0 registered members (), 291 guests, and 16 spiders.
+8Rich 304
John V6 206
OZ 4/4 167
CooperMan 162
RichardV6 142
Alford, Mogge77, Kevin McMillen, Corrosion Guy, Supernano
8072 Registered Users
Sospan a warning
by +8Rich. 14/08/22 05:08 PM
Sprint day at Goodwood 13 august 2022
by Nick55. 14/08/22 04:24 PM
Boxster S Drives
by Peter J. 14/08/22 01:36 PM
Black Trad headlight rim
by John V6. 14/08/22 11:38 AM
Clear side repeaters for trads
by John V6. 14/08/22 08:54 AM
Fuel sending unit screws
by Rattler. 13/08/22 10:58 PM
4/4 75th Anniversary
Around the Cairngorms
Big Skies
More from Helmingham
Helmingham Hall Car Show 7.8.22
Topics43,863
Posts738,739
Members8,072
Most Online1,033
Dec 28th, 2019
Richard - Aus
Re: Removing Gas Cap [Re: AlexKnoll] #745234
20/06/22 01:59 PM
20/06/22 01:59 PM
AlexKnoll Offline OP
A person at Newton indicated there would be three grub screws underneath. I don't see those in the eBay listing so maybe it isn't a Newton unit after all.
Re: Removing Gas Cap [Re: AlexKnoll] #745282
20/06/22 11:16 PM
20/06/22 11:16 PM
Alrighty, figured it out with the help of a Morgan tech. The cap does indeed thread on but it is loctite'd to hell.
First I tried a strap wrench. NOT recommended. Not only did it not work, I gouged a bunch of paint out not realizing how close the metal piece was to the bodywork... This little project just became more expensive.
Final solution: Grab a piece of non-marring pipe and use it and a hammer to tap on the base of the hinge of the cap (closest to the front of the vehicle). It'll slowly rotate. A few taps in I had enough clearance to reach both bolts. Once done I tapped back the other way to realign it.
Re: Removing Gas Cap [Re: AlexKnoll] #745283
21/06/22 12:11 AM
21/06/22 12:11 AM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
i was thinking it was loctited and wondered the best way to loosen the loctite knowing that flame is a nono around fuel, but heat might soften it enough to not have to bang on it. Something like a heatgun on the closed cap? HeT blanket over the paint?
Re: Removing Gas Cap [Re: AlexKnoll] #745341
21/06/22 01:04 PM
21/06/22 01:04 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Surprised threads of that diameter would have required loctite. The friction over such a surface area would be high enough to stop parts coming undone once fully screwed up, assuming they were not previously greased. By the same token lots of opportunity for the slightest aluminium corrosion to jam the whole thing sold.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: Removing Gas Cap [Re: AlexKnoll] #745433
22/06/22 01:28 AM
22/06/22 01:28 AM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
The Loctite is likely used to hold the cap in the desired orientation, as otherwise you would need to have shim/sealing washers of just the right thickness to give the desired 'clocking' of the cap. Much easier to get it snug on the sealing washer then tighten it to the exact fore/aft clocking and keep it there with Loctite.
Late 2012 M3W
Re: Removing Gas Cap [Re: Bitsobrits] #745497
22/06/22 03:57 PM
22/06/22 03:57 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
that makes sense.
