13 registered members (Brian G, James B W, C2RM, Tresco, Tonyh157, Craig Jezz, DJC, Alpha1, TBM, chanteclair, GARYMYNARD, Malcolm T, Gordon D),
52
guests, and 19
spiders. |
Topics43,836
Posts738,156
Members8,072
Most Online1,033 Dec 28th, 2019
Immobiliser disable help please
#739223
17/04/22 03:15 PM
17/04/22 03:15 PM
Posts: 1,527 Cheshire, UK
nippymog
Cheshire, UK
After my immobiliser fob dying today I would like to remove / disable my immobiliser, or have the capability to do this on the road. This is my original 2013 fob so it has lasted best part of 9 years, not too bad, but when you dont have your spare with you its game over ! Luckily it failed a short distance from home so I was able to get to my spare and get home with out doing anything drastic.
I seem to remember many years ago on TM a thread about this , how disable the immobiliser using a plug supplied by Morgan ? I have googled TM and used the TM search facility with nothing directly on this that I can see, except a reference in the Club Parts List to a diagram in the Morgan Parts Book page 69 about an immobiliser socket, which just has a diagram of the wiring loom and an immobiliser connector C33 on the loom and another socket C47 not connected to the loom labelled immobiliser connection lead. I am guessing this is the Morgan socket ? From the diagram it look like C47 has all pins connected ?
Question - Anyone know how I can get hold of one of these sockets, or make one , and roughly physically where is socket C33 ?
Thanks
Re: Immobiliser disable help please
[Re: nippymog]
#739236
17/04/22 05:04 PM
17/04/22 05:04 PM
Posts: 629 exagone
GLLOQ
exagone
[Re: nippymog]
#739269
17/04/22 08:37 PM
17/04/22 08:37 PM
Posts: 5,068 East Harling, Norfolk UK
Thanks guys
I have bought the connector, but not sure of the pin connection needed on the connector. The Morgan diagram seems to have all pins shorted together, GLLOQ's has specific pins wired together, is there a definitive answer please?
Thanks This is the shorting plug schematic factory fitted when optional immobiliser not spec'd. ![[Linked Image]](https://i.imgur.com/0DJTdm0.jpeg) As can be seen if provides four loops identified by wires of the same code. These complete each leg of start circuit and coil circuit which presumably the immobiliser (when fitted) inhibits until cancelled by fob. If you look carefully at the last image GLLOQ posted, the above not surprisingly, ties in perfectly. ETA: Andy beat me too it
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
