Topics43,595
Posts733,725
Members8,033
Most Online1,033 Dec 28th, 2019
Re: Aero progress.. and a new roof!
[Re: NickCW]
#724172
10/11/21 07:47 AM
10/11/21 07:47 AM
Posts: 461 Oxted
PJC
Oxted
Hi Nick, before you get the car detailed you should consider whether you want full PPF or just at the front with a ceramic/glass coating for the rest as it often best to have the car detailed at the same place that will apply the PPF / glass coating and therefore if you are going to have a mixture of both it'd be best to find somewhere that does both. For example REEP in Dunsfold, near Guildford offer a PPF service (which I have used and they are highly recommended) and are also main agents for G-Techniq and can apply their full range of ceramic coatings. Be careful with the very long-lasting ones as they can only be removed by full sanding which will mean a re-spray so excellent unless you get any body repairs required. Alternatively buy some auto-clay and a Rupes Big Foot to do the detailing yourself (very easy, the main skill is simply "Time") and then apply a ceramic coat such as Polish Angel - really easy to apply, takes about an hour and last for 24-36 months - just need to keep the car in the garage for 24hours for the coating to properly cure.
Cheers, Paul
[Re: NickCW]
#724203
10/11/21 12:19 PM
10/11/21 12:19 PM
Posts: 1,835 Buckinghamshire
NickCW
Buckinghamshire
Thanks Paul, I am only going for a few high impact areas (and full front) as the cost just makes it unpalatable. I did want the same place to do everything but the good places that do PPF often don't do the coating and so on, and the ones that do both just were not competitive on the PPF to make it viable.
I do have a Megs G2220 DA, but time and wanting it to be done perfect means I will probably farm it out.
The coatings I have been looking at are minimum 5 year guarentee, with self-healing properties - apparently no issue for bodywork according to the bodyshop I spoke to as they said you just treat it as per any normal paint. I am actually having this applied to our Land Rover to help protect it as its black, so if its really good I will likely use the same one on the Aero. But it will be a faff having to ship it around..
Aero 8 S1
[Re: NickCW]
#724212
10/11/21 02:40 PM
10/11/21 02:40 PM
Posts: 9,421 Hampshire
Alistair
Smile, it confuses them
Hampshire
I believe our S2 has the factory fitted PPF kit.
Bits covered Over the cowl Running boards Lower bumper edge to edge Front of front wings up quite high Mirror backs Around door handles Lower part of front face of rear wheel arches
If that helps.
Lower part rear wheel arches have seen several marks so they have definitely paid for themselves. Mirrors have also seen extensive action.
Getting the heel scuffs off the running boards is a pain but proves their use!
Just time to rent a thimble more petrol before dinner.
[Re: Alistair]
#724678
14/11/21 08:49 PM
14/11/21 08:49 PM
NickCW
Buckinghamshire
If that helps.
Getting the heel scuffs off the running boards is a pain but proves their use! Thanks Alistair, I hadn’t thought about wing mirror backs or the handles. The rest is pretty much the same except I want the full front end done.
Aero 8 S1
