9 registered members (Luca, HeadlessBlue, Karlosfandango, JMD, BARDI1949, Gordon D, Image, DCH, Fuel.inj), 281 guests, and 12 spiders.
OZ 4/4 151
John V6 131
+8Rich 122
Luddite 113
CooperMan 109
JJD1776, Newboy, Tractor Driver, Phil Bordeaux, Slushymud
8127 Registered Users
Sidescreen window sticking
by Felix42. 28/09/22 09:22 PM
CANBUS & LEDs
by Buzz44. 28/09/22 02:32 PM
S1 Aero on live UK online auction - Ends 27 Sept
by Volvos60s60. 28/09/22 08:07 AM
Whilst I'm at it...
by Treesurveyor. 27/09/22 08:06 PM
Wobbly Steering Wheel
by Treesurveyor. 27/09/22 06:56 PM
Greasing the front UJs
by John V6. 27/09/22 01:23 PM
Roaster 3.0 MK 1 Pulley Noise / Wobble
by flyfisher. 27/09/22 12:23 PM
MORGAN SUPER 3 SUPER CLASSIC
Mirror
Fun in the Sun
My 1991 Plus 8
Morgan Super 4 EV
Topics44,094
Posts743,430
Members8,127
Most Online1,033
Dec 28th, 2019
Dutch
Indicator front lights connectors #744978
17/06/22 04:21 PM
17/06/22 04:21 PM
Madrid, Spain
Marmota Offline OP
Marmota  Offline OP
Madrid, Spain
Hello everyone!
I'm about to change the front indicators of my 2020 3-wheeler. Because I'm tired of having their support broken due to the poor design (ridiculously weak welding to the light arm). It’s the second time it breaks in a few months. Same side (right). But I bet that the left one may break any moment too. Or the right one again if I let MMC to reinstall another new lights’ arm under warranty.
This said, I have a simple question I hope you may help me with: is it possible to remove the end of the wires – the metal pins – out of the connector? So, I can slide the new indicator’s wiring through the existing corrugated hoses and simply redo the end pins and insert them back into the connector.
This one with the red and white wires coming from the indicator.
I hope I explained myself correctly.
I’m asking because if I can do this, I can do all the wiring comfortably at home. Otherwise I may cut the existing wires, and weld them to the new short ones of the new indicator, but in the garage, just by the front light and the engine, with little room and light.
www.speedymarmots.com
Re: Indicator front lights connectors [Re: Marmota] #744992
17/06/22 07:45 PM
17/06/22 07:45 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Yes you can remove either male or female pins from these Econoseal connectors with a narrow thin blade no wider than that of pin. I've used a narrow blade precision screwdriver although there are pin removal sets available on eBay.
After removing the yellow pin locator sleeve and with whatever tool you use, it needs to be slid in on the plastic catch side of pin to allow it's release from the cable side. A waterproof rubber seal will come out of body with pin.
There are YouTube videos better showing this process. Replacement is much easier, just push pin back in ensuring correct orientation until it clicks into place. Then snug up the individual seal rubber and finally add the yellow pin locater.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: Indicator front lights connectors [Re: Marmota] #744994
17/06/22 08:03 PM
17/06/22 08:03 PM
RichardV6 Offline
RichardV6  Offline
As mentioned process is similar for male and female pins.
Re: Indicator front lights connectors [Re: Marmota] #745033
18/06/22 08:09 AM
18/06/22 08:09 AM
Madrid, Spain
Marmota Offline OP
Marmota  Offline OP
Madrid, Spain
Great! Thanks a lot!
