Topics43,313
Posts728,690
Members7,932
Most Online1,033 Dec 28th, 2019
Roadster car keys
#730177
14/01/22 02:12 PM
14/01/22 02:12 PM
Posts: 134 Leicestershire UK
stumog
Leicestershire UK
I was wondering if any other Morgan owner has lost your car keys, I have a spare set but I would like another set and I was wondering what is the best way to replace them, could I just walk into a shop and get a set cut or do I have to go to Morgan Cars, I would appreciate and help you can give me, Kind Regards Andy.
Morgan 2009 Roadster Rolls Royce Lush Green 3.0 V6 Audi A4 Advant (some blue colour not botherd)
Re: Roadster car keys
[Re: stumog]
#730183
14/01/22 02:40 PM
14/01/22 02:40 PM
Posts: 20,249 South Yorkshire
South Yorkshire
The key fob contains a transducer for the immobiliser so although you can get a key cut which will fit and turn, it won't start your engine. Start by talking to your dealer unless anyone else knows a way?
[Re: stumog]
#730187
14/01/22 02:47 PM
14/01/22 02:47 PM
Posts: 22,111 Suffolk
Brooklands Register contact
Suffolk
They are Ford keys so maybe a Ford dealer. On my S1 Roadster there was a little transducer you could could extract in the key, by default it could also fall out. The 3.7l doesn't have that, just how it works I don't know. .
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
[Re: stumog]
#730192
14/01/22 03:22 PM
14/01/22 03:22 PM
Posts: 4,137 Costock, South Nottinghamshire...
Paul F
Are you sure the key is Ford?
Freelander rings a bell for the key. They are drilled in the factory to install the immobiliser chip. I believe the immobiliser is Ford.
Paul Costock, UK 2014 4/4 Rolls Royce Garnet Red Disco 4 Teddy - 17h1 Irish Draught cross
[Re: stumog]
#730193
14/01/22 03:27 PM
14/01/22 03:27 PM
Suffolk
Mea Culpa. You could be right as the steering column controls are ex Freelander.
[Re: stumog]
#730194
14/01/22 04:20 PM
14/01/22 04:20 PM
Posts: 138 Yorkshire
Jack & Jill 602
Yorkshire
By co incidence I asked in my local branch of Timpson's this morning about having a transducer key cut for a dally driver. They scanned key and are able to say straight away if they can make a key or not. They need the car present to match to.
They could do a key for a 11 year old Indian car so a Morgan should be no trouble!
Jack 1985 4/4 T/C 4 seater Royal Ivory 2018 Pembleton SuperSport (self built). Siva Edwardian
[Re: stumog]
#730200
14/01/22 05:00 PM
14/01/22 05:00 PM
Posts: 1,253 Sumerset
Rog
Sumerset
If…. your Roadster has a Ford ecu with a PATS immobiliser and you have two original (non clone) keys you may be able to program more immobisier chips using the ECU’s built in functionality. Then if you can find a Landrover key blank and have it cut its just a case of drilling a hole for, or attaching the new chip. This old thread might help.
Roger 2011 Plus 4
[Re: stumog]
#730222
14/01/22 09:55 PM
14/01/22 09:55 PM
Posts: 4,719 Northern Capital of Cool
May be worth a chat with your local Landrover dealer, especially when the parts dept sees it's a Mog parked outside and a bit of a different challenge ?
