4 registered members (peterd, flaagan, Jeff D, MattB), 96 guests, and 12 spiders.
+8Rich 305
OZ 4/4 187
John V6 182
CooperMan 158
RichardV6 137
Captain Morgan, CVH44, Ruffy, Morgan76, RogerEB
8107 Registered Users
Automatic transmission swap on a 60's +4?
by flaagan. 19/08/22 10:47 PM
Apple security threat today..?
by Luddite. 19/08/22 07:13 PM
Brake Recall - A Related Issue
by Budster. 19/08/22 02:21 PM
Seat belt reel problem
by bmgermany. 19/08/22 01:22 PM
New Zealand Floods
by OZ 4/4. 19/08/22 10:30 AM
Hello from France
by lolo106. 19/08/22 10:15 AM
And to add to the Linux tale - now Apple
by Graham, G4FUJ. 19/08/22 09:34 AM
My 1991 Plus 8
Morgan Super 4 EV
4/4 75th Anniversary
Around the Cairngorms
Big Skies
Topics43,892
Posts739,267
Members8,107
Most Online1,033
Dec 28th, 2019
Biggles
Plus 4 Duratec - Air Filter #750952
05/08/22 07:43 PM
05/08/22 07:43 PM
Montegue Offline OP
Montegue  Offline OP
Hi all,
Can someone confirm the original aplication for the air filter in my 2012 Plus 4?
To be clear I'm not looking for a so called performance air filter, I'm perfectly happy with fitting a new standard paper element panel type but it would just be useful to know the OEM aplication so I can source one easily and at a reasonable cost.
Details on the cabin air filter would be much appreciated too.
Thanks in advance, Dave.
Re: Plus 4 Duratec - Air Filter [Re: Montegue] #750955
05/08/22 07:55 PM
05/08/22 07:55 PM
North Somerset, UK
Deejay Offline
Deejay  Offline
North Somerset, UK
Bosch version of air filter is S3047. £11.85 from Amazon which I found to be cheaper than local factor.
Cabin filter? do you mean that bit of foam on top of the heater box under the bonnet? if so, any old bit of foam will do, or give it a wash!
Doug
2011 +4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Re: Plus 4 Duratec - Air Filter [Re: Deejay] #750965
05/08/22 09:04 PM
05/08/22 09:04 PM
Montegue Offline OP
Montegue  Offline OP
Excellent, thanks.
And yes, I looked at that bit of foam and assumed it was a pre-filter and there might be something more OEM under it confused2
Clearly I'm new to Morgan ownership laugh2
Re: Plus 4 Duratec - Air Filter [Re: Montegue] #750969
05/08/22 09:10 PM
05/08/22 09:10 PM
Köln Germany
Heinz Offline
Heinz  Offline
Köln Germany
I must say that an open K&N can make sense, so I mean such a cylinder or mushroom. But the inserts in the normal standard airboxes....I have made the experience that the paper filters are simply better than the K&N alternative. I found on the Roadster 3.0 and on my current 4/4 that the standard paper filter makes better torque out of the basement. You also protect your MAF sensor.
Re: Plus 4 Duratec - Air Filter [Re: Heinz] #750970
05/08/22 09:40 PM
05/08/22 09:40 PM
South Yorkshire
DaveW Offline
DaveW  Offline
South Yorkshire
Also my findings with my S1 Roadster.
Jury is still out with GDI!
Re: Plus 4 Duratec - Air Filter [Re: Montegue] #750974
05/08/22 10:21 PM
05/08/22 10:21 PM
Essex
Burgundymog Offline
Black Rat
Burgundymog  Offline
Black Rat
Essex
It's a Mondeo air box. I have a K&N cone filter fitted to mine by Cain @ Wolf Performance.
Keith
2013 narrow bodied + 4 Ruby.
Re: Plus 4 Duratec - Air Filter [Re: Montegue] #750990
06/08/22 06:56 AM
06/08/22 06:56 AM
Montegue Offline OP
Montegue  Offline OP
Personally, I'd want to see conclusive evidence of power gains before moving on from the standard paper element panel filter, over the years all my experience has been a performance air filter will add little or nothing other than an increase in induction noise.
Saying that I did run a K&N filter on my TVR, but this was more for ease of maintenance. Having replaced the Lucas 14CUX on my Chimaera with an aftermarket standalone engine management system meant replacing the sensitive hotwire MAF with a MAP, so the sensor oiling issue was eliminated and the K&N was easy to clean and re-oil at service time so over the years it saved me a fortune in standard and crumbling foam filters.
Now I know my Plus 4 runs a £12.00 Mondeo air filter I'll be sticking with that, Monty is looking like he'll be cheap as chips to run cloud9
