2 registered members (Barkbark, CraigL), 51 guests, and 35 spiders.
+8Rich 149
John V6 136
OZ 4/4 121
Alistair 104
05 Roadster, John Tromans, Factotum, Dave Jones, Fester
8159 Registered Users
Spark Plug Wires
by PaulyG. 09/12/22 04:47 PM
Jet Black
by lowebird. 09/12/22 03:01 PM
It is crowded up there
by John V6. 09/12/22 01:52 PM
Autocar YouTube
by ProfessorM. 09/12/22 01:43 PM
M3W oil pressure switch
by planenut. 09/12/22 12:02 PM
Shed Racing vid
by Luddite. 08/12/22 04:23 PM
New Morgan Pedal Car - Kettcar
by flyfisher. 08/12/22 03:42 PM
Cover Girl_MOG414
Under the clouds....
Ms Marple's island/s connection...
Autumn Sunshine
Back Onshore
Topics44,401
Posts750,323
Members8,159
Most Online1,033
Dec 28th, 2019
346VAB, Dannywk
Re: Greasing the front UJs [Re: John V6] #756677
27/09/22 07:14 PM
27/09/22 07:14 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Found this image of my car being built John. It shows that with the central part of transmission cover removed (not sure how easy but seat removal at least) you should be able to see grease nipples by looking into gearbox cover area above driveshaft. You can also see the wider gap between seat boards and how the handbrake cable is P clipped to edge of n/s board, out of the way.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: Greasing the front UJs [Re: John V6] #756685
27/09/22 08:26 PM
27/09/22 08:26 PM
Suffolk, England
John V6 Offline OP
Brooklands Register contact
John V6  Offline OP
Suffolk, England
Thanks Richard. Food for thought. A hole in the gearbox tunnel on the drivers side.
2014 Brooklands Edition Roadster "Brookland's Belle" #5 of 50
Re: Greasing the front UJs [Re: John V6] #756710
28/09/22 06:56 AM
28/09/22 06:56 AM
RichardV6 Offline
RichardV6  Offline
And whilst you're at it maybe another further forward to access gearbox filler plug.
Re: Greasing the front UJs [Re: xc68anc] #756722
28/09/22 08:33 AM
28/09/22 08:33 AM
Essex
Burgundymog Offline
Black Rat
Burgundymog  Offline
Black Rat
Essex
Originally Posted by xc68anc
What are „UJs“?
Greets René
The flexible joints on the propeller shaft that connect the gearbox to the rear axle, grease nipples at the front are hard to find.
Keith
2013 narrow bodied + 4 Ruby.
Re: Greasing the front UJs [Re: RichardV6] #756725
28/09/22 08:43 AM
28/09/22 08:43 AM
Germany, Rhein-Main Area
X
xc68anc Offline
xc68anc  Offline
X
What are „UJs“?
Greets René
Universal joint - Universalverbindung or maybe Kardangelenk
Oh, great, thank you for the translation!
And I see „DIY“ (or looking like that) serviceholes are British standard.
At my classic MINI with an brakeservo fitted it was difficult to change the brakehoses. So I cut a hole in the rightside „innerwing“. In the left innerwing there is a hole, in cause there is the radiator. I think the HONDA-engineers at ROVER from the 90ies on haven‘t realized that you can‘t reach the hoses from the top with the servo in the way.
Greets René
2018 plus4 (sports green)
Re: Greasing the front UJs [Re: John V6] #756728
28/09/22 08:51 AM
28/09/22 08:51 AM
Luddite Offline
Luddite  Offline
UJ = Universal Joint. UJ`s = more than one universal joint.
Re: Greasing the front UJs [Re: Luddite] #756731
28/09/22 09:06 AM
28/09/22 09:06 AM
Petersfield, Hampshire
Ian Wegg Offline
Ian Wegg  Offline
Nope!
UJ's = belonging to a Universal Joint. UJs = more than one Universal Joint. UJs' = belonging to more than one Universal Joint.
read
1980 Morgan 4/4 4-seater
1932 Austin 7 Chummy
Re: Greasing the front UJs [Re: John V6] #756741
28/09/22 09:33 AM
28/09/22 09:33 AM
Luddite Offline
Luddite  Offline
Thanks for the translation of my failed attempt at a simplified translation...Ian. laugh2
Re: Greasing the front UJs [Re: John V6] #756785
28/09/22 06:38 PM
28/09/22 06:38 PM
north yorkshire
Lowflyer Offline
Lowflyer  Offline
north yorkshire
On the Triumph TR4A and TR6 you had no access to lubricate the outer UJs at the rear. They didn't seem to suffer too much although i did drill the bottom rear wishbones to allow access with a grease gun.
Re: Greasing the front UJs [Re: John V6] #756824
29/09/22 08:35 AM
29/09/22 08:35 AM
South West France
CBY Offline
CBY  Offline
South West France
On a friend's PLUS 4 we made a hole drilling 4 10mm holes and using with care a small hand saw without any problem. But be carefull.
Regards
2005 PLUS 4
