0 registered members (), 181 guests, and 18 spiders.
+8Rich 215
John V6 149
CooperMan 109
OZ 4/4 107
TBM 90
DalesPlusFour, Mark Adams, Ian12345Aero8, kiwi100, Steve_1970
8015 Registered Users
Inauguration of the Morgan Brussel Belgium garage
by nestor59310. 26/06/22 10:07 PM
Sat nav glare
by M3W55. 26/06/22 08:37 PM
Are pressure washers worth it?
by Quicksilver. 26/06/22 06:58 PM
Plus4 Tonneau 1993
by Clive Fishing. 26/06/22 04:16 PM
I Had To Do It....
by Peter J. 26/06/22 12:38 PM
Vredestein t-trac 2 165/80r15
by Montegue. 26/06/22 08:06 AM
Wire Wheels - Chrome to Black Options?
by Montegue. 26/06/22 07:41 AM
Isle of Man Trip June 2022
People of the Isle of Man Trip June 2022
Orkney
New Plus Four config...
MOG414 on MaltaTV part 1 &  2
Topics43,535
Posts732,587
Members8,015
Most Online1,033
Dec 28th, 2019
DaytonaMog
Sat Nav bracket #742656
23/05/22 07:01 PM
23/05/22 07:01 PM
Northern Capital of Cool
CooperMan Offline OP
I've always been nervous of my TomTom sucker making a mark in the lacquer on the dash, plus the location is a bit high so thought I'd make an alternative bracket, but where to securely fix without damage ?
I decided the glove box door gap is generous, so a bit of metal origami
It's fixed internally into the glovebox, mount is screwed to ally and a thin layer of foam on the back to keep it clear of the veneer
And there's enough gap for the door to work without catching
Quite tidy from the drivers view
Re: Sat Nav bracket [Re: CooperMan] #742657
23/05/22 07:05 PM
23/05/22 07:05 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Nice work!!!
Re: Sat Nav bracket [Re: CooperMan] #742661
23/05/22 08:26 PM
23/05/22 08:26 PM
UK
BuyBritish Offline
BuyBritish  Offline
UK
Great solution, but the bracket sitting there when not needing the sat nav would not look nice
I've seen a bracket that fits the dash lifter dot near the mirror and when not used it just lifts off...
Rob Davies
Morgan 3 Wheeler 1934 MX
Morgan Series 1 1947
Morgan +4 1956 TR4
Morgan +4 2000 T16 Rov
Re: Sat Nav bracket [Re: BuyBritish] #742662
23/05/22 08:32 PM
23/05/22 08:32 PM
Costock, South Nottinghamshire...
Paul F Offline
Paul F  Offline
Excellent work.
Which is what I have. Works well but causes the sat-nav to obscure the speedo in my 4/4. Rely on the GPS speedo I have on the steering column. And mine is a bit scruffy by comparison.
Costock, UK
2014 4/4 Rolls Royce Garnet Red
Disco 4
Re: Sat Nav bracket [Re: BuyBritish] #742692
24/05/22 08:50 AM
24/05/22 08:50 AM
Renfrewshire
asmair Offline
asmair  Offline
Renfrewshire
Does anyone know where you can buy a lifter dot bracket, or supply pictures to enable me to make one?
Regards Alistair
Re: Sat Nav bracket [Re: asmair] #742708
24/05/22 10:52 AM
24/05/22 10:52 AM
Paul F Offline
Paul F  Offline
Regards Alistair
Simple solution is to buy the lift dot fastener from eBay together with an aluminium motorcycle tax disk holder. Fit the faster to the narrow end and bend the tax disk holder to suit your dashboard. Then glue something to the back of the tax disk holder (leather offcut perhaps) to the rear of the tax disk holder to protect the leather on your dashboard. The mounting brackets to suit various sat-navs are available on eBay - you need to know the diameter of the pivot ball and Garmin differ from TomTom. Alternatively, you can glue a pad to the aluminium that your windscreen suction mount will adhere to.
Costock, UK
Disco 4
Re: Sat Nav bracket [Re: BuyBritish] #742754
24/05/22 07:06 PM
24/05/22 07:06 PM
Fair observation Rob, however I've tried the lift-a-dot version before and the wobble got annoying, also on 3.7's it totally obscures engine temp & fuel, and partially blocks the speedo with a wide screen Nav
Re: Sat Nav bracket [Re: CooperMan] #742763
24/05/22 08:48 PM
24/05/22 08:48 PM
Northern Germany
bmgermany Offline
bmgermany  Offline
Northern Germany
I am very happy with my lift-a-dot Version.
Here an older foto. I have raised the mobile phone with an extra plate So with my actual phone and the actually phone holder I use my mobile phone horizontally.
Also it looks like parts of the dash board are hidden that is not the case because the mobile is placed between the mirror and the dash bord.
My bracket - I used a piece of PE- is sitting like a clamp on the upper part of the dashboard so absolutely no wobbeling,
Some more photos also here:
Sat Nav bracket
Re: Sat Nav bracket [Re: CooperMan] #742809
25/05/22 03:28 PM
25/05/22 03:28 PM
Bridgeport
PaulyG Offline
PaulyG  Offline
Bridgeport
Nice work. I am in the process of designing something too. This gives me ideas.
1973 4/4 2 place
Re: Sat Nav bracket [Re: CooperMan] #742813
25/05/22 03:37 PM
25/05/22 03:37 PM
South West Hertfordshire, UK
Quicksilver Offline
Quicksilver  Offline
Good solution, Jon. Looks neat. Perhaps you should market and sell those !
David
2020 Roadster 3.7 Dove Grey.
