10 registered members (JMT, Fuel.inj, Dougie, M3W55, Perry_P_M3W, BobtheTrain, IcePack, bilibib, TBM, DJC), 371 guests, and 23 spiders.
+8Rich 291
John V6 199
OZ 4/4 168
CooperMan 150
RichardV6 129
Alford, Mogge77, Kevin McMillen, Corrosion Guy, Supernano
8072 Registered Users
OCTANE issue 231
by xc68anc. 10/08/22 05:44 AM
The Axle Tramps
by +8Rich. 09/08/22 09:21 PM
Squeaking windscreen
by Lordofthewings. 09/08/22 07:25 PM
Ireland Scotland Trip
by Gambalunga. 09/08/22 04:25 PM
Form an orderly queue
by M3W55. 09/08/22 03:11 PM
Commonwealth Games.
by Scrambledsignals. 09/08/22 11:01 AM
Car intercom
by G Walker. 09/08/22 10:22 AM
Big Skies
More from Helmingham
Helmingham Hall Car Show 7.8.22
Aero 8 Series 5
1967 Morgan Plus 4 DHC
Topics43,836
Posts738,145
Members8,072
Most Online1,033
Dec 28th, 2019
No Birthdays
Immobiliser disable help please #739223
17/04/22 03:15 PM
17/04/22 03:15 PM
Cheshire, UK
nippymog Offline OP
nippymog  Offline OP
Cheshire, UK
After my immobiliser fob dying today I would like to remove / disable my immobiliser, or have the capability to do this on the road.
This is my original 2013 fob so it has lasted best part of 9 years, not too bad, but when you dont have your spare with you its game over !
Luckily it failed a short distance from home so I was able to get to my spare and get home with out doing anything drastic.
I seem to remember many years ago on TM a thread about this , how disable the immobiliser using a plug supplied by Morgan ?
I have googled TM and used the TM search facility with nothing directly on this that I can see, except a reference in the Club Parts List to a diagram in the Morgan Parts Book page 69 about an immobiliser socket, which just has a diagram of the wiring loom and an immobiliser connector C33 on the loom and another socket C47 not connected to the loom labelled immobiliser connection lead. I am guessing this is the Morgan socket ? From the diagram it look like C47 has all pins connected ?
Question - Anyone know how I can get hold of one of these sockets, or make one , and roughly physically where is socket C33 ?
Thanks
Re: Immobiliser disable help please [Re: nippymog] #739230
17/04/22 04:51 PM
17/04/22 04:51 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
anything that can immobilize you eventually will and usually not at a time of your choosing. So I guess the devices worked, kudos to MMC.
Good luck getting it back into working order.
Re: Immobiliser disable help please [Re: nippymog] #739234
17/04/22 05:03 PM
17/04/22 05:03 PM
exagone
GLLOQ Offline
GLLOQ  Offline
exagone
[Linked Image][url=https://zupimages.net/viewer.php?id=22/15/zvp4.jpg][im
Re: Immobiliser disable help please [Re: nippymog] #739235
17/04/22 05:04 PM
17/04/22 05:04 PM
exagone
GLLOQ Offline
GLLOQ  Offline
exagone
Re: Immobiliser disable help please [Re: nippymog] #739236
17/04/22 05:04 PM
17/04/22 05:04 PM
exagone
GLLOQ Offline
GLLOQ  Offline
exagone
Re: Immobiliser disable help please [Re: nippymog] #739238
17/04/22 05:16 PM
17/04/22 05:16 PM
Near Windsor Berkshire
Rog G Offline
Rog G  Offline
The plug can be bought here
https://uk.rs-online.com/web/p/wire-housings-plugs/3629193
You also need the appropriate pins and then wire as per the instructions in the wiring diagram. The mating connector is also white and behind the dash somewhere near the middle.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Re: Immobiliser disable help please [Re: nippymog] #739252
17/04/22 06:54 PM
17/04/22 06:54 PM
Cheshire, UK
nippymog Offline OP
nippymog  Offline OP
Cheshire, UK
Thanks guys
I have bought the connector, but not sure of the pin connection needed on the connector.
The Morgan diagram seems to have all pins shorted together, GLLOQ's has specific pins wired together, is there a definitive answer please?
Thanks
Re: Immobiliser disable help please [Re: nippymog] #739264
17/04/22 08:10 PM
17/04/22 08:10 PM
Leicestershire, UK
Bunny Offline
Bunny  Offline
Leicestershire, UK
This taken from the M3W Parts Book.
Andy
Re: Immobiliser disable help please [Re: nippymog] #739269
17/04/22 08:37 PM
17/04/22 08:37 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Originally Posted by nippymog
Thanks guys
Thanks
This is the shorting plug schematic factory fitted when optional immobiliser not spec'd.
As can be seen if provides four loops identified by wires of the same code. These complete each leg of start circuit and coil circuit which presumably the immobiliser (when fitted) inhibits until cancelled by fob.
If you look carefully at the last image GLLOQ posted, the above not surprisingly, ties in perfectly.
ETA: Andy beat me too it wink
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: Immobiliser disable help please [Re: nippymog] #739276
17/04/22 10:56 PM
17/04/22 10:56 PM
Cheshire, UK
nippymog Offline OP
nippymog  Offline OP
Cheshire, UK
Many thanks Andy , Richard.
Spot on.
