5 registered members (HeadlessBlue, Robbie, SLH, RichardV6, Rainer Duell), 111 guests, and 22 spiders.
+8Rich 301
John V6 194
OZ 4/4 170
CooperMan 165
RichardV6 140
Alford, Mogge77, Kevin McMillen, Corrosion Guy, Supernano
8072 Registered Users
Seen at the factory
by Saxonian. 17/08/22 07:16 AM
Seen at the factory
by Saxonian. 17/08/22 06:30 AM
Altenator replacement for 4/4 Ford CVH?
by TimB. 16/08/22 04:31 PM
Speedometer Calibration
by 1854sailor. 16/08/22 01:31 AM
Upper intake manifold gasket
by Leroy. 15/08/22 04:16 PM
Removing scuffs to the rear perspex window
by Quicksilver. 15/08/22 01:36 PM
4/4 75th Anniversary
Around the Cairngorms
Big Skies
More from Helmingham
Helmingham Hall Car Show 7.8.22
Topics43,876
Posts739,032
Members8,072
Most Online1,033
Dec 28th, 2019
DougM
Page 2 of 4 1 2 3 4
Re: Radiator fix [Re: John V6] #739574
20/04/22 04:17 PM
20/04/22 04:17 PM
SimonH Offline
SimonH  Offline
The revised radiator mounting, along with the lower pressure cap, and reduced coolant level has not prevented any further radiator failures
I’ve been contacted by a dealer , who having fitted a third replacement radiator on a Plus Six in year, had the third radiator last less than 80 miles….
I’ll be working on a solution soon….
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Radiator fix [Re: John V6] #740484
29/04/22 06:27 PM
29/04/22 06:27 PM
Pamo Offline
Pamo  Offline
I changed my leaky radiator
With replacement, new cap and 50% full fluid
I have done 2500 kms since, without problem ... for the moment ...
Fun is not a straight line ...
Re: Radiator fix [Re: SimonH] #740538
30/04/22 11:00 AM
30/04/22 11:00 AM
East Harling, Norfolk UK
RichardV6 Online NoMood
Not a minute too soon by the sound of it Simon. You will have a strong market for such I'm sure.
FWIW it's taken me a couple of months and a 1000 miles to completely cure minor hose leaks on my Roadster which despite nipping up hose clips when hot, kept re-appearing and in differing locations including T piece, top and bottom hose. Finally cured by extra hose clips on the lower two of bottom hose connections and ensuring coolant filled to no higher than mid mark on header tank.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: Radiator fix [Re: John V6] #740539
30/04/22 11:09 AM
30/04/22 11:09 AM
Suffolk
John V6 Offline OP
Brooklands Register contact
John V6  Offline OP
Suffolk
Lets hope so Richard I know Hawki's new to him plus four has had 4 rads in 18 months.
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Radiator fix [Re: John V6] #742868
26/05/22 07:34 AM
26/05/22 07:34 AM
Gonze Offline
Gonze  Offline
I had a major leak on my radiator which was very efficiently replaced by Adam at MelvynRutter (under warranty) - this seems to have fixed the leaking.
To answer John V6’s question about the engine coolant cap being changed - attached are some photos - the original cap has a red “Stant” printed on it, the new cap has no such printed text. When the cap is replaced the header tank is drained and refilled with 500ml of coolant (and a sticker applied to the side of the tank).
No idea if these two things will permanently fix the radiator blowing again, but I hope they will!
Old cap as installed (note there is a second similar tank and cap, just visible under hood - that is the aircon coolant):
New cap:
New cap and sticker installed:
Re: Radiator fix [Re: John V6] #742870
26/05/22 08:10 AM
26/05/22 08:10 AM
tervuren belgium
thierry242 Offline
thierry242  Offline
tervuren belgium
Strangely , after i had again a leak with le third radiator and the new cap , no drops on the garage floor even i have made two times 350 km .
Re: Radiator fix [Re: Gonze] #742877
26/05/22 08:53 AM
26/05/22 08:53 AM
SimonH Offline
SimonH  Offline
New cap:
The second tank is for the chargecooler not aircon
Simon @ Sifab.co.uk
Re: Radiator fix [Re: John V6] #742878
26/05/22 08:59 AM
26/05/22 08:59 AM
New Forest
Lordofthewings Offline
New Forest
I'm intrigued by this discussion (although I don't have a problem with my Roadster radiator as far as I know), because I have previously owned TVRs which featured a "swirl tank" (or "swirl pot"). This article explains: https://www.merlinmotorsport.co.uk/...system-header-tanks-in-your-race-car-323
I recall there was some discussion among TVR owners as to which of the caps should be "pressure relief" type, and which simply plain. In my last TVR, an S3, also with a Ford V6 (2.9) engine, I had a swirl pot with a pressure-cap above the thermostat. The overflow just had a cap, as the level never reached more than about half. This is probably all basic stuff for somebody who knows more than me about Morgan cooling systems, and will probably be able to explain which of our cars if any have swirl pots.
Re: Radiator fix [Re: CooperMan] #742884
26/05/22 09:34 AM
26/05/22 09:34 AM
Originally Posted by +8Rich
Yes Jon, that's what these boys said as per dealers advise..
So, as I see it a WET system that becomes hydraulically locked by it's OE design...and blows things apart... doh
I don't see it as a hydraulic lock situation Jon. The coolant vapour pressure above the level in the header tank reflects back through the incompressible coolant to pressurise the radiator. Increasing this vapour volume with lower coolant level and futher controling it's pressure with release cap was supposedly the radiator fix. I understand CX rads have still failed after this though thinking
Re: Radiator fix [Re: John V6] #742908
26/05/22 03:04 PM
26/05/22 03:04 PM
France, Dunkerque
gaston Offline
gaston  Offline
France, Dunkerque
I wonder if it is not a quality problem of the radiators. Mine at 12,000 km.
We changed the cap and checked the level at 8000 KM. We drove around Spain with a temperature of 35°C and not a drop under the car.
Uneven manufacturing quality may be the explanation.
Page 2 of 4 1 2 3 4
