9 registered members (brian battersby, BertR, nick w, Edwin, Bunny, Dougie, Image, JohnWT, SCX358G),
69
guests, and 15
spiders. |
Topics43,595
Posts733,723
Members8,033
Most Online1,033 Dec 28th, 2019
Re: Series 3 Aero - speedo
[Re: Roady]
#741655
11/05/22 03:35 PM
11/05/22 03:35 PM
Posts: 461 Oxted
PJC
Oxted
I have a Series 3 Aero and had an issue with my speedo recently where the needle started to vibrate and slowly work its way right around the clock to the maximum speed regardless of my actual speed and then it slowly went back to zero and rested on the stop and at the same time I lost the little LCD screen with the mileometer reading on it. I kept driving for about another hour and no change. Got home, washed the car and started it to put it in the garage and all was perfect again and not had an issue since - back to the old saying of MORGAN - Most Owners Regard Gremlins As Normal. If there is an electrical issue switching the car off and leaving completely off (no ignition) for a good 10-15 minutes will ensure that there is no residual charge in any of the systems and hopefully the next time it is turned on the classic reboot will reset everything - fingers crossed.
Cheers, Paul
[Re: Roady]
#741684
11/05/22 11:17 PM
11/05/22 11:17 PM
Posts: 2,097 Wales
Taffmog
Roady, Yes it is possible to recalibrate the speedo, I seem to remember this being discussed in previous posts on here, somewhere! Paul, odometer readings disappearing are almost always caused by damp air, a few miles with your sidelights on usually rectifies it with the heat from the bulb inside the instrument, otherwise use a hairdryer under the dash on gentle heat, this works too.
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
[Re: Roady]
#741756
13/05/22 01:41 AM
13/05/22 01:41 AM
Posts: 2,097 Wales
Taffmog
Let us know how you get on Paul..., trick works on my Aero.
[Re: Roady]
#741760
13/05/22 06:35 AM
13/05/22 06:35 AM
Posts: 1,819 Sevenoaks,Kent
Viper
Sir S1'a'lot
Sir S1'a'lot
Sevenoaks,Kent
Amazing coincidence that my digital display for mileage disappeared yesterday after leaving it out in the rain.
20 miles later and with the advice from Jamie at BHM to point the heater vent up it came back on.
I’ve recalibrated my Speedo too not was over reading by 15%
2000 Plus 8 4.6 2002 Aero 8 S1
[Re: Roady]
#741785
13/05/22 11:04 AM
13/05/22 11:04 AM
Posts: 9,421 Hampshire
Alistair
Smile, it confuses them
Hampshire
I will try this on the S2, I always felt it was overreading vastly. Ambling along the M4 in the traffic it used to read 90, I will reference the sat nav thingy. Excellent share thank you.
Just time to rent a thimble more petrol before dinner.
