0 registered members (),
185
guests, and 17
spiders. |
Topics43,535
Posts732,587
Members8,015
Most Online1,033 Dec 28th, 2019
Re: Boot plywood deck - soundproofing
[Re: NelsonG]
#731590
29/01/22 11:34 AM
29/01/22 11:34 AM
Posts: 669 New Forest
Lordofthewings
New Forest
Not sure if this is the same stuff, https://www.ebay.co.uk/itm/393779132303 and seems inexpensive. I used a similar but "quilted" product intended to stop resonance (a slightly different phenomenon), which also comes in sheets and as supplied there is sufficient for lining the boot of small convertibles, so should fit the Mog rear deck. ![[Linked Image]](https://www.tm-img.com/images/2022/01/29/Sound-deadening-mat.md.jpg)
Peter 2009 3-litre Roadster "Ivor", royal ivory / green
[Re: Max5]
#731591
29/01/22 11:37 AM
29/01/22 11:37 AM
Posts: 5,121 Llanelli
Ray
Llanelli
The outer surface of Dynamat is a metal foil so I believa that it should be waterproof. . Be careful it can't drop on to the battery terminals, if you have a rear mounted one.
[Re: Ray]
#731630
29/01/22 05:28 PM
29/01/22 05:28 PM
Posts: 4,863 Northern Capital of Cool
The outer surface of Dynamat is a metal foil so I believa that it should be waterproof. . Be careful it can't drop on to the battery terminals, if you have a rear mounted one. Good point that, some of these modern aerosol adhesives are easy to use but seem to loose their bond over the years
[Re: NelsonG]
#731706
30/01/22 05:49 PM
30/01/22 05:49 PM
That lovely smell of Cellulose paint from rattle cans has gone too, I sprayed a panel in the shed a couple of weeks ago with some modern version and two weeks later it still smells like a dead cat in there, goodness knows what the propellant gas is now
