2 registered members (Barkbark, CraigL), 51 guests, and 35 spiders.
+8Rich 149
John V6 136
OZ 4/4 121
Alistair 104
05 Roadster, John Tromans, Factotum, Dave Jones, Fester
8159 Registered Users
Spark Plug Wires
by PaulyG. 09/12/22 04:47 PM
Jet Black
by lowebird. 09/12/22 03:01 PM
It is crowded up there
by John V6. 09/12/22 01:52 PM
Autocar YouTube
by ProfessorM. 09/12/22 01:43 PM
M3W oil pressure switch
by planenut. 09/12/22 12:02 PM
Shed Racing vid
by Luddite. 08/12/22 04:23 PM
New Morgan Pedal Car - Kettcar
by flyfisher. 08/12/22 03:42 PM
Cover Girl_MOG414
Under the clouds....
Ms Marple's island/s connection...
Autumn Sunshine
Back Onshore
Topics44,401
Posts750,323
Members8,159
Most Online1,033
Dec 28th, 2019
346VAB, Dannywk
Page 6 of 9 1 2 3 4 5 6 7 8 9
Re: Crank Position Sensor - Let's find an alternative [Re: Bunny] #752518
17/08/22 06:58 PM
17/08/22 06:58 PM
exagone
GLLOQ Offline
GLLOQ  Offline
exagone
What matters most to me is the impedance I've been looking for the right length and impedance for several weeks now and I haven't found it yet, generally it doesn't give a diameter for $10 I risk myself cheaply and for the length is not a big issue for me the harley sensor is not available from aliexpres currently.
I just bought a timing belt from Morgan this afternoon to get spare parts ahead of time, the price has gone up.
Re: Crank Position Sensor - Let's find an alternative [Re: Bunny] #752562
18/08/22 07:58 AM
18/08/22 07:58 AM
atalante83 Offline
atalante83  Offline
All increase
Re: Crank Position Sensor - Let's find an alternative [Re: GLLOQ] #752584
18/08/22 01:22 PM
18/08/22 01:22 PM
France
Black Adder Offline
Toys for Boys
Black Adder  Offline
Toys for Boys
France
Stunning work as always! Will be in touch.
Omne trium perfectum
Re: Crank Position Sensor - Let's find an alternative [Re: Bunny] #753047
22/08/22 07:21 PM
22/08/22 07:21 PM
San Diego, California, USA
PocketRocket Offline
For those looking to purchase a replacement Crank Position Sensor Kit 106-0734.
S&S just produced some inventory, You'll need to call direct to place your order, it's not listed on the S&S web site.
I just received my spare! the price was reasonable too!
M3W
Plus 4
Re: Crank Position Sensor - Let's find an alternative [Re: PocketRocket] #753066
22/08/22 09:00 PM
22/08/22 09:00 PM
Leicestershire, UK
Bunny Offline OP
Bunny  Offline OP
Leicestershire, UK
Originally Posted by PocketRocket
For those looking to purchase a replacement Crank Position Sensor Kit 106-0734. S&S just produced some inventory, You'll need to call direct to place your order, it's not listed on the S&S web site. I just received my spare! the price was reasonable too.
What do you call reasonable? Just asking for a friend... innocent
Andy
Re: Crank Position Sensor - Let's find an alternative [Re: Bunny] #753073
22/08/22 09:32 PM
22/08/22 09:32 PM
Their list price... $129 plus tax...
M3W
Plus 4
Re: Crank Position Sensor - Let's find an alternative [Re: Bunny] #754438
04/09/22 01:05 PM
04/09/22 01:05 PM
exagone
GLLOQ Offline
GLLOQ  Offline
exagone
I received the Kia / Hyundai sensor and modify the diameter which is larger and make a fixing, I will stick it to the same depth it may be that the O-ring on the crankcase cone is sufficient.
Re: Crank Position Sensor - Let's find an alternative [Re: GLLOQ] #754534
05/09/22 08:56 AM
05/09/22 08:56 AM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
Hi GLLOQ,
Can you expand on "modify the diameter please" , do you mean the diameter of the sensor body ?
Thanks
Re: Crank Position Sensor - Let's find an alternative [Re: Bunny] #754577
05/09/22 02:24 PM
05/09/22 02:24 PM
exagone
GLLOQ Offline
GLLOQ  Offline
exagone
I destroyed the fixing with cutting pliers then with the lathe I reduced to half then I turned it over to machine the other side to the correct diameter, the Kia Hyundai sensor at about 1 mm in diameter more and has 1 cm too long, then I fixed an original sensor on the lathe machine 2 mm from the chuck then started at 1000 rpm to see the voltage produced, after I mounted the Kia and realized that I reduced by 0.3 mm to have the same voltage, despite everything 0.2 volts should not matter.
I'll give it a try tomorrow maybe.
Re: Crank Position Sensor - Let's find an alternative [Re: Bunny] #754765
06/09/22 07:13 PM
06/09/22 07:13 PM
exagone
GLLOQ Offline
GLLOQ  Offline
exagone
I mounted the Kia sensor to modify this evening it works for the moment I will test several days and order another sensor to try to make a hollow for the O-ring in the position like the original sensor.
