10 registered members (DavidR, Soleng, Leroy, bmgermany, GIB, PhilRoyle, Karlosfandango, IvorMog, PocketRocket, RedThree),
55
guests, and 21
spiders. |
Topics43,869
Posts738,828
Members8,072
Most Online1,033 Dec 28th, 2019
Corroded Side Light Screws
#747007
05/07/22 06:07 PM
05/07/22 06:07 PM
Posts: 7,168 Devon
Budster
Devon
Worth checking the screws that hold your front side lights/ indicators lenses in place. Two of mine had corroded to such an extent that they had failed. I couldn’t find suitable size replacements; despite trying both metric and BA. Melvyn Rutter’s wonderful parts department quickly came to the rescue. New screws complete with replacement brass fittings, arrived in the post. Bit awkward to fit, but now replaced and secure. Bud 4/4 - Stanley
Bud 4/4 "Stanley"
Re: Corroded Side Light Screws
[Re: Budster]
#747014
05/07/22 06:58 PM
05/07/22 06:58 PM
Posts: 5,096 East Harling, Norfolk UK
Depending on age/source of the Lucas lamp holders Bud, the lens screws will be either 3mm or larger diameter 6-32 UNC. The length will vary according to lens used but easy enough to match OE.
I've certainly sourced the smaller metric screws with matching brass T nuts on eBay, which work fine.
When fitting current switchback LED's in front indicator Iocation I took the opportunity to change screws to stainless though. A fit and forget solution with a blob of grease. You should be able to find the 6-32 UNC stainless screws on eBay or from your local stockist. I use Anglia Stainless.
2018 Roadster - Red/Magnolia - "Morton" 1966 Land Rover series 2a SWB 1945 Moto Guzzi Airone
[Re: Budster]
#747061
06/07/22 09:30 AM
06/07/22 09:30 AM
Posts: 8,463 Llanelli
sospan
Llanelli
I got 6-32 stainless from westfield fasteners. It is also worth looking for other products in their range to order with a single p&p. Very handy to have a stock to replace old nuts,bolts, screws, washers on a Morgan. https://www.westfieldfasteners.co.uk/
Red Plus8
[Re: Budster]
#747065
06/07/22 09:40 AM
06/07/22 09:40 AM
Posts: 4,113 Essex
Burgundymog
Black Rat
Black Rat
Essex
Worth checking the screws that hold your front side lights/ indicators lenses in place. Two of mine had corroded to such an extent that they had failed. I couldn’t find suitable size replacements; despite trying both metric and BA. Melvyn Rutter’s wonderful parts department quickly came to the rescue. New screws complete with replacement brass fittings, arrived in the post. Bit awkward to fit, but now replaced and secure. Bud 4/4 - Stanley  Hope Stanley is ok after his op.
[Re: Burgundymog]
#747073
06/07/22 10:05 AM
06/07/22 10:05 AM
Posts: 7,168 Devon
Budster
Devon
Worth checking the screws that hold your front side lights/ indicators lenses in place. Two of mine had corroded to such an extent that they had failed. I couldn’t find suitable size replacements; despite trying both metric and BA. Melvyn Rutter’s wonderful parts department quickly came to the rescue. New screws complete with replacement brass fittings, arrived in the post. Bit awkward to fit, but now replaced and secure. Bud 4/4 - Stanley  Hope Stanley is ok after his op. Minor surgery, now fully recovered.  Bud 4/4 - Stanley is
Bud 4/4 "Stanley"
