0 registered members (),
185
guests, and 17
spiders. |
Topics43,535
Posts732,587
Members8,015
Most Online1,033 Dec 28th, 2019
Fuel pump fuse
#736942
23/03/22 04:00 PM
23/03/22 04:00 PM
Posts: 3 Raleigh, NC USA
Louis
Raleigh, NC USA
Issue with fuel pump, and have replaced with a new Walbro, but now need to run down electrical issues related to the pump. The fuel pump fuse did not blow (was correct amp) and instead melted the fuse block (see picture). anyone know how to remove the wiring from the fuse block? would like to either remove the fuse sockets and clean up the block, or install a separate fuse for the pump. all of this after tracing the electrics looking for any issues, but also looking for suggestions as to where to look. thanks [img] https://docs.google.com/document/d/1OxdjXI5lDZDcJ8SgMSAKWzu24CRS3WiCbzmePoD10Ng/edit?usp=sharing[/img]
Re: Fuel pump fuse
[Re: Louis]
#736961
23/03/22 07:01 PM
23/03/22 07:01 PM
Posts: 4,863 Northern Capital of Cool
Looking at the distortion I wouldn't bother trying to re-use that fuse socket, as it will also have heat damage to the connector / cable below & oxides leading to bad continuity
I would carefully snip out the two wires from below and add in an inline fuse holder on fly leads with soldered connections into the existing wires, plenty of options online that take the same blade fuse as OE, you may even find a holder that clips onto the end of the existing grey base in your photo
Re: Fuel pump fuse
[Re: Louis]
#737163
25/03/22 08:56 PM
25/03/22 08:56 PM
Posts: 1,870 United Kingdom, Lincolnshire
planenut
It is not a common problem, most failures are of the original specification fuel pump, not the power supply. There have been very few (none?) fuel pump failures reported after changing to the Walbro GS342 fuel pump. The Range Rover V8 EFi owners researched the issue with the standard pump pretty well, although I will agree it is vastly over specified for the S&S X-Wedge requirements.
I think your problem is with the fuse box installation and it's poor connectors. Maybe a good idea to break and make the fuse box connectors to ensure good connections? I suppose we have a mentality that M3W's are still "new" cars and shouldn't suffer from problems like corroded electrics, thats for "old" cars, but some are now over 10 years old and have sat in cold damp garages. Not saying that applies to your car Louis but it may to others in the future, you may just have a loose connector.
Re: Fuel pump fuse
[Re: Louis]
#737188
26/03/22 08:27 AM
26/03/22 08:27 AM
Posts: 4,902 East Harling, Norfolk UK
Thanks for the info, and wonder if this isn't a common problem (well, at least more than just the two of us). happened to me with the stock pump, although if the issue is a faulty connection in the fuse block this would melt the connection but not blow the fuse. just odd that we have the exact same symptoms, but in any event, have now solved with a solution just like yours. This is not at all unusual Louis in any electrical circuit high or low voltage, AC or DC. The heat damage occurs due to build up over a significant amount of time often due to the tiniest additional contact resistance allied to constant significant current draw. The power (i 2r) loss that creates heat at this point being proportional to the square of the current! In your situation this won't cause an increase in overall current draw from pump, it might even be a tad less so fuse won't be effected. As an example I had a suitably fused high current DC connection on a boat secured solidly through 15mm plywood by M12 nuts and bolt. This hefty fixing got so hot it charred the wood that supported it!
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
Re: Fuel pump fuse
[Re: Louis]
#737194
26/03/22 10:33 AM
26/03/22 10:33 AM
Posts: 1,669 New River Valley, VA
rcmatt
I suspect you either has some moisture/dirt grim or the fuse wasn't in snug, leading to poor contact. That will lead to heat which will make the contact worse over time until you have a failure. I would take out all your fuses and clean with contact cleaner and reinsert them just for good measure.
