2 registered members (Barkbark, CraigL), 51 guests, and 35 spiders.
+8Rich 149
John V6 136
OZ 4/4 121
Alistair 104
05 Roadster, John Tromans, Factotum, Dave Jones, Fester
8159 Registered Users
Spark Plug Wires
by PaulyG. 09/12/22 04:47 PM
Jet Black
by lowebird. 09/12/22 03:01 PM
It is crowded up there
by John V6. 09/12/22 01:52 PM
Autocar YouTube
by ProfessorM. 09/12/22 01:43 PM
M3W oil pressure switch
by planenut. 09/12/22 12:02 PM
Shed Racing vid
by Luddite. 08/12/22 04:23 PM
New Morgan Pedal Car - Kettcar
by flyfisher. 08/12/22 03:42 PM
Cover Girl_MOG414
Under the clouds....
Ms Marple's island/s connection...
Autumn Sunshine
Back Onshore
Topics44,401
Posts750,323
Members8,159
Most Online1,033
Dec 28th, 2019
346VAB, Dannywk
Re: Clutch Replacement [Re: WarBird] #754044
31/08/22 04:04 PM
31/08/22 04:04 PM
North Wales
Red3W Offline
Red3W  Offline
North Wales
WarBird – Remembering an M3W 5 speeder enthusiast and racing pioneer of these little trikes. He was such a friendly and helpful chap who had great enthusiasm for the car.
Re: Clutch Replacement [Re: Red3W] #754048
31/08/22 05:12 PM
31/08/22 05:12 PM
Cheshire, UK
nippymog Offline
nippymog  Offline
Cheshire, UK
2nd to that, RIP Austin.
How are you Red3W? , not heard from you in a long time. All the best.
Re: Clutch Replacement [Re: nippymog] #754312
03/09/22 08:02 AM
03/09/22 08:02 AM
North Wales
Red3W Offline
Red3W  Offline
North Wales
We are good thanks Nippymog. Hope you are both okay. I still look in occasionally to see what is going on.
Re: Clutch Replacement [Re: WarBird] #755033
09/09/22 12:26 AM
09/09/22 12:26 AM
Mogegg Offline
Mogegg  Offline
Ahh the ole g50 Porsche . Lol long and short of it . Is there ANY M3W owner who Actually sourced and installed a non Morgan factory “part”. I have scoured all the clutch articles here. It’s seems a bigger clutch friction plate and pressure plate is not a problem due to roomy bell housing. I have to do a clutch job . And my inclination is to take the opportunity to put in a beefier larger more capable clutch . I saw the possible sources mentioned, but wanted to get some up to date actual use input ? Why not go bigger and as high performance as possible? If fully technically possible .
Re: Clutch Replacement [Re: WarBird] #755093
09/09/22 01:19 PM
09/09/22 01:19 PM
Gods own county! Oop north
Dab of oppo Offline
Dab of oppo  Offline
Perhaps more rotating mass would put extra strain on the crank shaft as it was never designed to spin a big flywheel and clutch assy. Also it would slow the throttle response down.
Re: Clutch Replacement [Re: WarBird] #755142
09/09/22 10:23 PM
09/09/22 10:23 PM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
Do not forget to change the throwout bearing while you are in there doing the clutch job.
Re: Clutch Replacement [Re: Mogegg] #755199
10/09/22 05:45 PM
10/09/22 05:45 PM
Lot et Garonne, France
Stevo666 Offline
Stevo666  Offline
Sorry - got to ask, what's wrong with the standard fitment clutch - in albeit 'heavy duty' spring version? So not an MMC supplied friction plate.
The clutch isn't normally a huge issue on the M3W...odd spring broken but that's about it.
Its up to the job of transferring the power as required.
Re: Clutch Replacement [Re: Dab of oppo] #755230
10/09/22 11:47 PM
10/09/22 11:47 PM
Mogegg Offline
Mogegg  Offline
No flywheel change . The Morgan 3w practically has no flywheel . So there’s no flywheel change or any additional mass related to that. I’m talking about , to begin with just using the slightly bigger actual Mazda Miata friction plate . Morgan plate 180 , step up 210 . Not a giant change , but a nice increase in friction plate .
Seems perfectly feasible . As to the pressure plate , I would assume a matching plate is made for the corresponding friction plate. All this info I’ve garnered from the forum. Kinda wild that nobody has actually correctly sourced and ran with a better than stock , beefier , more efficient clutch ? Or has anyone? I’d really like too.
Re: Clutch Replacement [Re: WarBird] #755349
12/09/22 12:50 AM
12/09/22 12:50 AM
SW Iowa, U.S.A.
Bitsobrits Offline
Bitsobrits  Offline
SW Iowa, U.S.A.
I believe the reason no one has sought a "beefier, more efficient" clutch is there is simply no need to do so.
As for you comment "the Morgan 3W practically has no flywheel" you need to remember that that S&S motor already has a huge amount of mass (and therefore flywheel effect) in it's 43 pound crankshaft. Adding any more mass to the rotating assembly, especially cantilevered from the crank as is the M3W clutch, is a very bad idea, IMHO.
Late 2012 M3W
Re: Clutch Replacement [Re: Bitsobrits] #755350
12/09/22 01:02 AM
12/09/22 01:02 AM
Port Orchard, WA.
LightSpeed Offline
LightSpeed  Offline
Port Orchard, WA.
+1
