1 registered members (LightSpeed), 139 guests, and 22 spiders.
+8Rich 190
John V6 135
OZ 4/4 88
TBM 86
Image 79
Rosendahl, Vladimir T, 2949olivier, peter tierney, Tom ff
7771 Registered Users
S1 for sale
by Tvrtastic. 17/01/22 11:14 PM
The usual way to get lost…
by xc68anc. 17/01/22 08:58 PM
Exhaust température
by atalante83. 17/01/22 07:04 PM
Map light, another style
by xc68anc. 17/01/22 06:29 PM
Tool to release tenax hood fasteners
by Jonathan G. 17/01/22 05:06 PM
Brough Superior
by Gambalunga. 17/01/22 03:27 PM
So, you think YOUR roof leaks a little..
by Stringers Best Mate. 16/01/22 11:05 PM
King George VI badge
Ms Marple meets Grandmama!
Sunshine Returns to the North East
MOG414 gear knob
2022 is the year!!!!!
Topics42,691
Posts717,121
Members7,771
Most Online1,033
Dec 28th, 2019
No Birthdays
Page 3 of 4 1 2 3 4
Re: Wolf performance remote grease system [Re: RJW] #730093
13/01/22 01:14 PM
13/01/22 01:14 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
Originally Posted by RJW
For those of us who do not have remote greasing, is it preferable to have the wheels on the ground when greasing or is it okay to jack up the car so the wheels are off the ground when greasing? Obviously access is easier with wheels off the ground.
Bob.
Any greasing is better than none. However, with the wheels off the ground, more of the king pin is inside the hub, so arguably gets a more direct splash of grease.
I have fitted extenders to my top nipples which makes it really easy to apply a grease gun by simply bending over to access under the top of the wheel arch rather than crawling underneath, as both nipples feed the same grease gallery.
I grease every 500 miles and I only tend to use the wheel arch method when touring, for a quick squirt if I am going to be well over the 500 mark, to save crawling underneath in good clothes.
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: Wolf performance remote grease system [Re: DaveW] #730096
13/01/22 02:11 PM
13/01/22 02:11 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Bob.
Off the ground for me.
I would just echo that it has to be really to allow easy turning of wheels lock to lock to gain access to top nipples.
I now follow Cain's suggestion of an old sock to remove old excess grease from lower part of stub axle followed by a wipe of discs with brake cleaner.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1960 Velocette Venom
Re: Wolf performance remote grease system [Re: Leroy] #730097
13/01/22 02:33 PM
13/01/22 02:33 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
I tend to do mine on the ground, and since I removed the bumpers, access is OK.
However, I'm not a big fan of rolling around in puddles and ice this time of year, so I'm tempted to fit a Wolf kit for the more inclement days that I need to regrease.
1972 4/4 4 seater - 3G Morganeer
Too many ratty motorbikes
Re: Wolf performance remote grease system [Re: Leroy] #730099
13/01/22 04:03 PM
13/01/22 04:03 PM
Llanelli
sospan Offline
sospan  Offline
Llanelli
Off the ground for me. I have a pneumatic grease gun. I use a pry bar to raise the bronze plate on the hub and the grease gun is easier to trigger than a pump one. I watch for grease exiting under the raised plate. Greased at 1000 or nearest.
No signs of kingpin/bush wear after approaching 40k miles since I bought the car. Hard chrome kingpins. I went under the car at MOT with the tester last November.All looking ok but not as sparkly as Craig’s car.
Red Plus8
Re: Wolf performance remote grease system [Re: Leroy] #730107
13/01/22 05:45 PM
13/01/22 05:45 PM
Northern Capital of Cool
CooperMan Offline
CooperMan  Offline
These are my solution to the top nipple access, make it possible to do them without jacking when on a long continental tour
Re: Wolf performance remote grease system [Re: Leroy] #730117
13/01/22 07:10 PM
13/01/22 07:10 PM
Preston, Lancashire
Saxonian Offline
Saxonian  Offline
Preston, Lancashire
Off the ground for me - This makes it a whole lot easier..........
Ian S
2019 Sports Green Morgan Plus 4
2019 Gunmetal Mercedes 220 CLA
Re: Wolf performance remote grease system [Re: Leroy] #730137
14/01/22 08:25 AM
14/01/22 08:25 AM
Lytham St Annes, Lancashire
JohnHarris Offline
JohnHarris  Offline
A lift makes it much more accessible to grease, I just go to Matty at Life's and get him to grease them, the Morgan always needs tinkering/fixing for something, so get Matty to grease at the same time, it takes just a matter of seconds with the car lifted and much less of a struggle with securing the grease gun on the nipple.
2008 Roadster 4 seater FELIX
prev 2006 4/4 70th LOKI
prev 1977 4/4 SEAMUS
prev 1985 4/4 MOLLY
Re: Wolf performance remote grease system [Re: Leroy] #730218
14/01/22 08:00 PM
14/01/22 08:00 PM
South Shields
Leroy Offline OP
Leroy  Offline OP
South Shields
Fitted one side of the system, as took longer than I expected. Having a damper blade really made fitting the lower one really tricky.
2004 Series 1 Roadster
Re: Wolf performance remote grease system [Re: Leroy] #730219
14/01/22 08:44 PM
14/01/22 08:44 PM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
What was the problem (I have blades so forewarned is forearmed!)
Re: Wolf performance remote grease system [Re: TBM] #730224
14/01/22 11:48 PM
14/01/22 11:48 PM
South Shields
Leroy Offline OP
Leroy  Offline OP
South Shields
When screwing in the lower swivel joint in place the nipple, when fully screwed, the top of the joint rubs against the bronze plate. Also very tedious trying to tighten the fitting with an open ended spanner. I had to inch it around a few mm at a time I installed it as seen in Craig jazz's photo as if it pointed upwards, then when the wheel turns, it would rub against the bronze plate as well.
Page 3 of 4 1 2 3 4
