Mirrors
by Image. 13/08/22 09:06 AM
Topics43,856
Posts738,619
Members8,072
Most Online1,033 Dec 28th, 2019
Fuel Gauge, Wow and Thank you
#732684
07/02/22 09:07 PM
07/02/22 09:07 PM
Posts: 138 San Francisco
RobFog
San Francisco
Took the Morgan out today, first proper drive ever and wow - it felt amazing, I've been waiting for this moment since I first found the car in the barn back in March last year. I wanted to thank everyone who has given me the advice and confidence to get the car to this far - without your help I wouldn't have known where to start.
Taking it to get fuel for the first time it's clear that the fuel gauge isn't working, it hovers at the 1/4 full mark the whole time and I was wondering if somebody could give some pointers as to the logical steps to isolate the issue or where I should look t get replacement parts.
Thank you all again, I hope I can be a net contributor to the site at some point
1974 4/4 2 seater
Re: Fuel Gauge, Wow and Thank you
[Re: RobFog]
#732685
07/02/22 09:15 PM
07/02/22 09:15 PM
Posts: 4,508 Northants, UK
TBM
Northants, UK
Great news!
I'd start with the sender in the tank - take the wire off it. Check you have power coming from it.
Then earth the wire - that should move the gauge needle.
If you have power, and the gauge works, then it's the sender.
1972 4/4 4 seater - 3G Morganeer Too many ratty motorbikes
[Re: RobFog]
#732686
07/02/22 09:18 PM
07/02/22 09:18 PM
TBM
Northants, UK
You can also check the continuity of the wire from the gauge to the sender, and also check the voltage of the wire going to the sender. It should be around 10V, not 12V. There is a voltage stabilizer that provides the feed to the temp gauge and fuel gauge. Is the temp gauge working OK?
[Re: RobFog]
#732689
07/02/22 10:15 PM
07/02/22 10:15 PM
Posts: 22,612 Suffolk
Brooklands Register contact
Suffolk
I would also check the earth. Earths on mogs often fail.
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
[Re: RobFog]
#732696
07/02/22 11:05 PM
07/02/22 11:05 PM
Posts: 8,462 Llanelli
sospan
Llanelli
I am sure MMC use special metals for the earth. Probably from the group in the Periodic Table ....Rare Earths. Apologies but I couldn’t resist ( no pun there either).
Red Plus8
[Re: sospan]
#732711
08/02/22 09:06 AM
08/02/22 09:06 AM
Posts: 2,118 London
MOG 615
London
Very good!
[Re: MOG 615]
#732736
08/02/22 02:07 PM
08/02/22 02:07 PM
Posts: 1,230 Northern Germany
bmgermany
Northern Germany
Very good!  +1
[Re: RobFog]
#732769
08/02/22 09:02 PM
08/02/22 09:02 PM
Posts: 5,088 East Harling, Norfolk UK
TBM's wiring diagram of the instrument voltage regulator reminds me of the need for same. Late 60's and into 70's and beyond, fuel and temperature gauges worked on the bi-metallic principle where an electrical current would heat such a strip of metal which would distort in a manner proportional to the voltage driving the current, so allowing mechanical linkage of strip to gauge pointer. It also gave very damped readings which was an advantage with fuel sloshing around tank. The technology only worked with a constant reference voltage though, which battery charge systems didn't allow, hence need for 10 volt regulator.
It can be seen if regulation fails an erroneous gauge reading will ensue.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
[Re: RichardV6]
#732771
08/02/22 09:18 PM
08/02/22 09:18 PM
TBM
Northants, UK
It can be seen if regulation fails an erroneous gauge reading will ensue. Yep, replaced mine with a solid state regulator - gives me much more accurate temp and fuel readings. Regulator
