Forums32
Topics45,124
Posts764,265
Members8,359
Most Online1,033 Dec 28th, 2019
GPS Speedo recommendations?
#742677
24/05/22 04:46 AM
24/05/22 04:46 AM
Posts: 11,102 Gloucestershire, UK
Hamwich
Gloucestershire, UK
What with a increasing enthusiasm for tighter speed monitoring on our roads and the inevitable inaccuracy of a T9 cable-driven speedo in a Morgan, I'm thinking it might be wise to join the ranks of those who have fitted a GPS Speedo, especially with a Scotland trip coming up.
But a quick perusal of Amazon seems to show (a) a bewildering variety and (b) that they seem to be pretty large, so over to you guys.
I want something large enough that I can see the digits at speed (obvs), but small enough to mount in the eyeline of a Trad without obscuring too much. Extra bonus points if it can do some trip logging, even more bonus points if you can download the data for analysis.
TIA
Re: GPS Speedo recommendations?
[Re: Hamwich]
#742678
24/05/22 06:10 AM
24/05/22 06:10 AM
Posts: 6,091 East Harling, Norfolk UK
To show how cheaply they can be had I've just ordered this from Amazon - ÂŁ28.49 delivered  ![[Linked Image]](https://i.imgur.com/4mTE6wD.jpeg) It displays trip, odometer, real time, running time, altitude and of course speed, max and average. Quick detach from handlebar mount for recharging. It will be used on my Guzzi which doesn't have any speedo.
2018 Roadster - Red/Magnolia - Morton 1966 Land Rover S2a 88 - Lenny 1945 Moto Guzzi Airone
[Re: Hamwich]
#742680
24/05/22 06:58 AM
24/05/22 06:58 AM
Posts: 3,698 Aberdeenshire
Aberdeenshire
Sorry if this is stating the obvious, but there are two different types of HUD mini speedos out there ... one reads the GPS and one the vehicle's electronic speedo signal ... they look alike ... having nearly bought the wrong one for my old (pre-electronic) car in a fit of enthusiasm, it's worth reading the ad carefully
[Re: Hamwich]
#742682
24/05/22 07:03 AM
24/05/22 07:03 AM
and a third type that reads GPS speed from your phone and bluetooths to display.
[Re: Hamwich]
#742685
24/05/22 07:30 AM
24/05/22 07:30 AM
Posts: 4,438 Essex
Burgundymog
Black Rat
Black Rat
Essex
Why not just use a SatNav, probably more accurate than a cheap Chinese GPS. Remember you do need to be in an area that gets good Satellite reception or you can get lag or drop out.
[Re: Burgundymog]
#742686
24/05/22 07:53 AM
24/05/22 07:53 AM
Hamwich
Gloucestershire, UK
Why not just use a SatNav, probably more accurate than a cheap Chinese GPS. Remember you do need to be in an area that gets good Satellite reception or you can get lag or drop out. Because my sat nav is too large to have close to my sight line. I want something more discreet.
[Re: Hamwich]
#742689
24/05/22 08:10 AM
24/05/22 08:10 AM
Aberdeenshire
I went the 'cheap Chinese' route (because I hope that it will be a temporary fix while I get my main speedo to work with wonderful accuracy in spite of the cable currently being incompatible with the Type 9 5 spd box 🙂) .... my Defender has a spot-on accurate mechanical speedo (measured against various GPS and roadside speed warnings) ... so I tested it out by fitting it in the landy ... was surprisingly accurate and except for taking 30 secs to 'boot up' initially seems remarkably stable here in the NE Scotland.
Having an idea what revs correspond to what speeds as a temporary fallback for if you do get a drop-out might be reassuring.... though I guess in your case you can temporarily forgo the HUD in favour of the main speedo if that happens
I believe TBM has used one in his Morgan for some time, so maybe he can give us a 'long term test' report?
