7 registered members (Fuel.inj, JMD, RichardV6, TBM, JB62, Alan Patterson, alb),
344
guests, and 11
spiders. |
Mirrors
by Image. 13/08/22 09:06 AM
Topics43,856
Posts738,620
Members8,072
Most Online1,033 Dec 28th, 2019
Re: Off to HQ
[Re: Neilda]
#741155
06/05/22 05:56 PM
06/05/22 05:56 PM
Posts: 5,088 Northern Capital of Cool
First drive out today and first visit to the petrol pump. It's fixed! It fills just like any other car - nozzle right in, squeeze as hard as you like. Fantastic - I'm delighted as it was the only real negative I had about the car. I dreaded filling it. Thank you MMC. Neil, do you know what MMC did as the cure ?
Re: Off to HQ
[Re: CooperMan]
#741219
07/05/22 09:52 AM
07/05/22 09:52 AM
Posts: 4,897 Surrey. UK
Neilda
Surrey. UK
First drive out today and first visit to the petrol pump. It's fixed! It fills just like any other car - nozzle right in, squeeze as hard as you like. Fantastic - I'm delighted as it was the only real negative I had about the car. I dreaded filling it. Thank you MMC. Neil, do you know what MMC did as the cure ? Yes - they listed: Machine Shop Supply Fuel Adapter. Tank Rubber Gasket Petrol Hose 1/2 Inch Bore Petrol Cap Side Vent 12mm I assume bigger vents/bores and an especially made up 'supply fuel adapter' - but I don't know what this is. It was worth having done as filling the car was beyond tedious. It was painfully slow (gingerly pressing the trigger etc) but also not really knowing if the car was actually full. Worth adding that previously I would end up with my feet covered in petrol as it would also suddenly woosh out of the filler cap. This has stopped too.
+8 4.8
Re: Off to HQ
[Re: Neilda]
#741264
07/05/22 06:44 PM
07/05/22 06:44 PM
First drive out today and first visit to the petrol pump. It's fixed! It fills just like any other car - nozzle right in, squeeze as hard as you like. Fantastic - I'm delighted as it was the only real negative I had about the car. I dreaded filling it. Thank you MMC. Neil, do you know what MMC did as the cure ? Yes - they listed: Machine Shop Supply Fuel Adapter. Tank Rubber Gasket Petrol Hose 1/2 Inch Bore Petrol Cap Side Vent 12mm I assume bigger vents/bores and an especially made up 'supply fuel adapter' - but I don't know what this is. It was worth having done as filling the car was beyond tedious. It was painfully slow (gingerly pressing the trigger etc) but also not really knowing if the car was actually full. Worth adding that previously I would end up with my feet covered in petrol as it would also suddenly woosh out of the filler cap. This has stopped too. Many thanks Does yours have this mis filling plate removed now ? I ask because I have a pal with a trad that has problems of fuel burp & can never get a full tank, & I suspect the unleaded only breather plate below could be removed ![[Linked Image]](https://www.tm-img.com/images/2022/05/07/filler-cap.md.jpg)
Re: Off to HQ
[Re: CooperMan]
#741306
08/05/22 08:49 AM
08/05/22 08:49 AM
Neilda
Surrey. UK
Does yours have this mis filling plate removed now ? I ask because I have a pal with a trad that has problems of fuel burp & can never get a full tank, & I suspect the unleaded only breather plate below could be removed ![[Linked Image]](https://www.tm-img.com/images/2022/05/07/filler-cap.md.jpg) The inside of the cap looks as it did before - so I don't think that plate has been removed.
+8 4.8
Re: Off to HQ
[Re: Neilda]
#741313
08/05/22 09:04 AM
08/05/22 09:04 AM
Posts: 22,612 Suffolk
Brooklands Register contact
Suffolk
I cant easily fully fill the tank. So this is interesting.
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Off to HQ
[Re: Neilda]
#741318
08/05/22 09:43 AM
08/05/22 09:43 AM
nick w
I had this problem with my series 1 roadster when new. I found that the plate with all the holes in pictured above rotates very freely. Only when the hinge is at 12 o'clock will the car fill properly. That's my memory of it, I just rotated the plate using a pencil and the problem went away. I should call it the flap, not the plate. Nick
Re: Off to HQ
[Re: Neilda]
#741324
08/05/22 11:26 AM
08/05/22 11:26 AM
Suffolk
Just tried the 12 oclock apporach & that seems to help
Re: Off to HQ
[Re: John V6]
#741385
09/05/22 07:13 AM
09/05/22 07:13 AM
Neilda
Surrey. UK
I cant easily fully fill the tank. So this is interesting. I have to say that it's a bit of a game changer being able to fuel easily - but also recognise that it's major faff to take it to the factory. I am glad I have had mine done.
+8 4.8
Re: Off to HQ
[Re: Neilda]
#741399
09/05/22 08:39 AM
09/05/22 08:39 AM
Posts: 9,550 Hampshire
Alistair
Smile, it confuses them
Hampshire
I have to say that it's a bit of a game changer being able to fuel easily - but also recognise that it's major faff to take it to the factory. I am glad I have had mine done. That was one of the things that used to drive me a little bit (more) nuts - it was a big change as you say.
Just time to rent a thimble more petrol before dinner.
