My speedometer had been working sporadically for years and no longer worked after three repairs to the sensor harness, so I ordered a sensor from China and on a $12 promotion to try to repair it, I was billed $150 the last time in Malvern. So I ordered with aliexpress a sensor for HD with Delphi direct plug it also comes with cable harness and Deutsch three-pin connector, the original sensor is wired with a 1w - 2k ohm resistor perhaps to lower the strength of the signal. The problem that I may encounter again is pain on the side of my stomach caused by my wife who nudges me while watching the speedometer as I drive, the last time she did not dare on the highway because she not sure what 6200rpm is in fifth gear when accelerating. https://fr.aliexpress.com/item/1005...=a2g0o.order_list.0.0.6f245e5bTdmq6C_the center distance and the diameter may be smaller, the length is identical, which is why I rebuilt a support, it is possible to fix it in the same place by drilling another tapped hole. .
