15 registered members (SLH, bilibib, OZ 4/4, TBM, RedThree, jrt, JWG, B3MOG, DickJ, JohnMat, Burgundymog, Rog G, Soleng, Eurosystem0, linklaw), 354 guests, and 19 spiders.
+8Rich 291
John V6 200
OZ 4/4 169
CooperMan 150
RichardV6 129
Alford, Mogge77, Kevin McMillen, Corrosion Guy, Supernano
8072 Registered Users
OCTANE issue 231
by xc68anc. 10/08/22 05:44 AM
The Axle Tramps
by +8Rich. 09/08/22 09:21 PM
Squeaking windscreen
by Lordofthewings. 09/08/22 07:25 PM
Ireland Scotland Trip
by Gambalunga. 09/08/22 04:25 PM
Form an orderly queue
by M3W55. 09/08/22 03:11 PM
Commonwealth Games.
by Scrambledsignals. 09/08/22 11:01 AM
Car intercom
by G Walker. 09/08/22 10:22 AM
Big Skies
More from Helmingham
Helmingham Hall Car Show 7.8.22
Aero 8 Series 5
1967 Morgan Plus 4 DHC
Topics43,836
Posts738,147
Members8,072
Most Online1,033
Dec 28th, 2019
No Birthdays
Page 2 of 4 1 2 3 4
Re: Fuel Gauge, Wow and Thank you [Re: RobFog] #732784
09/02/22 05:45 AM
09/02/22 05:45 AM
San Francisco
RobFog Offline OP
RobFog  Offline OP
San Francisco
This site is such an amazing resource - I always come away feeling more educated that when I arrive :-)
1974 4/4 2 seater
Re: Fuel Gauge, Wow and Thank you [Re: TBM] #732812
09/02/22 11:14 AM
09/02/22 11:14 AM
Northern Capital of Cool
CooperMan Offline
CooperMan  Offline
Originally Posted by TBM
. The technology only worked with a constant reference voltage though, which battery charge systems didn't allow, hence need for 10 volt regulator.
It can be seen if regulation fails an erroneous gauge reading will ensue.
Yep, replaced mine with a solid state regulator - gives me much more accurate temp and fuel readings. Regulator
The chap at Spiyda makes some really useful stuff, very helpful too
Re: Fuel Gauge, Wow and Thank you [Re: RobFog] #732835
09/02/22 03:12 PM
09/02/22 03:12 PM
Norfolk
thelastgizmo Offline
Norfolk
Don't forget that if you are measuring the output of the mechanical voltage regulator it won't read 10V but will chop between 0v and battery voltage (12-14V). The fuel and temperature gauge are heavily damped and take an average. The regulator that TBM mentions is easy enough to install as long as you are the size of a 6 year old child!
Re: Fuel Gauge, Wow and Thank you [Re: thelastgizmo] #732866
09/02/22 07:28 PM
09/02/22 07:28 PM
CooperMan Offline
CooperMan  Offline
Yes, with a modern digital voltage tester they are too sensitive, if you have an old analogue jobbie with a nice old fashioned needle you can almost get a better average reading around 10 volts, but it does flicker a bit, by coincidence been testing one today which suddenly decided to work, I can only assume the coil contacts were a bit grotty from standing over winter
Re: Fuel Gauge, Wow and Thank you [Re: thelastgizmo] #732880
09/02/22 09:30 PM
09/02/22 09:30 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
There are other solid state regulators which closer mimic OE.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: Fuel Gauge, Wow and Thank you [Re: RobFog] #733017
11/02/22 08:28 PM
11/02/22 08:28 PM
San Francisco
RobFog Offline OP
RobFog  Offline OP
San Francisco
Thanks for the continued advice from everyone - I used a circuit tester and there is definitely power getting to the fuel tank (the led was flickering, so I'm assuming this is what the flickering from 10v to 0v indicates) - would I find the regulator in close proximity to the petrol gauge.
As the gauge does move (albeit, always to 1/3 full) the uneducated me is going to suggest that it's the sender that needs to be replaced
Got my first ever Morgan Car meet-up tomorrow - so excited !
1974 4/4 2 seater
Re: Fuel Gauge, Wow and Thank you [Re: RobFog] #733018
11/02/22 08:40 PM
11/02/22 08:40 PM
Northants, UK
TBM Online content
TBM  Online Content
Northants, UK
My regulator was on the bulkhead, behind the glovebox, passenger side (RHD car).
1972 4/4 4 seater - 3G Morganeer
Too many ratty motorbikes
Re: Fuel Gauge, Wow and Thank you [Re: RobFog] #733041
12/02/22 11:45 AM
12/02/22 11:45 AM
Norfolk
Norfolk
My regulator ('74 4/4 2 seater) is under the dash pretty much dead centre of the bulkhead. Fixed to the inside upper bolt holding the tool tray to the bulkhead. A multimeter would be a good buy. Tests more than voltage.
Re: Fuel Gauge, Wow and Thank you [Re: RobFog] #733045
12/02/22 12:16 PM
12/02/22 12:16 PM
RichardV6 Offline
RichardV6  Offline
It's the gauge that requires the regulated 10 volts so it will always be located close by.
An old moving coil analogue multimeter is best to assess the output from an OE electro-mechanical regulator.
Re: Fuel Gauge, Wow and Thank you [Re: RobFog] #733049
12/02/22 01:20 PM
12/02/22 01:20 PM
Llanelli
Ray Offline
Ray  Offline
Llanelli
. Dai,. A length of bamboo is a lot more reliable.
hide
Page 2 of 4 1 2 3 4
