3 registered members (JoeSpeetjens, Socalm3w, Heinz), 148 guests, and 13 spiders.
+8Rich 215
John V6 149
CooperMan 109
OZ 4/4 105
TBM 90
DalesPlusFour, Mark Adams, Ian12345Aero8, kiwi100, Steve_1970
8015 Registered Users
Inauguration of the Morgan Brussel Belgium garage
by nestor59310. 26/06/22 10:07 PM
Sat nav glare
by M3W55. 26/06/22 08:37 PM
Are pressure washers worth it?
by Quicksilver. 26/06/22 06:58 PM
Plus4 Tonneau 1993
by Clive Fishing. 26/06/22 04:16 PM
I Had To Do It....
by Peter J. 26/06/22 12:38 PM
Vredestein t-trac 2 165/80r15
by Montegue. 26/06/22 08:06 AM
Wire Wheels - Chrome to Black Options?
by Montegue. 26/06/22 07:41 AM
Isle of Man Trip June 2022
People of the Isle of Man Trip June 2022
Orkney
New Plus Four config...
MOG414 on MaltaTV part 1 &  2
Topics43,535
Posts732,585
Members8,015
Most Online1,033
Dec 28th, 2019
Garywc
Plate hanging out brake pad #741975
15/05/22 08:16 PM
15/05/22 08:16 PM
Oxon
Craig Jezz Offline OP
Oxon
When greasing and cleaning this afternoon, I noticed this plate hanging out the off side brake calliper. I believe it’s called a anti squeal plate.
I don’t feel confident enough in removing any pins to the callipers to investigate incase I can’t get it back together. So for now I pushed it back in place with a screwdriver.
Does anyone know the part number for this, or is this all part of the pads as a kit ? My Morgan is a 2016 4/4 Sport
Any advice is greatly appreciated
Pushed back in place
Craig Jezz
Morgan 4/4 Sports Sand
Re: Plate hanging out brake pad [Re: Craig Jezz] #741978
15/05/22 09:40 PM
15/05/22 09:40 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
I wouldn't drive the car until you have removed the pins, pads and the trapped anti-squeal spring plate. The latter holds the pins and therefore the pads in place. Can only suggest it was mis-seated when pads were last changed.
If damaged the part you will need to replace is (5) in above diagram, one for each pad pin, and part number MBS1890. I would check pads and pins as well.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: Plate hanging out brake pad [Re: RichardV6] #741979
15/05/22 09:48 PM
15/05/22 09:48 PM
Oxon
Oxon
Ok thanks Richard. The pads are the originals
Craig Jezz
Re: Plate hanging out brake pad [Re: Craig Jezz] #741980
15/05/22 09:49 PM
15/05/22 09:49 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
The two retaining pins are held in place by the spring clips visible under each pin. Depress the spring clip and the pin slides out of the caliper. No force is necessary. But if you're not experienced with brakes, seek assistance!
Re: Plate hanging out brake pad [Re: Craig Jezz] #741981
15/05/22 09:54 PM
15/05/22 09:54 PM
RichardV6 Offline
RichardV6  Offline
Did you remove pins and pads when you painted calipers though Craig?
As Dave suggests you just need to depress the spring securing plate and pins slide out. I use a broad flat blade screwdriver.
Re: Plate hanging out brake pad [Re: RichardV6] #741982
15/05/22 09:56 PM
15/05/22 09:56 PM
Oxon
Oxon
Did you remove pins and pads when you painted caliper though Craig?
I didn’t remove any pins no….I painted in situ.
Craig Jezz
Re: Plate hanging out brake pad [Re: RichardV6] #741994
16/05/22 06:04 AM
16/05/22 06:04 AM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
I don't think it is one of the springs - it looks more like one of the anti squeal shims that fits to the back of a brake pad.
1972 4/4 4 seater - 3G Morganeer
Too many ratty motorbikes
Re: Plate hanging out brake pad [Re: TBM] #741999
16/05/22 06:51 AM
16/05/22 06:51 AM
RichardV6 Offline
RichardV6  Offline
On later models there isn't such though TBM - check out parts diagram above. I think the spring clips bearing on pins and top of pads serve that purpose.
Re: Plate hanging out brake pad [Re: RichardV6] #742001
16/05/22 07:09 AM
16/05/22 07:09 AM
Northants, UK
TBM Offline
TBM  Offline
Northants, UK
They're often bonded/fixed onto the back of the pad rather than a seperate item in the old day. I had a set of new pads from my Mrs Hyundai in the shed, and they have shims fitted.
My understanding was the spring clips were to stop pad rattle and to prevent the pins working loose.
From the photos, it looks too large and flat for a spring, and also don't think it possible for a spring to fit between the piston and pad whilst in situ.
Re: Plate hanging out brake pad [Re: Craig Jezz] #742005
16/05/22 08:56 AM
16/05/22 08:56 AM
Devonshire
+8Rich Offline
+8Rich  Offline
Devonshire
Hi Craig,
When I had my Sport about three years into ownership and 15,000 mls the car pulled to the right under braking so I checked the front brakes and the nearside outer pad had delaminated from it's heavy steel backing plate. New pads ordered up and fitted and the thin metal shim you are referring to which I understand to be an anti squealing device did not come with the pads, I just put a smear of copper grease on them and they held in place no problems.
I am at a loss to suggest any reason (other than below) why yours has become dislodged but it could well be that it stays where it is now, just keep a regular check on it until you visit Henry's again.
You can see in your top image the impression left by the upper piston on the plate suggesting this is a recent happening and other than the top piston now exerting less pressure on the plate than the lower one I can't see why it would become loose, I am assuming braking is as per normal ? as if the piston is sluggish I would expect the imbalance to give the car a tendency to veer to the right slightly under heavyish braking.
Regards Richard
1993 Connaught Green +8 prev
