0 registered members (),
126
guests, and 10
spiders. |
Topics43,535
Posts732,585
Members8,015
Most Online1,033 Dec 28th, 2019
Re: Tyre Pressure
[Re: Malachy]
#741451
09/05/22 02:09 PM
09/05/22 02:09 PM
Posts: 1,106 North Somerset, UK
Deejay
North Somerset, UK
I have it on expert authority (SSL) that 22psi is plenty for the front. My first question would be how old are the tyres? Many people find a vast difference with new rubber, so if they are 8 years old or so, worth changing anyway as rubber hardens over time. Also, exactly what do you mean by uprating the suspension?? One further thought, with the front jacked up, can you spin the steering wheel with one finger in the steering wheel spokes?
Doug
2011 +4 in Rich Maroon 1972 750 “ComDom” sprinter 1958 Triton 650 1992 Triumph Trophy 900
Re: Tyre Pressure
[Re: Malachy]
#741464
09/05/22 03:12 PM
09/05/22 03:12 PM
Deejay
North Somerset, UK
Good news; those pressures were crazy! You can check exact date of tyres from a code moulded in on the sidewall; look for a 4 digit number, usually in a little depression near the rim. The first 2 digits are the week number and the second 2 are the year. Don’t expect you need to be reminded about greasing the suspension regularly too. I do mine every 500 miles.
Doug
Re: Tyre Pressure
[Re: Malachy]
#741474
09/05/22 05:43 PM
09/05/22 05:43 PM
Posts: 22,281 Suffolk
Brooklands Register contact
Suffolk
Change them if over 5 - 6 years old
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Tyre Pressure
[Re: Malachy]
#741489
09/05/22 07:10 PM
09/05/22 07:10 PM
Posts: 4,863 Northern Capital of Cool
Be very careful with those tyres, at that age and running below proper pressure will have put a lot of bending stress into the sidewalls as they rotate
As John says above, change them...what price do you put on safety ?
Re: Tyre Pressure
[Re: Malachy]
#741519
10/05/22 07:34 AM
10/05/22 07:34 AM
Posts: 10,706 Gloucestershire, UK
Hamwich
Gloucestershire, UK
I run my 4/4 tyres at 23psi all round, and feel that this gives the best combination of sidewalk flexibility and steering lightness. An old set of Avons that have been run at less than 15psi should definitely be replaced as the sidewalls will have been overstressed in my view.
I have Vredestein Sprint Classics on my car. The rears are 5 years old, the fronts are 9 years old. the car lives in a dark garage most of the time, so they are not exposed to much in the way of UV degradation. There is loads of tread left on each tyre - 4mm or so. There are no visible signs of ageing or deformation. I took it out for a good thrash round last week, and I could detect no difference in handling or road holding from that which I'm used to. I could get the tyres to chirp when I wanted to, and they clung on just as tight as I wanted them to when cornering.
For a heavy powerful car with upwards of 200bhp that is driven hard especially on track days, then yes, changing tyres every 5 or 6 years is probably wise. But for a 4/4 or +4 used for summer cruising and touring, not so much in my view.
I will probably put a fresh pair on the rears next winter and move the existing rears to the front, but I am not going to stress over driving around on old tyres this summer. Yes, it's a risk, but as long as the tyres have been looked after and regularly inspected, I don't believe it's _that_ much of a risk. With a car that only weighs 850Kg or so, they are far less heavily loaded than their design capacity.
Re: Tyre Pressure
[Re: Malachy]
#741539
10/05/22 09:16 AM
10/05/22 09:16 AM
Posts: 7,129 Devon
Budster
Devon
In my 2003 Zetec engined 4/4 I run 21/23 when loaded and 19/21 unloaded. I use Continental tyres and change them every 6 or 7 years. Bud 4/4 - Stanley
Bud 4/4 "Stanley"
