7 registered members (Robbie, MATTMOG, dherdebart, +8Rich, RichardV6, milligoon, Derek596), 104 guests, and 20 spiders.
+8Rich 301
John V6 194
OZ 4/4 170
CooperMan 165
RichardV6 140
Alford, Mogge77, Kevin McMillen, Corrosion Guy, Supernano
8072 Registered Users
Seen at the factory
by Saxonian. 17/08/22 07:16 AM
Seen at the factory
by Saxonian. 17/08/22 06:30 AM
Altenator replacement for 4/4 Ford CVH?
by TimB. 16/08/22 04:31 PM
Speedometer Calibration
by 1854sailor. 16/08/22 01:31 AM
Upper intake manifold gasket
by Leroy. 15/08/22 04:16 PM
Removing scuffs to the rear perspex window
by Quicksilver. 15/08/22 01:36 PM
4/4 75th Anniversary
Around the Cairngorms
Big Skies
More from Helmingham
Helmingham Hall Car Show 7.8.22
Topics43,876
Posts739,032
Members8,072
Most Online1,033
Dec 28th, 2019
DougM
Page 1 of 63 1 2 3 62 63
Safety Recall - Brakes #743896
07/06/22 04:33 PM
07/06/22 04:33 PM
South Yorks
Clipper Offline OP
Clipper  Offline OP
South Yorks
Advised by my dealer Ledgerwood that emails are going out to Plus Six owners not to use the car until a possible leaking master brake cylinder issue is fixed - loss of brakes is possible.
Not sure if it affects other vehicles.
Dealer meeting tomorrow Wednesday - not sure how cars will get to the dealer.
Affected owners to be contacted.
I had to ring the dealer because I was advised by another motorist that my brake lights were on permanently. Dealer told me to push a switch connected to the brake pedal lever under steering wheel which made a ratcheting noise and moved about an inch which cured the problem.
Mechanism that controls the brake lights must be sticking - need to keep an eye on that.
Re: Safety Recall - Brakes [Re: Clipper] #743899
07/06/22 05:14 PM
07/06/22 05:14 PM
Devonshire
+8Rich Online content
+8Rich  Online Content
Devonshire
Well if they have instructed you NOT to drive it MMC is duty bound to trailer it to the factory or more likely your local dealer will pick it up to complete the work.
God help anyone currently on tour then...
Regards Richard
1993 Connaught Green +8 prev
Re: Safety Recall - Brakes [Re: Clipper] #743902
07/06/22 05:44 PM
07/06/22 05:44 PM
SER Offline
SER  Offline
Had the call at lunch time today from my local dealer I'm a new Plus Four owner so looks like recall affects all CX vehicles, only had the car for two weeks!
Re: Safety Recall - Brakes [Re: Clipper] #743903
07/06/22 05:49 PM
07/06/22 05:49 PM
tervuren belgium
thierry242 Offline
thierry242  Offline
tervuren belgium
Dear Mister ,...................
We understand from our records that you are the current registered keeper of a vehicle with the chassis number
detailed above.
We would like to advise you that during ongoing quality assessment of our product we have identified a possible
safety related issue in respect of all Morgan Plus Four and Plus Six vehicles.
Preliminary investigations indicate that in certain limited circumstances, premature degradation of the rubber seal(s) in
the brake master cylinder may result in compromised brake performance, and in extreme cases cause brake failure.
Because this is a possible safety issue, we are immediately advising that you should not drive your vehicle until a
rectification action has been completed.
Your supplying dealer will contact you as soon as the service action has been finalised in order to arrange for your
car to be rectified.
This work will of course be carried out free of charge. If you have any questions regarding this letter, please speak to
your supplying or nearest Morgan Dealership. Please quote the recall reference detailed at the top right-hand side of
the letter when calling.
We have sent you this important notice as we are concerned about your safety.
Your safety is our highest priority. We regret any inconvenience this inspection may cause; however, we are
committed to ensuring the continued safe operation of your vehicle
Re: Safety Recall - Brakes [Re: +8Rich] #743904
07/06/22 05:52 PM
07/06/22 05:52 PM
South Yorks
Clipper Offline OP
Clipper  Offline OP
South Yorks
Dealer says one owner in Portugal.
Says check fluid reservoir. - if full should be okay - not leaking hide
Re: Safety Recall - Brakes [Re: Clipper] #743905
07/06/22 05:52 PM
07/06/22 05:52 PM
tervuren belgium
thierry242 Offline
thierry242  Offline
tervuren belgium
As far i am concerned the car had breaking problems since the beginning , and i have adapted my way of driving since .
Re: Safety Recall - Brakes [Re: Clipper] #743910
07/06/22 06:42 PM
07/06/22 06:42 PM
Banham, Norfolk
Themorganeer Offline
Banham, Norfolk
This is going to cost.
What’s different in the CX master cylinder department to those on the classics?
Chris
2015 Plus4
Re: Safety Recall - Brakes [Re: Clipper] #743916
07/06/22 07:20 PM
07/06/22 07:20 PM
Taunton
deano Offline
deano  Offline
Taunton
Probably a simple & quick rectification for the dealer to complete
Martin (Deano)
Re: Safety Recall - Brakes [Re: Clipper] #743917
07/06/22 07:20 PM
07/06/22 07:20 PM
Perthshire & Kent
flyfisher Offline
flyfisher  Offline
Perthshire & Kent
Surely the CX master cylinder isn’t unique to Morgan…
Expect it is unique to the CX rather all due to ABS
Re: Safety Recall - Brakes [Re: deano] #743919
07/06/22 07:25 PM
07/06/22 07:25 PM
Northern Capital of Cool
CooperMan Offline
CooperMan  Offline
IIRC it's integral to the servo and access is pretty tight, plus some poor sod's get to wriggle into that tiny footwell to release the pedal connection, then bleed all the hydraulics and the ABS...
