Morgan Aero 8
5 registered members (ChrisConvertible, IMHO, Heinz, James B W, Jack & Jill 602), 104 guests, and 13 spiders.
+8Rich 226
John V6 180
Image 129
OZ 4/4 119
CooperMan 113
Mikemog6, John Fell, RevD, Beat-Chris, 1854sailor
8033 Registered Users
Tesla - Switch Off?
by Budster. 06/07/22 04:12 PM
Gear Shift Knob
by 1854sailor. 06/07/22 11:53 AM
Kingswear Castle PS rebuild progress
by +8Rich. 05/07/22 10:04 PM
Miscellany cover pic
by Luddite. 05/07/22 08:25 PM
Corroded Side Light Screws
by Budster. 05/07/22 06:07 PM
Great service on Morris oils
by RichardV6. 05/07/22 02:49 PM
1973 +8, exhaust fumes in cabin
by Sensei. 04/07/22 08:18 PM
We call her "Little Red"
2021 M3W Torn Boot
RP-Kestrel_Homebuilt prototype aircraft_PART 2
RP-Kestrel_Homebuilt prototype aircraft_PART 1
Isle of Man Trip June 2022
Topics43,595
Posts733,725
Members8,033
Most Online1,033
Dec 28th, 2019
RonB
Page 2 of 9 1 2 3 4 5 6 7 8 9
Re: More Lost Electrons [Re: Peter J] #740985
05/05/22 06:04 AM
05/05/22 06:04 AM
Oxted
PJC Offline
PJC  Offline
Oxted
Richard - that makes a lot of sense, I spent a lot of time wiggling a lot of wire only for the window issue to disappear for several months and only two weeks after putting all the door panels back on (no more wiggling) and the window fuse fails again! Maybe a stripped out, even lighter, Aero is the way to go!
Cheers, Paul
Re: More Lost Electrons [Re: Peter J] #740995
05/05/22 07:04 AM
05/05/22 07:04 AM
Berkshire/Oxon & Devon
JB62 Offline
JB62  Offline
My lights regularly show the “ bulb failure” icon. I check the lights- and all seem to be ok? A weird one is when, on start up, the telltale for full beam lights up. 10 mins later, the telltale fails when on full beam? Full beam is fine.
Occasionally, the headlights don’t work- so having been in IT for years. I use the standard “stop- turn it off- take the key out- count to ten” fix. And it mainly fires up.
Hopefully I will be showing the car at The Stonor Supercar and Classic show later in the month. I’ll have to get it cleaned though!!
V8 Speedster ( current)
4/4 Competition spec (5 years)
4/4 4str Kent ( 10 years)
Re: More Lost Electrons [Re: asbojohn] #741010
05/05/22 08:57 AM
05/05/22 08:57 AM
TheCustomer Offline
TheCustomer  Offline
Originally Posted by asbojohn
Got mine back from a factory service a couple of weeks back. Similar issue with the lights that now seems to have been fixed.
ah, is that Peter's rear lights issue, or my flickering headlamps issue?!
Will
Aero 8 S5
BMW i8 Coupe
Triumph Stag '72
Re: More Lost Electrons [Re: Peter J] #741011
05/05/22 09:00 AM
05/05/22 09:00 AM
TheCustomer Offline
TheCustomer  Offline
oh, and... if I don't keep the screenwash topped up I get an orange engine warning light
(only on a Morgan!)
Will
Aero 8 S5
BMW i8 Coupe
Triumph Stag '72
Re: More Lost Electrons [Re: Peter J] #741017
05/05/22 09:24 AM
05/05/22 09:24 AM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
Will
In the earlier cars the screen wash tubes up near the squirters and behind the dash used to be a casual fit. Often they would come loose and water would be able to just leak out behind the dash. The usual introduction of a LUCAS quality experience would then occur with random lights/switches. I did also get a comment that removal and re-installation of the dash with all the tight cabling can disturb it and slack them off. It might be worth getting a small person and dangling them upside down in the footwell then running the washers and inspecting the state of them afterwards ?
Just time to rent a thimble more petrol before dinner.
Re: More Lost Electrons [Re: Peter J] #742134
17/05/22 11:19 AM
17/05/22 11:19 AM
Salisbury, UK
Peter J Offline OP
Formerly known as Aldermog
Peter J  Offline OP
Salisbury, UK
Replacing the switch on the brake pedal wasn't the answer.
My friendly BMW technician said that it is possible that the brake light switch is associated with the master cylinder or the ABS unit.
I'm taking the car back to Williams again on 26th, and it will stay there until it is fixed.
I beginning to tire of this game, the costs and the uncertainty....the nagging what happens next thoughts. And the train ride from Salisbury to Yate.
Power Corrupts.....
Tarka the 'Otter Mog....2014 Plus 8
Tesla Model 3 AWD.
Re: More Lost Electrons [Re: Peter J] #742150
17/05/22 02:54 PM
17/05/22 02:54 PM
Gloucestershire, UK
Hamwich Offline
Hamwich  Offline
Gloucestershire, UK
This is all pretty depressing stuff to read, and you guys have my sympathies, I can only imagine how galling it must be to spend an awful lot of money on a car which simply isn't reliable. I'm wondering whether there's a case to be made for ruggedising the entire electrical system somehow - but even if you could, it wouldn't help the mechanical issues.
Of course, the obvious (but maybe not so palatable) answer is not to buy a recent Morgan, or anything built on a CX platform, and simply stick with the older stuff. Rugged, simple, easy to work on and easy to fix, perfectly performant enough for most purposes, cheap to run and still fun to drive?
Re: More Lost Electrons [Re: TheCustomer] #742160
17/05/22 04:32 PM
17/05/22 04:32 PM
Cambridgeshire
asbojohn Offline
le Asbo du Bling
asbojohn  Offline
le Asbo du Bling
Cambridgeshire
Will
Your problem seems some interna breaks on the wiring.
Slowly going green
Re: More Lost Electrons [Re: Peter J] #742166
17/05/22 04:56 PM
17/05/22 04:56 PM
Salisbury, UK
Peter J Offline OP
Peter J  Offline OP
Salisbury, UK
Electro mechanically the car is a +10 year old 45,000 mile E36 Series BMW 3 series....complicated by Morgan's value engineered CANBUS controllers from Volvo that are supposed to make the BMW and Morgan bits communicate.
So I think there will be periods of electrical incontinence... It is the price I have to pay for owning a hand built classic that whilst costing a bit to keep in good order isn't depreciating and when on form is simply a joy to drive....
I keep thinking a Plus Four would make sense but would it?
Power Corrupts.....
Tesla Model 3 AWD.
Re: More Lost Electrons [Re: Peter J] #742167
17/05/22 05:00 PM
17/05/22 05:00 PM
Luddite Offline
Luddite  Offline
Sorry to read of your brake light issue Peter. My expectation of a brake light circuit would be that it should be of a robust and simple design with no electronics involved thus simple to trace and rectify any fault. The switch would seem the most likely fail point, after that fuse(s) and loose/dirty connections... For sure intermittent faults are a real pain, though the fault must be found and proven to be repaired to restore any faith in the system.. ?
Good luck.
