10 registered members (DavidR, Soleng, Leroy, bmgermany, GIB, PhilRoyle, Karlosfandango, IvorMog, PocketRocket, RedThree), 55 guests, and 21 spiders.
+8Rich 307
John V6 205
OZ 4/4 168
CooperMan 162
RichardV6 142
Alford, Mogge77, Kevin McMillen, Corrosion Guy, Supernano
8072 Registered Users
Upper intake manifold gasket
by Leroy. 15/08/22 04:16 PM
Removing scuffs to the rear perspex window
by Quicksilver. 15/08/22 01:36 PM
Handbrake cable moving
by NelsonG. 15/08/22 01:00 PM
Bevel box grease ?
by nippymog. 15/08/22 12:55 PM
Plus 4 Rover M16 ECU
by Beltiebeef. 15/08/22 11:04 AM
Seat Webbing split on drivers seat
by jeepy. 15/08/22 09:18 AM
Sospan a warning
by +8Rich. 14/08/22 05:08 PM
4/4 75th Anniversary
Around the Cairngorms
Big Skies
More from Helmingham
Helmingham Hall Car Show 7.8.22
Topics43,869
Posts738,828
Members8,072
Most Online1,033
Dec 28th, 2019
Richard - Aus
New wheels.. #742190
17/05/22 07:36 PM
17/05/22 07:36 PM
Cotswolds
Treesurveyor Offline OP
Cotswolds
Well, new to me, as in a new look. I fancied a change to alloys for a while, then I read up on all the tales of how difficult changing hubs was! Undeterred, or maybe just doggedly determined, I sourced wheels and hubs, the latter from Terry at G.E.E. "Do it here" he said, "don't worry, Ive got a spline hub puller and some really long bars somewhere, and if we need to we can heat them up under tension and go for lunch, they may spring off when we're not looking!"
Well, having set too with the front hubs, and peining off the rust build up, I crossed my fingers that Terry could find the puller, and it would work. No need for worry, there was the puller in the corner- well, Terry found it, I could only see a pile of metal, but then I'm not an engineer! but I do usually know where I've put something. "Make sure you wind it on the right side, dont forget to remove washer, put the nut back backwards, and wind it up." Blow me, the rear hub popped off with a couple or three turns! Three cheers Terry! Light work in the end, though I hadn't factored new bearings for the front's ( nearside race was pitted and scored), so back tomorrow to finish off, with Dot on stilts awy from home tonight. Happy with progress so far, and so nice to work on a hard level(ish) surface. Maybe next year I'll get to play indoors!
[Linked Image] [Linked Image]
06 Saab 93
Re: New wheels.. [Re: Treesurveyor] #742210
18/05/22 08:25 AM
18/05/22 08:25 AM
London
MOG 615 Offline
MOG 615  Offline
London
That was both lucky and a credit to Terry's engineering knowledge and practice .
New bearings are always a good idea if there is any pitting or corrosion on the tracks.
Andy G
1999 +8 , Indigo Blue.
Re: New wheels.. [Re: Treesurveyor] #742265
18/05/22 08:11 PM
18/05/22 08:11 PM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
Great work!
I love MOGs on alloys.
Greets René
2018 plus4 (sports green)
Re: New wheels.. [Re: Treesurveyor] #742270
18/05/22 08:37 PM
18/05/22 08:37 PM
Cotswolds
Cotswolds
Frustratingly, still waiting for wheel bearings, so third day tomorrow without driving yet! I've opted for Dunlop SP Sport blue response on the bare spare. Yokohama Advan semislicks on the four corners for now. I think its probably best to switch them out for touring, and keep a set by for trackdays/sprints/hill climbs when I get into all that. Hopefully roll bar fitting tomorrow as well; Have to leave that in the trusted hands of my son, I have to go to work! Something wrong about my equations there! 🤦irked
06 Saab 93
Re: New wheels.. [Re: Treesurveyor] #743120
28/05/22 06:27 PM
28/05/22 06:27 PM
Cotswolds
Cotswolds
Finally got finished up last Wednesday, later than anticipated, and a tad over budget. After waiting for the bearings, turns out the replacement front hubs were incompatible with the the front stub axles- bearings too small. TF made a quick call to Morgan, and sourced the last pair in stock of the correct hubs. They arrived 2 days later, and swiftly had bearings installed. I fitted them on the stub axles, excitedly anticipating mounting the wheels and getting away. Ahh, calipers now wont fit! After some head scratching, (mine) spacers are turned and the discs remounted. Joy at last, 4 Morgan alloy wheels on the ground! Thursdays 275 mile work trip was a good test of the rework, (with a wheel bolt torque check at 100 miles) Cotswold windy roads testing on Friday, with nothing coming apart or un-recognised noises, gave great peace of mind for todays thrash up Shelsley at the inaugural Haggerty Hill Climb there. Great fun, and shaved 4 secs of my previous members day effort; as to whether thats due lighter wheels/reduced unsprung weight, or the fact I swapped my 24 yr old son as passenger for the 11 yr old, whose to say. It being only my second climb, I hesitate to say it's down to my improved performance.
Either way, I love the new look.
06 Saab 93
Re: New wheels.. [Re: Treesurveyor] #743141
28/05/22 08:28 PM
28/05/22 08:28 PM
Suffolk
John V6 Offline
Brooklands Register contact
John V6  Offline
Suffolk
Well done
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
