Morgan Aero 8
10 registered members (MarioCP, DickJ, Heinz, M3W55, Socalm3w, teknome, mph, Craig Jezz, bmgermany, David_E), 63 guests, and 11 spiders.
+8Rich 228
John V6 180
Image 128
OZ 4/4 119
CooperMan 113
Mikemog6, John Fell, RevD, Beat-Chris, 1854sailor
8033 Registered Users
Tesla - Switch Off?
by Budster. 06/07/22 04:12 PM
Gear Shift Knob
by 1854sailor. 06/07/22 11:53 AM
Kingswear Castle PS rebuild progress
by +8Rich. 05/07/22 10:04 PM
Miscellany cover pic
by Luddite. 05/07/22 08:25 PM
Corroded Side Light Screws
by Budster. 05/07/22 06:07 PM
Great service on Morris oils
by RichardV6. 05/07/22 02:49 PM
1973 +8, exhaust fumes in cabin
by Sensei. 04/07/22 08:18 PM
We call her "Little Red"
2021 M3W Torn Boot
RP-Kestrel_Homebuilt prototype aircraft_PART 2
RP-Kestrel_Homebuilt prototype aircraft_PART 1
Isle of Man Trip June 2022
Topics43,595
Posts733,723
Members8,033
Most Online1,033
Dec 28th, 2019
RonB
Re: Off to HQ [Re: Neilda] #740176
26/04/22 01:33 PM
26/04/22 01:33 PM
TheCustomer Offline
TheCustomer  Offline
On mine I put the nozzle in 180 to where you'd naturally place it, and it fills fine.
If I remember rightly it's what the handbook recommends. I'm not sure if I'm more surprised to have read the handbook, or that Morgan reckon it's fine for owners to workaround a problem that the manufacturer should fix?
Anyhoo, Neilda, it sounds like your problem was much worse than it should've been
Will
Aero 8 S5
BMW i8 Coupe
Triumph Stag '72
Re: Off to HQ [Re: Neilda] #740197
26/04/22 04:03 PM
26/04/22 04:03 PM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
"I'm not sure if I'm more surprised to have read the handbook, or that Morgan reckon it's fine for owners to workaround a problem that the manufacturer should fix?"
LOL, for those of you with the traditional version of English that means laugh out loud. thumbs
Just time to rent a thimble more petrol before dinner.
Re: Off to HQ [Re: Neilda] #740239
27/04/22 07:01 AM
27/04/22 07:01 AM
Surrey. UK
Neilda Offline OP
Neilda  Offline OP
Surrey. UK
I have tried every position of nozzle insertion angle and have tried twisting the internal holes to every position.
I wondered if fitting another fuel filler cap might help - to have it also open whilst filling. But this would be a very costly 'fix'.
Anyhoo, hopefully MMC can fix this issue before my jaunt to the Med in June.
+8 4.8
Re: Off to HQ [Re: Neilda] #740264
27/04/22 10:22 AM
27/04/22 10:22 AM
Oxted
PJC Offline
PJC  Offline
Oxted
I find this really odd as the last time I filled up it took me almost 1min per litre, trying the nozzle in every possible angle 45 degrees at a time, half in - half out etc and yet on previous occasions no such issues. I wonder if to is particular fuel stations as the one I used most recently I've not used before and therefore potential different petrol pumps have different flow rates and/or different cut-off sensor sensitivity, maybe?
Cheers, Paul
Re: Off to HQ [Re: Neilda] #740276
27/04/22 11:47 AM
27/04/22 11:47 AM
Hampshire
Alistair Offline
Alistair  Offline
Hampshire
I asked a local garage owner about that when I was having a problem. He said that the pump maintenance people he uses (along with most garages) have a standard setting they aim for which is determined by the pump type in the unit and petrol or diesel going through.
Re: Off to HQ [Re: Neilda] #740513
30/04/22 12:40 AM
30/04/22 12:40 AM
Taffmog Offline
Taffmog  Offline
This problem seems peculiar to the Aluminium chassis Plus 8, it's really is frustrating. Mine was sorted at the Factory under warranty and has been fine since but, sorry I don't know the cure. As I said previously I can't understand why the 'fix' hasn't been released to the dealers. It's a case of rerouting or modifying pipes and less than a 2 hour job. Aero owners complain of a similar problem but it's nowhere as bad as the Plus 8. My S1 suffers from it to a lesser extent but holding the nozzle at 12 o'clock seems to solve it.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
Re: Off to HQ [Re: Neilda] #740517
30/04/22 06:38 AM
30/04/22 06:38 AM
Surrey. UK
Neilda Offline OP
Neilda  Offline OP
Surrey. UK
I have yet to test the car at the petrol pumps - however the factory fix detailed on the invoice contained the following parts:
Machine Shop Supply Fuel Adapter.
Tank Rubber Gasket
Petrol Hose 1/2 Inch Bore
Petrol Cap Side Vent 12mm
One interesting note is that the factory mentioned not 'topping off' when filling. In other words, once the pump has clicked off, don't be tempted to try and trickle more fuel in - apparently this additional fuel makes its way to the charcoal canister thing.
I assume it's fixed it - I will know when I am next at the pump!
+8 4.8
Re: Off to HQ [Re: Neilda] #740525
30/04/22 08:26 AM
30/04/22 08:26 AM
Cheltenham, Glos. UK
Graham, G4FUJ Offline
Thought that might have returned to you. Saw it being loaded into the trailer yesterday morning. Hope the fix is satisfactory.
And yes, the "no trickle fill" applies to just about all modern petrol cars.
D8921 L44FOR '93 4/4 Giallo Fly 2 seat smile
'09 Alfa Romeo MiTo
Re: Off to HQ [Re: Neilda] #741131
06/05/22 01:56 PM
06/05/22 01:56 PM
Surrey. UK
Neilda Offline OP
Neilda  Offline OP
Surrey. UK
First drive out today and first visit to the petrol pump. It's fixed! It fills just like any other car - nozzle right in, squeeze as hard as you like. Fantastic - I'm delighted as it was the only real negative I had about the car. I dreaded filling it. Thank you MMC. smile
+8 4.8
Re: Off to HQ [Re: Neilda] #741137
06/05/22 02:25 PM
06/05/22 02:25 PM
Salisbury, UK
Peter J Offline
Formerly known as Aldermog
Peter J  Offline
Salisbury, UK
That sounds like a WIN!!
Power Corrupts.....
Tarka the 'Otter Mog....2014 Plus 8
Tesla Model 3 AWD.
