14 registered members (BobtheTrain, petemog, AlyMatt, nick w, Aeromax51, DCH, Julian BB, Gordon D, Edwin, TBM, Ginmoggie, Dab of oppo, Bunny, Paul F), 198 guests, and 11 spiders.
+8Rich 136
John V6 106
OZ 4/4 89
8359 Registered Users
Book recommendation..
by +8Rich. 28/05/23 01:29 PM
Morgan roof
by tom+4. 28/05/23 10:02 AM
Luton Town FC in Premier League
by Fox Terrier. 28/05/23 08:09 AM
MSCC Denmark 50th: Frederica 8th June
by docock. 28/05/23 07:10 AM
car recovery from europe
by howard. 27/05/23 10:40 AM
Myford lathe
by Grumpy2. 26/05/23 06:56 PM
Sat nav mountings
by nick w. 26/05/23 03:39 PM
Spotted In Amboise Loire
Wiscombe Park
Sod the rain
Forums32
Topics45,124
Posts764,270
Members8,359
Most Online1,033
Dec 28th, 2019
Maskellman, Matt C, mphcarpaintings, TeBe-Swe
Horn slip ring (Moto-Lita) #756267
22/09/22 03:59 PM
22/09/22 03:59 PM
Northern Germany
bmgermany Offline OP
Northern Germany
I need some help that means I have some questions confused2:
The wire to the horn slip ring is broken because the slipring has loosened.
How was the ring fixed? Glued?
Also the thin copper sheet on the switches is bent and beginning to break.
So I am afraid I have to buy the whole plastic part where Indicator lever and windscreen wiper lever ?
Re: Horn slip ring (Moto-Lita) [Re: bmgermany] #756281
22/09/22 05:35 PM
22/09/22 05:35 PM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
I‘ve got the same problem.
Usual the metal is „pressfitted“. I fitted a new wire („gelötet“) and glue the ring at the plastic.
Greets René
2018 plus4 (sports green)
with a homemade really shiny red tinted dash
Re: Horn slip ring (Moto-Lita) [Re: bmgermany] #756461
25/09/22 08:26 AM
25/09/22 08:26 AM
Sweden
Bjorn V Offline
Bjorn V  Offline
Sweden
I had a similar problem on my +8. The ring loosened, wich caused some interesting problems with the horn. I glued it back on.
Greetings from Sweden.
Morgan +8 1998
Re: Horn slip ring (Moto-Lita) [Re: bmgermany] #756528
26/09/22 07:23 AM
26/09/22 07:23 AM
Northern Germany
Northern Germany
Hello Bjorn,
In the meantime, the the small contact under the slip ring has also broken.
When I'm back in Germany, I'll have to see if I have a spare part on the shelf.
I am looking for the best glue to fix the slip ring on the Alluminium Boss.
Aluminium is a bit more difficult to glue, and the glue should really hold and not stick immediately so that the slip ring can still be aligned well.
Unfortunately, Motolita's answer about the glue "suggested either Evo Stick or Fast Bond“ didn't help, because I couldn't find any glue in Germany with the described designations.
Which glue did you use and what experience did you have with it?
Re: Horn slip ring (Moto-Lita) [Re: bmgermany] #756533
26/09/22 08:34 AM
26/09/22 08:34 AM
X
xc68anc Offline
xc68anc  Offline
X
In cause of my bad English the answer to Bernd in German.
Der Kontaktring sitzt normalerweise in einem isolierenden KunststofftrĂ€ger. Dieser „TrĂ€ger“ ist so gearbeitet das der Kontaktring einrastet.
So wie Dein Kontaktring aussieht hat da mal jemand improvisiert.
Kunststoff und Metall klebt man mit jedem beliebigen Kontaktkleber (Pattex).
Gruß RenĂ©
And now:
Usual the contactring sit in a plastic. This plastic holds the ring by its construction.
But your contactring looks a little strange, as a bad DIY.
If you‘ve got the original plastic/metalconstruction every clue will work, the best in my eyes would be Pattex.
Greets René
Re: Horn slip ring (Moto-Lita) [Re: bmgermany] #756560
26/09/22 01:46 PM
26/09/22 01:46 PM
Northern Germany
Northern Germany
Hello Rene'
as I wrote: I have a Moto-Lita steering wheel boss.
Here an example from their website.
It looks like my boss.
How does. your your (plastic)part look?
Re: Horn slip ring (Moto-Lita) [Re: bmgermany] #756576
26/09/22 05:46 PM
26/09/22 05:46 PM
X
xc68anc Offline
xc68anc  Offline
X
My boss looks different.
It looks like the contactring is clued on leather? You can clue leather/metal with Pattex. Or: WÜRTH SprĂŒhkleber super.
Greets René
NS: ignore my email, sorry.
Re: Horn slip ring (Moto-Lita) [Re: xc68anc] #756587
26/09/22 07:39 PM
26/09/22 07:39 PM
People's Republic of South Yor...
CooperMan Offline
CooperMan  Offline
Greets René
It's a layer of natural cork, as an electrical insulator
A good 'contact adhesive' should work, the EvoStik referred to is a well known UK brand name
Re: Horn slip ring (Moto-Lita) [Re: bmgermany] #756616
27/09/22 08:02 AM
27/09/22 08:02 AM
Northern Germany
Northern Germany
Thank you! Now I understand!
As Service from Moto-Lita answered "I have checked with the factory and they have suggested either Evo Stick or Fast Bond."
I was looking for both "Evo Stick" and "Fast bond". Without result!
Now I found "Evo-Stik Impact" in GB via Amazon. I hope that is the right one.
Here in Germany "Evo Stik" is unknown.
Thank you again! cheers
Re: Horn slip ring (Moto-Lita) [Re: bmgermany] #756659
27/09/22 04:33 PM
27/09/22 04:33 PM
Sweden
Bjorn V Offline
Bjorn V  Offline
Sweden
Can not say that I remember what I used to glue the ring back on. your picture looks similar to what I have.
I probably used some 2 component stuff I had at home.
Morgan +8 1998
