14 registered members (Jon G4LJW, Burgundymog, Image, Tresco, Paul F, James B W, deano, teifistar, AlyMatt, B3MOG, Barkbark, TBM, 1560, Fuel.inj), 97 guests, and 12 spiders.
+8Rich 126
John V6 103
OZ 4/4 94
8359 Registered Users
Used car purchase scam?
by KennethM. 29/05/23 09:50 PM
M3W - check the following
by Chris99. 29/05/23 05:12 PM
4/4 Four seater outdoor car cover
by Tim W. 29/05/23 08:11 AM
Book recommendation..
by +8Rich. 28/05/23 01:29 PM
Morgan roof
by tom+4. 28/05/23 10:02 AM
Luton Town FC in Premier League
by Fox Terrier. 28/05/23 08:09 AM
MSCC Denmark 50th: Frederica 8th June
by docock. 28/05/23 07:10 AM
Spotted In Amboise Loire
Wiscombe Park
Sod the rain
Forums32
Topics45,127
Posts764,405
Members8,359
Most Online1,033
Dec 28th, 2019
No Birthdays
Door Lock Failure #741778
13/05/22 09:08 AM
13/05/22 09:08 AM
Winchmore Hill, Bucks
CJB Offline OP
CJB  Offline OP
For some time the central pin on my 1990 +8 driver's door lock has been loose meaning the door doesn't shut tight. I finally got round to removing it from the 'pillar' to see if I could tighten it. I assumed it had a nut on the back, forum users may be interested in the design. I'm guessing the door locks and catches are originally Land Rover Defender?
Fortunately I have speakers fitted so I was able to remove the speaker and gain access behind the frame to remove the nuts on the 2 retaining bolts. I also removed the cup screws down the front edge of the trim panel and could spring the panel open to gain access.
It turned out the pin is fixed to the plate with a couple of tack welds on the back and these had fractured.
I ground off the broken welds and cadmium plating locally and my mate applied 3 new welds.
I didn't take a picture of the broken welds but here is the repair:
https://tm-img.com/image/Fnz6U
https://tm-img.com/image/FnLPs[/
1990 +8 Connaught Green
1970 Lotus Elan S4 SE
1973 Lotus Europa TC/Special
Re: Door Lock Failure [Re: CJB] #741795
13/05/22 01:34 PM
13/05/22 01:34 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Doubt you will have any further trouble with this repair thumbs
2018 Roadster - Red/Magnolia - Morton
1966 Land Rover S2a 88 - Lenny
1945 Moto Guzzi Airone
Re: Door Lock Failure [Re: CJB] #741797
13/05/22 01:45 PM
13/05/22 01:45 PM
Suffolk, England
John V6 Offline
Brooklands Register contact
John V6  Offline
Suffolk, England
This is the other photo
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Door Lock Failure [Re: CJB] #741816
13/05/22 04:27 PM
13/05/22 04:27 PM
CJB Offline OP
CJB  Offline OP
Thanks for doing the photos gents, it always defeats me on this forum, much harder than most!
Re: Door Lock Failure [Re: CJB] #741818
13/05/22 04:29 PM
13/05/22 04:29 PM
Suffolk, England
John V6 Offline
John V6  Offline
Suffolk, England
No worries
Re: Door Lock Failure [Re: CJB] #742492
21/05/22 02:37 PM
21/05/22 02:37 PM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
As I see now, an usual problem…
http://www.talkmorgan.com/ubbthreads.php/topics/736544/1
And a lot of possibilities to repair.
Greets René
2018 plus4 (sports green)
