0 registered members (),
202
guests, and 31
spiders. |
Topics43,535
Posts732,587
Members8,015
Most Online1,033 Dec 28th, 2019
Re: Battery isolating switch
[Re: RJW]
#732605
07/02/22 11:17 AM
07/02/22 11:17 AM
Posts: 22,281 Suffolk
Brooklands Register contact
Suffolk
My T16 +4 had exactly that plus power for the clock
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
[Re: RJW]
#732613
07/02/22 12:07 PM
07/02/22 12:07 PM
Posts: 1,106 North Somerset, UK
Deejay
North Somerset, UK
I believe battery isolation switches were primarily fitted to rapidly isolate the battery in the event of fire on a competition car, and hence have a universal key? If I were a professional sports car thief, its the one item I would carry in my pocket!
If theft is the main concern, I would look to installing a simple isolating switch which is wired to prevent the fuel pump from operating. Simple access to intercept the white/pink wire to the inertia switch that is mounted on the near side bulkhead adjacent to the coolant tank, would be a very simple and easy job to do. You could position the switch wherever you like, say under the dash with just a short run of wires.
Doug
2011 +4 in Rich Maroon 1972 750 “ComDom” sprinter 1958 Triton 650 1992 Triumph Trophy 900
[Re: RJW]
#732622
07/02/22 01:41 PM
07/02/22 01:41 PM
Posts: 1,260 Sumerset
Rog
Sumerset
I like Deejay’s fuel pump switch but not so sure about the small fuse with the isolator!
If the car is a Duratec and unless you have fitted one yourself I don’t think it will have an alarm so you would only be powering the immobiliser and keeping the ecu memory alive. IMO the learnt data is not worth much. It’s mainly only the fuel trims and they are soon relearnt. I don’t think you would notice much difference. I swop ecu’s in and out quite often and don’t really notice anything. As for keeping the immobiliser powered on I don’t think that adds much value from a security perspective as it would activate as soon as the car was powered anyway. Regarding isolation when working on the car a small fuse may help prevent a fire but wouldn’t necessarily prevent damage from say an accidental reverse polarity mishap.
Good luck!
Roger 2011 Plus 4
[Re: RJW]
#732623
07/02/22 02:20 PM
07/02/22 02:20 PM
Posts: 147 Yorkshire
Jack & Jill 602
Yorkshire
Bob, I fitted such a switch on my Pembleton (they count as an immobiliser for the MSVA test) however it failed after less than 3 years (easily by-passed). Instead I have fitted a commercial vehicle battery terminal where the cable is attached with a large wing nut - nothing to go wrong! Hopefully Doug's professional car thief does not also carry a wing nut of the correct size!
Jack 1985 4/4 T/C 4 seater Royal Ivory 2018 Pembleton SuperSport (self built). Siva Edwardian
[Re: RJW]
#732625
07/02/22 02:33 PM
07/02/22 02:33 PM
Posts: 300 South Shields
Leroy
South Shields
This may have been covered previously but I can’t find the answer. I would like to install a battery isolating switch on my 2013 Plus 4. The battery is located near the rear axle and the switch will go on the rear bulkhead between the seats. The reason for the installation is partly for a crude security measure against theft and mostly to isolate the battery when working on the car.
My question concerns the lack of power to the alarm and to the ECU when the battery is isolated. Clearly the alarm wouldn’t work and the ECU may lose its “learnt” mode. Is it therefore sensible to bypass the switch with a flyer wire with a fuse of small capacity to retain some power to the alarm and ECU but any attempt to start the car would blow the fuse?
Any advise would be much appreciated. Bob. I have an isolator switch connected to my battery terminal, but my battery is under the bonnet so easily accessible. Not needed really from a security perspective as that's what the immobiliser is for. As others have said, the ecu relearn pretty quickly, and I haven't noticed a difference when mine has been switched off. I don't have a clock to be concerned about and not fussed about retuning radio stations in, as I just press the search button and up pops radio 2 straight away.
2004 Series 1 Roadster
[Re: RJW]
#732633
07/02/22 03:57 PM
07/02/22 03:57 PM
Posts: 449 Oxted
PJC
Oxted
You could install a remote controlled isolation device which also monitors the battery condition and automatically disconnects draw if the voltage is dropping as well as offering some anti-theft protection: https://www.antigravitybatteries-uk.co.uk/battery-protection/powerlock-battery-protector.htmlThere may be other similar things available online at less cost - I just recall seeing this one at a show a while back.
Cheers, Paul
[Re: John V6]
#732672
07/02/22 07:06 PM
07/02/22 07:06 PM
Posts: 453 Begijnendijk, Belgium
DirkM
My T16 +4 had exactly that plus power for the clock +1 In my 1993 T16 +4 the key is located behind the driver seat. ![[Linked Image]](https://live.staticflickr.com/1841/30502698208_0f84cc9f75_b.jpg)
Dirk
1993 Morgan +4 (Connaught Green) 2009 Mini Cooper D 2008 BMW 320d 1994 Ford Motorhome
[Re: RJW]
#732697
07/02/22 11:06 PM
07/02/22 11:06 PM
Posts: 4,027 Essex
Burgundymog
Black Rat
Black Rat
Essex
In the old days we simply took of the distributor cap and removed the rotor arm.
