0 registered members (),
119
guests, and 17
spiders. |
Topics43,535
Posts732,585
Members8,015
Most Online1,033 Dec 28th, 2019
Re: Loss of Power 3.7 V6 - help!!
[Re: roof down and go]
#744862
16/06/22 03:24 PM
16/06/22 03:24 PM
Posts: 4,863 Northern Capital of Cool
The metallic 'tinkle' you describe could well be the Cat as others have discussed or a collapsed baffle internally as they only look to be spot welded
#744864
16/06/22 04:12 PM
16/06/22 04:12 PM
Posts: 1,106 North Somerset, UK
Deejay
North Somerset, UK
I also had the ” tinkle” with the failed cat on the Ford Escort. Possibly a garage could stick their exhaust analyser up each pipe which may give a clue as to whether the cat is performing properly. Finding a replacement will be the issue as I guess if you just temporarily replace it with a bit of plain pipe, it will upset the ecu.
Doug
2011 +4 in Rich Maroon 1972 750 “ComDom” sprinter 1958 Triton 650 1992 Triumph Trophy 900
#744867
16/06/22 04:42 PM
16/06/22 04:42 PM
Posts: 22,281 Suffolk
Brooklands Register contact
Suffolk
But sound good. Maybe they empty out the bits and the rest stays in. Other a roadster in for sale and would that cat for yours?
JohnV6 2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
#744886
16/06/22 07:30 PM
16/06/22 07:30 PM
Posts: 108 Burgundy, France
Mick Annick
Burgundy, France
morzine - going south - not near Montceau les Mines or Toulouse - but if you can give me the names I'll keep them for sure. route is Annecy, Chambery, Grenoble , Aix en Provence, Nice Montceau les mines is https://www.garage-bobin.com/Toulouse is https://www.marcassus-sport.com/I’m 40 mins west of Dijon, have basic facilities, and a very good classic car specialist nearby if it’s of any help. keep us posted. Michael
Mike H
2000 Plus 8
#745567
23/06/22 10:27 AM
23/06/22 10:27 AM
Deejay
North Somerset, UK
An unexpected outcome indeed! In view of different temperatures on the same side, and the tinkle sound, I would get a compression test carried out in case a valve spring has broken or valve has bent, maybe?
Doug
#745618
23/06/22 03:20 PM
23/06/22 03:20 PM
Posts: 20,335 South Yorkshire
South Yorkshire
A couple of issues on the internet about the 3.7 engine.
3.7 Cyclone Cam Torque Actuated Phasers Problems Cam torque actuated phasers, primarily affect the later Ford 3.7 Ti-VCT engines. Dual variable cam timing (Ti-VCT) is somewhat complex technology involving many moving parts. The idea is to adjust cam/valve timing to allow for a better power band and fuel economy. It’s great tech that many modern engines use.
However, problems can and do occur with these systems. The Ford 3.7L Cyclone cam torque actuated phasers (cam phasers for short) are one of those issues that pops up. Cam phasers rotate each camshaft relative to the timing. When the 3.7 Duratec cam torque actuated phasers fail they can cause a handful of symptoms and other issues if not fixed in a timely manner. It’s also a pretty expensive fix.
Look for the following symptoms that may indicate an issue with the 3.7 Cyclone cam torque actuated phasers:
Check engine light Rattling sound from engine Power loss Rough running When the cam phasers fail you’ll usually get a check engine light and hear a rattling sound from the Ford 3.7 engine. It can also cause improper ignition timing, which can lead to a loss of power and rough running.
Ford 3.7 Cyclone Ignition Coil Issues The 3.7 V6 is a solid engine, overall. We’re mostly talking about ignition coils here since there aren’t many other major common problems. Ignition coils are really a standard wear and tear part that usually require replacement at some point during an engines life. However, the 3.7 Duratec ignition coils sometimes fail earlier than normal.
Look for these problems to pop up somewhere in the 70,000 to 100,000 mile ballpark. It’s really not a huge deal all things considered. Ignition coil replacement is usually required by 150,000 miles, anyways. It’s also not a serious issue by any means, though ignition coil problems can cause some drivability issues.
3.7L V6 Duratec Ignition Coil Symptoms Symptoms of ignition coil faults on the Ford 3.7L V6 include:
Misfires Rough running Check engine light Stuttering Misfires are the number one symptom of spark plug or ignition coil problems. Though, misfires can have many other causes. When the 3.7 Cyclone ignition coils go bad it will prevent the air/fuel mixture from properly igniting. In turn, you may notice the Ford 3.7 engine is running rough or stuttering. Misfires can sometimes trigger a check engine light, too.
