9 registered members (planenut, Budster, Hamwich, Vicar, TBM, MJF, SimonH, dogmog, Quicksilver),
265
guests, and 11
spiders. |
Topics43,313
Posts728,694
Members7,932
Most Online1,033 Dec 28th, 2019
Replacing 3 way union on rear axle
#741738
12/05/22 07:54 PM
12/05/22 07:54 PM
Posts: 132 San Francisco
RobFog
San Francisco
I'm slowly replacing parts on the car, starting from the brakes and, as I learn the hard way, gradually making my way to the engine. I need to replace the 3 way brake union on the rear axle - looks like the only unions now available are differently configured and, due to the thickness of the union, I can't seem to make the original axle clamp fit as the bolt through the union tightens up before the clamp is tightened to the axle. Hope that makes sense. If somebody else has replaced their union do you have any tips or images of what you used. The axle is 7 inches in diameter and I've searched for clamps etc without success. Picture of picture of old and mew tees .
1974 4/4 2 seater
Re: Replacing 3 way union on rear axle
[Re: RobFog]
#741744
12/05/22 08:27 PM
12/05/22 08:27 PM
Posts: 246 Ross-on Wye, Herefordshire
bilibib
I'm slowly replacing parts on the car, starting from the brakes and, as I learn the hard way, gradually making my way to the engine. I need to replace the 3 way brake union on the rear axle - looks like the only unions now available are differently configured and, due to the thickness of the union, I can't seem to make the original axle clamp fit as the bolt through the union tightens up before the clamp is tightened to the axle. Hope that makes sense. If somebody else has replaced their union do you have any tips or images of what you used. The axle is 7 inches in diameter and I've searched for clamps etc without success. Picture of picture of old and mew tees . I think you mean 7 inches in circumference
Owen "bilibib" 1982 4/4 Twin Cam Royal Ivory, Dark Red Leather
[Re: bilibib]
#741755
13/05/22 12:37 AM
13/05/22 12:37 AM
RobFog
San Francisco
I do indeed - thanks, that's why it took me multiple attempts to get my maths GCSE
1974 4/4 2 seater
[Re: Arwyn Williams]
#741790
13/05/22 12:57 PM
13/05/22 12:57 PM
RobFog
San Francisco
Why does the union need replacement?
Arwyn
Unfortunately, the threads aren't ok . The union I received seems to be the standard replacement part as offered by Melvyn Rutter and Morgan Motors of New England, but, because the bolt hole is that much larger than the original, I can't tighten the clamp sufficiently to keep it rigid on the axel. I've searched for axel clamps but nothing suitable comes up, not sure if there's another kind of clamp or brace I could be using for my search terms.
1974 4/4 2 seater
[Re: RobFog]
#741796
13/05/22 01:38 PM
13/05/22 01:38 PM
Posts: 1,064 North Somerset, UK
Deejay
North Somerset, UK
Not sure of the clamping arrangement but I guess it’s simply there to prevent the union and pipes wobbling about, so no great mechanical force is needed. If all else fails, can you not improvise with a large Jubilee Clip (hose clamp) to clamp a small bracket to the axle and then bolt through to that bracket?
Doug
2011 +4 in Rich Maroon 1972 750 “ComDom” sprinter 1958 Triton 650 1992 Triumph Trophy 900
[Re: Deejay]
#741807
13/05/22 03:32 PM
13/05/22 03:32 PM
RobFog
San Francisco
Not sure of the clamping arrangement but I guess it’s simply there to prevent the union and pipes wobbling about, so no great mechanical force is needed. If all else fails, can you not improvise with a large Jubilee Clip (hose clamp) to clamp a small bracket to the axle and then bolt through to that bracket? Thanks Deejay, I was considering whether a Jubliee Clip would give it a sufficient rigidity, let me try that. I've learnt so many new terms and phrases on this site that I was wondering if there was a specialized axle clamp - a Windsor Sprocket, a Cleveland Beebop or something similar that served this exact purpose Just for the record, here's how it currently looks in case my original description wasn't sufficient.
1974 4/4 2 seater
[Re: RobFog]
#741824
13/05/22 04:57 PM
13/05/22 04:57 PM
Posts: 342 Bethel, CT USA
PaulyG
Bethel, CT USA
I can't remember how it looks on mine, but does the clamp go to either side of the TEE? And now the new TEE is thicker so the ends of the clamp are farther apart?
If so, can you just put both sides of the clamp on the same side of the TEE? Maybe use a longer bolt?
1973 4/4 2 place
