0 registered members (),
140
guests, and 17
spiders. |
Topics43,535
Posts732,587
Members8,015
Most Online1,033 Dec 28th, 2019
Re: More Lost Electrons
[Re: Peter J]
#742170
17/05/22 05:07 PM
17/05/22 05:07 PM
Posts: 14,957 Salisbury, UK
Peter J
Formerly known as Aldermog
Salisbury, UK
The brake lights don't work... but I don't get a "bulb failure" warning, which should happen if a bulb fails. So it isn't simple. There are no obvious fuses for the brake lights.
There are strange things happening here... The Prince of Darkness seems to be at large.
Peter, Power Corrupts..... Tarka the 'Otter Mog....2014 Plus 8 Tesla Model 3 AWD.
[Re: Peter J]
#742198
17/05/22 11:55 PM
17/05/22 11:55 PM
Posts: 2,091 Wales
Taffmog
Peter, just change your dealer......
1969 4/4 1995 plus 8 2002 Aero S1 2013 M3W 2014 Plus 8
[Re: B3MOG]
#742201
18/05/22 06:08 AM
18/05/22 06:08 AM
Posts: 4,902 East Harling, Norfolk UK
Peter, I may be completely wrong here but when I was in industry when canbus systems were popping up one of the problems I found was that at the end of the wiring cct (canbus) there is usually a small resistor in the cct that sometimes fails... of course it may all be different nowadays.
David Byrne That ties in with the Canbus on my Roadster David. On the topology schematic there are 120Ω terminator resistors on medium and high speed networks linking BCU, PCM and instrument cluster. Guessing these are to load the networks and hide any random transients that might otherwise errantly trigger something. It also shows twisted pairs of interconnecting cables carrying high and low signals on each network, again designed to cancel out random inductions.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
[Re: Taffmog]
#742202
18/05/22 06:25 AM
18/05/22 06:25 AM
Peter, just change your dealer...... It might be the way to go Peter. Such an annoying random fault on a limited production run hybrid system is, pardon me for suggesting, seemingly beyond the pay grade for most if not all Morgan dealers. At this stage I would tempted to seek out a Canbus expert (easily said I know) and better spend money there. My brother had a Mondeo Titanium X with a recurring, annoying dash problem. He had no help from Ford but found such an expert who had come up with a fix for the random electronic speedo error's he was suffering.
[Re: asbojohn]
#742251
18/05/22 04:54 PM
18/05/22 04:54 PM
TheCustomer
Got mine back from a factory service a couple of weeks back. Similar issue with the lights that now seems to have been fixed. ah, is that Peter's rear lights issue, or my flickering headlamps issue?! Will Your problem seems some interna breaks on the wiring. many thanks John - I'll let Williams know, and hopefully they can fix it. I guess Morgan bought a job lot of Mini Cooper headlamps in 2007, with wiring - so my 2017/8 build car has 15 year old wiring in places. Will
Aero 8 S5 BMW i8 Coupe Triumph Stag '72
[Re: Peter J]
#742452
20/05/22 08:00 PM
20/05/22 08:00 PM
Posts: 654 Berkshire/Oxon & Devon
JB62
Had the friendly little “ bulb failure” message again today. Checked all lights- all good. Only failure seems to be the warning. Hopefully when I fire it up tomorrow to drive to Stonor it will have gone.
V8 Speedster ( current) 4/4 Competition spec (5 years) 4/4 4str Kent ( 10 years)
