the fuel line at the connector where it comes up the NS bulkhead, and pump the fuel out using the in tank pump
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Draining Fuel [Re: NickCW] #730161
14/01/22 10:52 AM
14/01/22 10:52 AM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
If you do let the fuel (some/all) go through then try some of the injector cleaner afterwards in case any of it was sticky ?
Once out and running make certain you give it a longer run to get it hot all the way through so it combusts fully and the cats don't suffer. An Italian tune up of sorts.
Just time to bum a little more petrol before dinner.
Re: Draining Fuel [Re: Alistair] #730390
17/01/22 10:51 AM
17/01/22 10:51 AM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
Thanks for that - interesting looking device, never knew they existed!
Thanks Si I didn't realise it was foam filled. Also actually seems like a far simpler option!
Duly noted smile
Any fuel gurus know how long it takes fuel to break down? Its stored in a dry cool space with heating (though its often pointless heating it) so stays around 5/10degrees mostly if that makes any difference (thinking in tank condensation).
Aero 8 S1
Re: Draining Fuel [Re: NickCW] #730405
17/01/22 04:51 PM
17/01/22 04:51 PM
Oxted
PJC Offline
PJC  Offline
Oxted
I certainly had no issues with cars and bikes being left for 6-9 months in the garage and then adding fresh fuel regularly to dilute the old stuff and as Alistair says ensure the first run is long to ensure that everything gets up to full temps for a good period. If you know there is space in the tank then add the new fuel from a can before the first longer run out. Not saying this is ideal - just practical for those of us with less options to dispose of fuel safely. One of the reasons I don't fill ups just before getting home, then if the car of bike is in the garage for longer than expected I can add a good level of new fuel to dilute the old stuff straight away.
This is on the RAC website: Generally speaking, petrol has a shelf-life of six months if stored in a sealed container at 20 degrees – or just three months if kept at 30 degrees. The more it's exposed to heat, the more quickly it will go off. BP say if its in a sealed tank which is at least half full then it can be kept for up to 1 year although they recommend topping with new fuel as soon as possible.
Cheers, Paul
Re: Draining Fuel [Re: NickCW] #730409
17/01/22 05:38 PM
17/01/22 05:38 PM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
What sort of 'problems' are we talking about here? I've occasionally left my 4/4 standing for a few months and all I do is start it up, take it for a good thrash to get everything nice and hot, and then fill it up as normal. The only issue I've ever noticed if it can be called that is that it takes a few extra seconds cranking on the starter to get it fired up, which is in my view a good thing as it gets the oil circulating round the engine.
Re: Draining Fuel [Re: NickCW] #730414
17/01/22 06:03 PM
17/01/22 06:03 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
I was sent this by a friend, who I turn was sent it by a bloke in the petroleum industry:
Originally Posted by Consultant
As for your fuel, the traditional advice for mild steel tanks is to fill with fuel to prevent oxidation occurring but I have never been keen on this because the headspace is not protected and this is where oxidation is likely to occur.
The most important factor is to keep the inside of the tank free from moisture, a flush with nitrogen would be ideal but this is probably not practical. In the winter there is not as much water in the air so it is unlikely to be an issue if the car is kept inside and is a few degrees warmer than the air outside. so my advice is to drain the tank and put some silica-gel in a bag and drop it into the tank on a string to absorb any moisture.
I don't have to tell you that a nearly empty tank is the most dangerous so make sure that there are no static or other ignition sources close by including your clothing.
If you decide to fill with fuel it probably does not matter too much as most fuels contain an antioxidant additive but as I said before this will only protect the wetted part of the tank.
The fuel will need to be changed in the spring to replace the lost light ends and give the old girl a fighting chance of starting.
1972 4/4 4 seater - 3G Morganeer
Too many ratty motorbikes
Re: Draining Fuel [Re: Hamwich] #730421
17/01/22 06:41 PM
17/01/22 06:41 PM
Buckinghamshire
NickCW Offline OP
NickCW  Offline OP
Buckinghamshire
I have heard that mostly it is a loss of octane and some far to technical for me to report degradations that mean it doesn't burn as cleanly or as well.
There are a few youtube tests on it if I recall.
The other issue is if left for long enough it can go quite nasty, however this is usually accompanied by other corrosion in the tank or elsewhere which "fuels" (pun intended) the problem.
For me the car has been used for short trips to the bodyshop and for an mot but other than that its not had a fill up in about 3 years just owing to the fact the tank was pretty much full and its not been burned off.. hence my thoughts around just draining it for the lawn mower tbh.
Aero 8 S1
