Morgan Aero 8
12 registered members (Steve Simmonds, waikiore, CLPlusFour, Heinz, CooperMan, Image, bobar, TBM, SimonH, Dan_Lockwood, Snowden, Alistair), 101 guests, and 15 spiders.
John V6 195
+8Rich 138
Alistair 136
OZ 4/4 125
Image 96
05 Roadster, John Tromans, Factotum, Dave Jones, Fester
8159 Registered Users
A great day out
by Gambalunga. 27/11/22 11:45 AM
New Zealand
by Paul Grout. 26/11/22 08:02 PM
RIP Doddie Weir
by +8Rich. 26/11/22 06:04 PM
Why is everything hard work these days?
by Paul F. 26/11/22 03:43 PM
Extra Gauges Plus 4 GDI
by DaveW. 26/11/22 03:18 PM
Old School scam
by lowebird. 26/11/22 11:03 AM
VSCC Prescott vid
by Luddite. 25/11/22 06:10 PM
Under the clouds....
Ms Marple's island/s connection...
Autumn Sunshine
Back Onshore
Citroens in Amsterdam
Topics44,350
Posts749,237
Members8,159
Most Online1,033
Dec 28th, 2019
No Birthdays
CANBUS & LEDs #756763
28/09/22 02:32 PM
28/09/22 02:32 PM
Buzz44 Offline OP
Buzz44  Offline OP
How can I tell if my 2014 Plus 4 wiring is Canbus. Want to change my sidelight bulbs in headlight fitting for LEDs.
Will T10 501 LEDs advertised as Canbus still work if the wiring is not Canbus.
Also am I right in assuming the replacement bulb should be glass, because a previous attempt with non glass bulbs was not successful, my theory being the heat when on dipped/full beam damaged the LED.
Any advice would be appreciated.
Regards
David
Re: CANBUS & LEDs [Re: Buzz44] #756779
28/09/22 05:55 PM
28/09/22 05:55 PM
Northern Capital of Cool
CooperMan Online content
CooperMan  Online Content
David, your Trad Plus 4 is not CANbus, any LED bulbs will work in that location as your car is 'traditionally' wired
Re: CANBUS & LEDs [Re: CooperMan] #756780
28/09/22 05:59 PM
28/09/22 05:59 PM
Dorset, UK
milligoon Offline
milligoon  Offline
Dorset, UK
Only if the wiring is the right way round, it's a Morgan afterall wink
Mark - No Longer driving
Re: CANBUS & LEDs [Re: milligoon] #756781
28/09/22 06:01 PM
28/09/22 06:01 PM
Just flip the bulbs over, 501's are wedge style
Re: CANBUS & LEDs [Re: Buzz44] #756790
28/09/22 06:56 PM
28/09/22 06:56 PM
Sumerset
Rog Offline
Rog  Offline
Sumerset
Good theory Dave. Locating any LED bulb (regardless of the material ) close to a 55W incandescence bulb might not be ideal. I suspect the potential life of the semiconductor LED and any other components will be reduced as and when you use your headlights.
Roger
Re: CANBUS & LEDs [Re: Buzz44] #756791
28/09/22 07:01 PM
28/09/22 07:01 PM
UK
BuyBritish Offline
BuyBritish  Offline
UK
David
Im using LEDS on all my cars including sidelights within the headlight with the 'hot' halogen bulb with no problems. LEDS used are from Classic car LEDS
Classic car LEDS
Rob Davies
Morgan 3 Wheeler 1934 MX
Morgan Series 1 1947
Morgan +4 1956 TR4
Morgan +4 2000 T16 Rov
Re: CANBUS & LEDs [Re: Buzz44] #756800
28/09/22 08:00 PM
28/09/22 08:00 PM
East Harling, Norfolk UK
RichardV6 Offline
RichardV6  Offline
Regards
Davie
There is a CANBUS system on later/last Classics David for both engine and body but lamp monitoring is not implemented, so any LED replacement to filament bulb should work fine.
Having said that it's important to use no hyperflash/CANBUS friendly LED indicator bulb replacements otherwise the flash rate will be compromised, but this relates to the flasher relay not CANBUS per se. It's possible to also use external resistors but the availability of aforementioned makes this solution redundant in most cases now.
2018 Roadster - Red/Magnolia - "Morton"
1966 Land Rover series 2a SWB
1945 Moto Guzzi Airone
Re: CANBUS & LEDs [Re: BuyBritish] #756825
29/09/22 09:04 AM
29/09/22 09:04 AM
Buzz44 Offline OP
Buzz44  Offline OP
Morning Everyone.
Many thanks for all the useful info. just amazes me what a helpful lot Morgan owners are.
Kindest Regards to you all
David
