12 registered members (BuyBritish, Hamwich, Alistair, DWil23, Ian Wegg, brownbaker, AlyMatt, rv6, xc68anc, PaulV, Alan Patterson, JohnHarris),
351
guests, and 15
spiders. |
Mirrors
by Image. 13/08/22 09:06 AM
Topics43,856
Posts738,621
Members8,072
Most Online1,033 Dec 28th, 2019
Re: Fuel Gauge, Wow and Thank you
[Re: RobFog]
#732784
09/02/22 05:45 AM
09/02/22 05:45 AM
Posts: 138 San Francisco
RobFog
San Francisco
This site is such an amazing resource - I always come away feeling more educated that when I arrive :-)
1974 4/4 2 seater
[Re: TBM]
#732812
09/02/22 11:14 AM
09/02/22 11:14 AM
Posts: 5,088 Northern Capital of Cool
. The technology only worked with a constant reference voltage though, which battery charge systems didn't allow, hence need for 10 volt regulator.
It can be seen if regulation fails an erroneous gauge reading will ensue. Yep, replaced mine with a solid state regulator - gives me much more accurate temp and fuel readings. RegulatorThe chap at Spiyda makes some really useful stuff, very helpful too
[Re: thelastgizmo]
#732866
09/02/22 07:28 PM
09/02/22 07:28 PM
Don't forget that if you are measuring the output of the mechanical voltage regulator it won't read 10V but will chop between 0v and battery voltage (12-14V). The fuel and temperature gauge are heavily damped and take an average. The regulator that TBM mentions is easy enough to install as long as you are the size of a 6 year old child! Yes, with a modern digital voltage tester they are too sensitive, if you have an old analogue jobbie with a nice old fashioned needle you can almost get a better average reading around 10 volts, but it does flicker a bit, by coincidence been testing one today which suddenly decided to work, I can only assume the coil contacts were a bit grotty from standing over winter
[Re: thelastgizmo]
#732880
09/02/22 09:30 PM
09/02/22 09:30 PM
Posts: 5,090 East Harling, Norfolk UK
Don't forget that if you are measuring the output of the mechanical voltage regulator it won't read 10V but will chop between 0v and battery voltage (12-14V). The fuel and temperature gauge are heavily damped and take an average. The regulator that TBM mentions is easy enough to install as long as you are the size of a 6 year old child! There are other solid state regulators which closer mimic OE. ![[Linked Image]](https://i.ebayimg.com/images/g/SykAAOSwxTlZyOrL/s-l1600.jpg)
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
[Re: RobFog]
#733017
11/02/22 08:28 PM
11/02/22 08:28 PM
RobFog
San Francisco
Thanks for the continued advice from everyone - I used a circuit tester and there is definitely power getting to the fuel tank (the led was flickering, so I'm assuming this is what the flickering from 10v to 0v indicates) - would I find the regulator in close proximity to the petrol gauge.
As the gauge does move (albeit, always to 1/3 full) the uneducated me is going to suggest that it's the sender that needs to be replaced
Got my first ever Morgan Car meet-up tomorrow - so excited !
1974 4/4 2 seater
[Re: RobFog]
#733018
11/02/22 08:40 PM
11/02/22 08:40 PM
Posts: 4,508 Northants, UK
TBM
Northants, UK
Got my first ever Morgan Car meet-up tomorrow - so excited ! My regulator was on the bulkhead, behind the glovebox, passenger side (RHD car).
1972 4/4 4 seater - 3G Morganeer Too many ratty motorbikes
[Re: RobFog]
#733045
12/02/22 12:16 PM
12/02/22 12:16 PM
Got my first ever Morgan Car meet-up tomorrow - so excited ! It's the gauge that requires the regulated 10 volts so it will always be located close by. An old moving coil analogue multimeter is best to assess the output from an OE electro-mechanical regulator.
[Re: RobFog]
#733049
12/02/22 01:20 PM
12/02/22 01:20 PM
Posts: 5,121 Llanelli
Ray
Llanelli
Got my first ever Morgan Car meet-up tomorrow - so excited ! . Dai,. A length of bamboo is a lot more reliable.
