2 registered members (GParkins, ship1), 62 guests, and 40 spiders.
+8Rich 149
John V6 136
OZ 4/4 121
Alistair 104
05 Roadster, John Tromans, Factotum, Dave Jones, Fester
8159 Registered Users
Spark Plug Wires
by PaulyG. 09/12/22 04:47 PM
Jet Black
by lowebird. 09/12/22 03:01 PM
It is crowded up there
by John V6. 09/12/22 01:52 PM
Autocar YouTube
by ProfessorM. 09/12/22 01:43 PM
M3W oil pressure switch
by planenut. 09/12/22 12:02 PM
Shed Racing vid
by Luddite. 08/12/22 04:23 PM
New Morgan Pedal Car - Kettcar
by flyfisher. 08/12/22 03:42 PM
Cover Girl_MOG414
Under the clouds....
Ms Marple's island/s connection...
Autumn Sunshine
Back Onshore
Topics44,401
Posts750,323
Members8,159
Most Online1,033
Dec 28th, 2019
346VAB, Dannywk
Clutch Replacement #453059
04/06/17 09:04 PM
04/06/17 09:04 PM
Wigan
WarBird Offline OP
WW11 MOG
WarBird  Offline OP
WW11 MOG
Wigan
I've just got the engine out to fit new rubber barrels to the Centa compensator - see my other thread
It was quite a struggle to get at the bellhousing bolts, but now I've managed it I'm starting to strip down to the compensator.
I've removed the clutch friction plate seems around half worn, but the pressure plate looks to have got quite warm....
I'm going to fit a new clutch, but before I order...and wait for Morgan parts dept...... has anyone on here fitted an aftermarket clutch?
If so, what was it?
Thanking you in anticipation
Re: Clutch Replacement [Re: WarBird] #453088
05/06/17 04:30 AM
05/06/17 04:30 AM
exagone
GLLOQ Offline
GLLOQ  Offline
exagone
When I replaced the rubber centa I handed my first clutch disc which was in good condition because I found a damper spring broken, the clutch disc measures 181 mm the 22 splines of the standard meme as Ford Mondéo diesel or G50 porsche.
Re: Clutch Replacement [Re: WarBird] #453134
05/06/17 09:30 AM
05/06/17 09:30 AM
North West USA
Timothy Offline
Timothy  Offline
North West USA
WarBird, how many miles do you have on your M3W?
1998 +8
SS Sport tuned exhaust
2013 M3W
Stage ll motor kit
Cats removed
Re: Clutch Replacement [Re: WarBird] #453176
05/06/17 12:15 PM
05/06/17 12:15 PM
Wigan
WarBird Offline OP
WW11 MOG
WarBird  Offline OP
WW11 MOG
Wigan
Around 9000 miles
Remember that it does get some Motorsport abuse
Re: Clutch Replacement [Re: WarBird] #453204
05/06/17 03:39 PM
05/06/17 03:39 PM
exagone
GLLOQ Offline
GLLOQ  Offline
exagone
I was mistaken the 22 splines of the 5 speeds does not correspond to ford mondéo and G50 porsche, only the 23 splines of the boxes six gears mazda that correspond to ford and G50,My tw will have 60,000km.
Re: Clutch Replacement [Re: GLLOQ] #453278
05/06/17 07:30 PM
05/06/17 07:30 PM
North West USA
Timothy Offline
Timothy  Offline
North West USA
That is odd. I talked to the shop that is the go to place out of Portland, Oregon and what they tell me the six speed has the same back end and fitting a updated six speed will slip right in.
1998 +8
2013 M3W
Stage ll motor kit
Cats removed
Re: Clutch Replacement [Re: WarBird] #753735
29/08/22 12:58 AM
29/08/22 12:58 AM
Mogegg Offline
Mogegg  Offline
Is there even a Porsche G 50? ???
Re: Clutch Replacement [Re: WarBird] #753738
29/08/22 01:53 AM
29/08/22 01:53 AM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
The G50 is actually a transaxle type used by Porsche, and 911's from that era (late '80s perhaps into the early '90s, I think) are often referred to by the transaxle which was a desirable high capacity unit used in the Turbos, among others.
Late 2012 M3W
Re: Clutch Replacement [Re: Bitsobrits] #753743
29/08/22 07:21 AM
29/08/22 07:21 AM
Lytham St Annes, Lancashire
JohnHarris Offline
JohnHarris  Offline
The G50 gearbox was first introduced in 1987 in the Carrera 3.2, only appeared in the last year of production in 1989 in the 930 turbo and then went onto use in all the 911's ie 964,993,996 and 997.
2008 Roadster 4 seater FELIX
prev 2006 4/4 70th LOKI
prev 1977 4/4 SEAMUS
prev 1985 4/4 MOLLY
Re: Clutch Replacement [Re: WarBird] #753823
29/08/22 05:43 PM
29/08/22 05:43 PM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
Ah, a much more complete answer. Thanks
Late 2012 M3W
