Morgan Aero 8
4 registered members (peterd, Jeff D, flaagan, MattB), 98 guests, and 11 spiders.
+8Rich 305
OZ 4/4 187
John V6 182
CooperMan 158
RichardV6 137
Captain Morgan, CVH44, Ruffy, Morgan76, RogerEB
8107 Registered Users
Automatic transmission swap on a 60's +4?
by flaagan. 19/08/22 10:47 PM
Apple security threat today..?
by Luddite. 19/08/22 07:13 PM
Brake Recall - A Related Issue
by Budster. 19/08/22 02:21 PM
Seat belt reel problem
by bmgermany. 19/08/22 01:22 PM
New Zealand Floods
by OZ 4/4. 19/08/22 10:30 AM
Hello from France
by lolo106. 19/08/22 10:15 AM
And to add to the Linux tale - now Apple
by Graham, G4FUJ. 19/08/22 09:34 AM
My 1991 Plus 8
Morgan Super 4 EV
4/4 75th Anniversary
Around the Cairngorms
Big Skies
Topics43,892
Posts739,267
Members8,107
Most Online1,033
Dec 28th, 2019
Biggles
Replacement of Parrot Series 5 Aero 8 #750789
04/08/22 07:51 PM
04/08/22 07:51 PM
I
Ian12345Aero8 Offline OP
I
My Series 5 has a Parrot car entertainment system, it might have been good when first designed (back in 2015 I think) but is now pretty outdated and no longer supported by Parrot. I would like to replace it but I can't work out how on earth to get the existing unit out of the car, I have a nasty feeling that it might need the dashboard to be removed. Does anyone know how to remove the Parrot or is there a specialist who has done this before somewhere, ideally in Beds/Bucks/Herts.
Any thoughts would be most appreciated.
Re: Replacement of Parrot Series 5 Aero 8 [Re: Ian12345Aero8] #750800
04/08/22 08:57 PM
04/08/22 08:57 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
No idea what this is, but if it's normal car radio format they usually require a pair of flat metal keys to release the internal anti-theft catches. With these inserted each side the unit is free to pull out. Maybe they're hidden in a safe place??
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: Replacement of Parrot Series 5 Aero 8 [Re: Ian12345Aero8] #750824
05/08/22 06:42 AM
05/08/22 06:42 AM
Zurich, Milan
Ale_72 Offline
Ale_72  Offline
Zurich, Milan
If it's the parrot asteriod 1din, looks like a jigsaw blade could make the trick. Originally it's a C shaped tool.
https://www.youtube.com/watch?v=AeCuDaLXcpg
https://www.4c-forums.com/threads/need-help-removing-parrott-please.44458/
Re: Replacement of Parrot Series 5 Aero 8 [Re: RichardV6] #750850
05/08/22 08:35 AM
05/08/22 08:35 AM
I
I
thanks for the reply but the old flat metal keys won't work on this unit which is a double DIN sized unit and its full name is Parrot Asteroid Smart (so not the asteroid 1DIN). There must be screws holding it in somewhere but how to access those screws?
Re: Replacement of Parrot Series 5 Aero 8 [Re: Ian12345Aero8] #750889
05/08/22 11:25 AM
05/08/22 11:25 AM
Hampshire
Alistair Offline
Smile, it confuses them
Alistair  Offline
Hampshire
https://www.parrot.com/uk/support/documentation/asteroid
If I understand the model correctly try this one.
https://www.parrot.com/assets/s3fs-public/2021-09/asteroid-smart_user-guide_uk.pdf
this is the user documentation for the device.
Page 10 shows the elements. There is a frame that installs to the back of the dash and the device fits into this.
I am looking at the Bluetooth Amps and using my phone as the total ICE stack at the moment. I am just going to leave the 2011 Alpine thing to fill the hole in the dash.
On the Coupe there is apparently a 4 channel amp under the passengers seat, so I would swap this out and link the iPhone up to in on BT.
https://www.ebay.co.uk/itm/334432356488?epid=3036505605&hash=item4dddb8c888:g:hicAAOSw9BBfx9fi
Just time to rent a thimble more petrol before dinner.
Re: Replacement of Parrot Series 5 Aero 8 [Re: Ian12345Aero8] #750892
05/08/22 11:49 AM
05/08/22 11:49 AM
Lincoln.
The Flitting Offline
Lincoln.
I replaced my Parrot he’d unit with a Sony XAV-AX5650ANT head unit primarily as it was double din at the front but only single din at the rear and ai was not sure how much space was behind the dashboard. It also supports Apple car play etc. have had this unit in the car for a couple of years so far and am well pleased with it although DAB reception is not the best but I mostly stream the radio though my iPhone anyway and use TomTom on my iPhone as my sat nav.
Due to the way Morgan fitted the Parrot unit the dashboard does need to be moved to do the work. My unit was replaced by Ledgerwood Morgan but I believe Krazy horse has also upgraded a couple of Aeros
Re: Replacement of Parrot Series 5 Aero 8 [Re: Ian12345Aero8] #750899
05/08/22 12:10 PM
05/08/22 12:10 PM
TheCustomer Offline
TheCustomer  Offline
there was a thread on this in 2020, which ended with a Sony unit working in an S5
http://www.talkmorgan.com/ubbthreads.php/topics/673397/change-parrot-smart-infotainment-system
Will
Aero 8 S5
BMW i8 Coupe
Re: Replacement of Parrot Series 5 Aero 8 [Re: The Flitting] #750917
05/08/22 02:56 PM
05/08/22 02:56 PM
I
I
Thanks Alistair, you have correctly identified the beast!
The bluetooth amp is an interesting idea that I hadn't thought of, the down side is that it hasn't got a screen for sat nav etc.
Re: Replacement of Parrot Series 5 Aero 8 [Re: The Flitting] #750919
05/08/22 03:10 PM
05/08/22 03:10 PM
I
I
Thanks - The Flitting, you have confirmed my fears that the dashboard needs to come off, what a pain, that probably means I have to use Morgan dealer, neither of the dealers mentioned are near me so will try Melvin Rutter next. Thanks again.
By the way, when the roof is down, how viewable is the screen on your Sony, with the Parrot the glare means the screen looks just like a mirror.
Re: Replacement of Parrot Series 5 Aero 8 [Re: TheCustomer] #750920
05/08/22 03:11 PM
05/08/22 03:11 PM
I
I
Thanks Will
