Well; coincidentally I had a problem with the fuel gauge in two-ton the past few weeks.
Always indicated completely full. He did that sometimes in the past, but after a while or a refill everything went back to normal.
But not anymore, Research was needed.
I found in this great forum that the cause could be the tank sensor and how to clean it.
The spare wheel and everything else off.
Disconnected the cables to the sender and the gauge gave zero.
Then the resistance measured on the sender, which gave 38 ohms which according to Bunny's data is about half full.
But how much is in the tank now?
It's pretty simple to figure that out on an old Morgan. No valve in the filler opening.
I took a cord with a thick nut on it and lower it to the bottom.
I could see that the tank was indeed half full. So the sender is ok.
The contacts of the sender and cables cleaned and reattached and everything worked as usual.
Refueled up to three quarters with the gauge on, and double check with the cord,everything fine.
Did 120 Km today and everything is back to normal.
Apparently it was just a bad contact. But to measure is to know as we say in Flemish.
What would we be doing all day without a Morgan!?!?
