12 registered members (Craig Jezz, +8Rich, Brian G, James B W, C2RM, Tresco, Tonyh157, DJC, Alpha1, TBM, chanteclair, GARYMYNARD), 64 guests, and 21 spiders.
+8Rich 290
John V6 200
OZ 4/4 162
CooperMan 152
RichardV6 129
Alford, Mogge77, Kevin McMillen, Corrosion Guy, Supernano
8072 Registered Users
OCTANE issue 231
by xc68anc. 10/08/22 05:44 AM
The Axle Tramps
by +8Rich. 09/08/22 09:21 PM
Squeaking windscreen
by Lordofthewings. 09/08/22 07:25 PM
Ireland Scotland Trip
by Gambalunga. 09/08/22 04:25 PM
Form an orderly queue
by M3W55. 09/08/22 03:11 PM
Commonwealth Games.
by Scrambledsignals. 09/08/22 11:01 AM
Car intercom
by G Walker. 09/08/22 10:22 AM
Big Skies
More from Helmingham
Helmingham Hall Car Show 7.8.22
Aero 8 Series 5
1967 Morgan Plus 4 DHC
Topics43,836
Posts738,157
Members8,072
Most Online1,033
Dec 28th, 2019
No Birthdays
Speed ​​sensor #739340
18/04/22 06:55 PM
18/04/22 06:55 PM
exagone
GLLOQ Offline OP
GLLOQ  Offline OP
exagone
My speedometer had been working sporadically for years and no longer worked after three repairs to the sensor harness, so I ordered a sensor from China and on a $12 promotion to try to repair it, I was billed $150 the last time in Malvern. So I ordered with aliexpress a sensor for HD with Delphi direct plug it also comes with cable harness and Deutsch three-pin connector, the original sensor is wired with a 1w - 2k ohm resistor perhaps to lower the strength of the signal. The problem that I may encounter again is pain on the side of my stomach caused by my wife who nudges me while watching the speedometer as I drive, the last time she did not dare on the highway because she not sure what 6200rpm is in fifth gear when accelerating.
https://fr.aliexpress.com/item/1005...=a2g0o.order_list.0.0.6f245e5bTdmq6C_the center distance and the diameter may be smaller, the length is identical, which is why I rebuilt a support, it is possible to fix it in the same place by drilling another tapped hole.
.[Linked Image]
Re: Speed ​​sensor [Re: GLLOQ] #739350
18/04/22 07:41 PM
18/04/22 07:41 PM
Taffmog Offline
Taffmog  Offline
Thanks for that !
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Re: Speed ​​sensor [Re: GLLOQ] #739362
18/04/22 09:45 PM
18/04/22 09:45 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Good one for the Alternate Parts List. Thank you.
Re: Speed ​​sensor [Re: GLLOQ] #739363
18/04/22 09:46 PM
18/04/22 09:46 PM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
Great info GLLOQ , many thanks
Re: Speed ​​sensor [Re: GLLOQ] #739369
19/04/22 03:42 AM
19/04/22 03:42 AM
London uk
rockabilly john Offline
London uk
What type of air filter are you using. Looks a simple solution.
Re: Speed ​​sensor [Re: GLLOQ] #739375
19/04/22 07:00 AM
19/04/22 07:00 AM
exagone
GLLOQ Offline OP
GLLOQ  Offline OP
exagone
With my sensor, you have to choose the black three-way Delphi connector.
to mount the air filter, the part must be made to measure.
have-your-driven-you-m3w-today-stories?/page 220
