11 registered members (sprinty, Paul Grout, RichardV6, M3W55, petemog, brownbaker, Jens, Max5, yrr13, CPN, CLPlusFour), 167 guests, and 12 spiders.
John V6 195
+8Rich 138
Alistair 136
OZ 4/4 125
Image 96
05 Roadster, John Tromans, Factotum, Dave Jones, Fester
8159 Registered Users
A great day out
by Gambalunga. 27/11/22 11:45 AM
New Zealand
by Paul Grout. 26/11/22 08:02 PM
RIP Doddie Weir
by +8Rich. 26/11/22 06:04 PM
Why is everything hard work these days?
by Paul F. 26/11/22 03:43 PM
Extra Gauges Plus 4 GDI
by DaveW. 26/11/22 03:18 PM
Old School scam
by lowebird. 26/11/22 11:03 AM
VSCC Prescott vid
by Luddite. 25/11/22 06:10 PM
Under the clouds....
Ms Marple's island/s connection...
Autumn Sunshine
Back Onshore
Citroens in Amsterdam
Topics44,350
Posts749,243
Members8,159
Most Online1,033
Dec 28th, 2019
No Birthdays
Roaster 3.0 MK 1 Pulley Noise / Wobble #756627
27/09/22 12:23 PM
27/09/22 12:23 PM
Perthshire & Kent
flyfisher Offline OP
Perthshire & Kent
Hi all,
On my Dads 2007 Roadster Mk1 there is now a noise from the engine which seems to be coming from the top pulley. There is also a noticeable wobble from the belts caused by the pulley.
Hopefully the picture came though.
Has this happened to anyone before?
Does anyone know the part number for the replacement pulley, it is simply a case of changing the pulley?
Many thanks in advance.
Will
Re: Roaster 3.0 MK 1 Pulley Noise / Wobble [Re: flyfisher] #756631
27/09/22 12:46 PM
27/09/22 12:46 PM
SimonH Offline
SimonH  Offline
That's not a Mk1 Roadster
The Mk1 doesnt have the top pulley like that
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Re: Roaster 3.0 MK 1 Pulley Noise / Wobble [Re: flyfisher] #756635
27/09/22 01:20 PM
27/09/22 01:20 PM
Perthshire & Kent
Perthshire & Kent
Hi Simon,
Yes it is… it is a June 2007 car so the last of the mark 1’s.
You can see the part better in the below add for a 3.0 ST220 v6
https://www.ebay.co.uk/itm/25571619...r=&widget_ver=artemis&media=COPY
Thanks in advance.
Will
Re: Roaster 3.0 MK 1 Pulley Noise / Wobble [Re: flyfisher] #756636
27/09/22 01:23 PM
27/09/22 01:23 PM
SimonH Offline
SimonH  Offline
All the early S1 cars ran without the top pulley- the alternator belt had to be stretched over the crank and alternator pulleys
Simon @ Sifab.co.uk
Re: Roaster 3.0 MK 1 Pulley Noise / Wobble [Re: flyfisher] #756640
27/09/22 01:28 PM
27/09/22 01:28 PM
Perthshire & Kent
Perthshire & Kent
The car had aircon from new, so that might explain the different pulley setup.
Is the top pulley driven or is it fixed?
Re: Roaster 3.0 MK 1 Pulley Noise / Wobble [Re: flyfisher] #756641
27/09/22 01:46 PM
27/09/22 01:46 PM
SimonH Offline
SimonH  Offline
Its driven by the belt wrapped round it. On the Mondeo its part of the engine mount. If you need to change the engine mount to replace the pulley bearing- then its a head off job as theres not enough room to get the engine mount out off the "vee"
Simon @ Sifab.co.uk
Re: Roaster 3.0 MK 1 Pulley Noise / Wobble [Re: flyfisher] #756642
27/09/22 01:52 PM
27/09/22 01:52 PM
Luddite Offline
Luddite  Offline
I know nothing of that engine set-up, though looks like the pulley in question may be driving the water pump given it`s location and diameter. IF that might be the case then it seems possible that the beating could be the issue. If possible you could try gently levering the pulley from behind with a long screwdriver or similar if the pulley moves then it seems you may need a new water pump.. If you were handy with spanners I might suggest loosening the tension on the belt and checking the rest of the pulleys for play in their bearings.
Good luck.
Re: Roaster 3.0 MK 1 Pulley Noise / Wobble [Re: flyfisher] #756643
27/09/22 01:59 PM
27/09/22 01:59 PM
New Forest
Lordofthewings Offline
New Forest
For comparison, my S2 Roadster was built in late-2008 (reg 1-1-09) with A/C, and looks like this:
Re: Roaster 3.0 MK 1 Pulley Noise / Wobble [Re: flyfisher] #756644
27/09/22 02:06 PM
27/09/22 02:06 PM
Aberdeenshire
Image Offline
Image  Offline
Aberdeenshire
Does the pulley move on its mounting bolts or can you feel play if you lift it in its bearing/bush? ... or is the pulley itself distorted?
Re: Roaster 3.0 MK 1 Pulley Noise / Wobble [Re: Luddite] #756645
27/09/22 02:14 PM
27/09/22 02:14 PM
SimonH Offline
SimonH  Offline
Good luck.
The water pump is on the back of this engine, driven by a pulley on the camshaft
Simon @ Sifab.co.uk
